Project Goat
95 replies to this topic
#51 Guns n roses
Guns n roses
  • 575 posts
Posted 24 May 2014 - 05:02 PM
Can i ask what would cause the converter to do that?
#52 _SLR Goat_
_SLR Goat_
Posted 25 May 2014 - 12:37 PM
Found the rear main cap dosent sit snug in the block little bit of movement already has being linebored honed once not sure what to do from here at the moment
#53 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 25 May 2014 - 07:52 PM
Welcome to Drag Racing Dennis !
Sorry I couldn't resist :o
Ok, I have got a chisel and flogged it into the block each side of the register to tighten up the cap fit before line honing in the past, a bit rough yet effective.
If it was me I would bail out of that block. A line hone moves the crank up into the block and I wouldn't want to do it more than once to the one block, in fact I try to avoid that machining operation if at all possible.
I have a couple of blocks here if you need one, I may be up your way later this week. What bore is your current combo ?
#54 _SLR Goat_
_SLR Goat_
Posted 25 May 2014 - 08:13 PM
Think it was line bored/honed 10thou cylinder bore is 20 thou over was hoping to get some more life of it pm me about those blocks if you do come up this way probably be handy to have a couple of spares if you have no need for them
#55 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 25 May 2014 - 08:52 PM
Gary,
When you put a lot of power through a torque converter with reduced volume (a high stall converter is smaller in body size) it builds up a lot of heat and pressure. In some cheaper built converters this results in the body expanding thereby causing the crank to move forward. This load is then borne totally on the thrust face of the rear main bearing.
To combat this converter manufacturers build 6mm thick plates into the front and rear of the converter. These are referred to as anti-ballooning plates.
It is now quite common in really powerful turbocharged and supercharged 308's to replace the thrust bearing with a Torrington roller bearing capable of taking the load from expanding converters !
#56 Guns n roses
Guns n roses
  • 575 posts
Posted 26 May 2014 - 08:57 AM
Anything that can be done to cool the converter saving it from expanding?
#57 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 26 May 2014 - 09:20 PM
No, the fluid just can't get through the converter quick enough.
Its much worse with a transbrake.
#58 _SLR Goat_
_SLR Goat_
Posted 27 May 2014 - 07:41 AM
Could the trimatic being stock not helped the situation im hoping with the new box and new converter i wont have these issues again
#59 _AD_75_
_AD_75_
Posted 27 May 2014 - 06:06 PM
I'd be doing this mod for sure.
#60 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 27 May 2014 - 08:49 PM
AFAIK its all in the converter Dennis.
#61 _SLR Goat_
_SLR Goat_
Posted 30 May 2014 - 07:42 AM
Cheers mate will keep an eye on the new converter and box
Seems the crank tunnel on my engine wasnt lined honed in the first place machine shop said the block is reusable picked up another ground 304 crank and bearings/rings etc should be here today to send off to get balanced start assembling it next week and hopefully get it back in the car
#62 _MaliZ_
_MaliZ_
Posted 31 May 2014 - 09:12 PM
I saw the post goat and expected a bomb like mine but instead I saw this machine, inspiring
#63 _benster208_
_benster208_
Posted 01 June 2014 - 08:37 AM
when you get it back together can you post a few pictures of the trimatic setup as I'm trying to fit a B&M shifter to my trimatic and I'm having all sorts of problems. The adaptor i bought off ebay isn't even close to fitting and the original don't work
either.  Also I'm worried about my cable having to go past the tailshaft. (its a rear fitting cable).
#64 _SLR Goat_
_SLR Goat_
Posted 17 June 2014 - 05:59 PM
After the crank thrust bearing issue i have it back together with another crank and fitted new rings and bearings also went to 002 oversize cam bearings which should fix a oil pressure issue i was having should have everything bolted back up for a saturday fire up and tune and test drive to see how the new trimatic and converter feel there are a couple of car meets coming up i will take it for a spin to before i take it back to willowbank for another blast
10411326_10152516617336967_1866816610540
10459920_10152516669601967_4884647312603
#65 _LHSL308_
_LHSL308_
Posted 18 June 2014 - 05:17 AM
Looking good Dennis. Are you expecting anymore hp in this thing? Let us know how you go mate.
#66 _SLR Goat_
_SLR Goat_
Posted 18 June 2014 - 07:39 AM
Rebuilt to same specs as before HP and MPH  wont change but should improve the ET with the 5K stall converter
#67 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 18 June 2014 - 07:47 AM
Good to see it back together so quick !
#68 Guns n roses
Guns n roses
  • 575 posts
Posted 18 June 2014 - 09:50 AM
Looks good! did you put the motor and box in 1 go or did you have the tranny still in?
#69 _SLR Goat_
_SLR Goat_
Posted 18 June 2014 - 04:37 PM
Trimatic was already in the car cant put them both in together the high energy sump prevents it
#70 _LHSL308_
_LHSL308_
Posted 18 June 2014 - 05:13 PM
Unless you come in from the bottom ofcourse.
#71 _SLR Goat_
_SLR Goat_
Posted 18 June 2014 - 05:14 PM
Lol my garage ceiling isnt high enough to do it that way
#72 _LHSL308_
_LHSL308_
Posted 19 June 2014 - 03:57 PM
Me neither mate.
#73 _LH SLR 3300_
_LH SLR 3300_
Posted 19 June 2014 - 08:07 PM
I like this car, nothing over the top, just simple & all business. And you kept the rectangle LH headlights :spoton:
#74 _SLR Goat_
_SLR Goat_
Posted 19 June 2014 - 08:57 PM
Cheers mate i dont mind the rectangle lights i have a stockpile of them here for when the sealed beam dies on one
#75 _LHSL308_
_LHSL308_
Posted 19 June 2014 - 10:26 PM
Mine still has the rectangular headlights too. In the early days I hated them and wanted to change to the LX ones. These days they have grown on me and they will be staying on the car.
