seal tabs
25 replies to this topic
#1 _Drag lc_
_Drag lc_
Posted 27 February 2009 - 03:00 PM
hi, as most would already know we have a pin hole in our head on new engine i have fixed it but was put onto this stuff called seal tabs? used to be in tablet form ,but now comes like fine sand what i was woundering was before i put this stuff in will it be problematic with ally radiator i guess not as all new cars proberly have ally radiators?.the reason i am looking to put this stuff in is i have now put collant in and are unsure if it will eat the loctite i doubt it it but was just going to throw this stuff in anyway.
Thanks Hayden
#2 _SLR Goat_
_SLR Goat_
Posted 01 March 2009 - 10:04 AM
be wary when mixing it with coolant ive heard stories of it reacting with some coolants and blocking up the radiator have used it at work a few times seems to do the job
cheers dennis
#3 Tiny
Tiny
  • 10,018 posts
  • Name:Tiny
Posted 08 March 2009 - 04:02 PM
Hayden: GO for it mate!
I used 2 tabs in the monaro ( the sachets of sandy stuff) and it fixed my problem with no side effects whatsoever!
I'm actually in discussions with the wholesaler to become a distributor of their products i like them so much!!
From all our tests, it's compatible with all coolants and stays active for around 2 years so you should have no worries!
Cheers mate
Tiny.
#4 _Drag lc_
_Drag lc_
Posted 08 March 2009 - 04:10 PM
Hi Tiny,
yeh the sandy stuff,you say active ? does that mean it will still seal a leak even after awhile of being used?.
#5 Tiny
Tiny
  • 10,018 posts
  • Name:Tiny
Posted 08 March 2009 - 09:42 PM
Yes mate!
It will sit in your cooling system active for 2 years i'm told and be ready to seal up any leaks that may occur in that time.
However it's been proven not to clog small holes/galleries or damage water pumps and bearings!
I've had it in the monaro for a *least* 6 months now with no bad effects, and i know of a ouple of cars that my engine builder has built that get heavy use ( burnout engines) that use them too!
Cheers!
#6 GML-31
Posted 08 March 2009 - 10:17 PM
any good for head gasket leaks?
#7 _Drag lc_
_Drag lc_
Posted 09 March 2009 - 12:08 PM
Thanks Tiny as i have not put it in yet but i will now
Thanks Hayden
#8 Tiny
Tiny
  • 10,018 posts
  • Name:Tiny
Posted 10 March 2009 - 09:01 PM
GML-31: From what i've read in the literature yes they are.
Depending on the size of the leak I guess will depend on how permanent the fix is. If it's very small i'd say the seal tabs will fix it and hang in there for quite a while, but if it's a serious gasket problem then they're not a miracle unfortunately.
As i mentioned with the Monaro, We could not find the source of the leak and i belive it has something to do with my head gaskets and i believe the water was going into a chamber but such a small ammount so as not to cause a problem. THe seal tab fixed it, and has stood up to 12 months of driving/racing in the monaro.
I'm definitely interested in any and all feedback as these are a new product ( to me - they;ve been around for years in america!) and I really like them and the other products.
Thanks Hayden, Keep in touch and let me know mate!
Cheers!
#9 _memorylane-spare-parts_
Posted 10 March 2009 - 09:26 PM
I have a radiator sealer it is a black block it looks like a block of h--hs it is the best. You can not mix it with any coolant or it will go to jelly i sell for $10.00 a block.
#10 Tiny
Tiny
  • 10,018 posts
  • Name:Tiny
Posted 10 March 2009 - 09:29 PM
Hi Daryl,
Sounds like an interesting product mate!
The benefit of our Seal tabs are that they are compatible with all known coolants, So there is no need to dump and flush the cooling system like with traditional sealants.
We tried another product in my Monaro with no effect and i believe it was due to residual coolant in the system not allowing the sealer to work.
All the best with it!
#11 _memorylane-spare-parts_
Posted 10 March 2009 - 09:48 PM
Hi Tiny
How do i get your seal tabs no one wants to drop there coolant out.
Thank You
Daryl :D
#12 Tiny
Tiny
  • 10,018 posts
  • Name:Tiny
Posted 10 March 2009 - 09:57 PM
Hi Daryl,
I see your location is Loganlea, I take it that's in Queensland?
PM sent!
#13 _memorylane-spare-parts_
Posted 10 March 2009 - 09:59 PM
Hi Tiny
I in brisbane
#14 Tiny
Tiny
  • 10,018 posts
  • Name:Tiny
Posted 10 March 2009 - 10:05 PM
Cool mate! I've Private MEssaged you the QLD distributor's detials :)
We're working on the NSW rights, and we hope that things will go well for us!
Cheers :)
#15 _mumbo_
_mumbo_
Posted 14 March 2009 - 11:01 AM
I ordered some this morning i think i have similer problem to what you had Tiny.
No one in WA had herd of them so i had to order direct from QLD.
#16 Tiny
Tiny
  • 10,018 posts
  • Name:Tiny
Posted 15 March 2009 - 10:24 PM
No Worries Mumbo!
PM me if you need any of their products, I can organise them and send them to you.
We are in discussion to take the NSW distributorship for their products, and I would also like to help WA people to get these products in the long run too!
Cheers!
#17 _Drag lc_
_Drag lc_
Posted 16 March 2009 - 08:07 AM
Tiny,
i have finaly put this stuff in our cooling system as the water pump was leaking out of tel tail hole when cold and it seems to have fixed it have not seen the temp rise yet so it hasent clogged system yet. so far so good. :spoton:
Thanks Hayden
#18 Tiny
Tiny
  • 10,018 posts
  • Name:Tiny
Posted 16 March 2009 - 06:32 PM
Excellent mate! That's great news! I'm always happy to hear how these products are going :)
#19 _Terrible One_
_Terrible One_
Posted 20 March 2009 - 06:13 PM
Is it similar to Chemiweld sorta stuff?
I blew the head gasket in my old 626 and put 2 bottles in (poor apprentice syndrome) and drove it for a couple years, never had a problem.
#20 _waz355_
_waz355_
Posted 20 March 2009 - 06:23 PM
Tiny who makes this stuff? I would be interested in it getting some.
I have used products like this before, but they all require the cooling system to be flushed and full of plain water only, as coolant is quite oily and doesn't allow the products to seal properly.
Whenever I build an engine I always run plain water and tabs for the first few hundred k's to make sure everything seals up, so being able to run the coolant as well would be great!
#21 Tiny
Tiny
  • 10,018 posts
  • Name:Tiny
Posted 20 March 2009 - 07:07 PM
Terrible: Yep mate! These are a similar idea to Chemi weld but these have many benefits over Chemiweld and even the other stuff in teh clear bottle - Seal up.
Mostly for me it was the fact that it doesnt clog small holes like radiator cores or in teh case of my 400 chev, the Steam Vent holes to the heads! - I stuck 2 Seal tabs in the radiator ( to be sure to be sure...) and it worked a treat - my cooling system now holds pressure!
Waz: Theyre an American Product made in the USA and we're the NSW distributor for it. THe major benefit as you mentioned is teh fact it's good to use with all known coolants - and thus you dont have to frig around with plain water or other potentially problematic chemical sealants.
A few older mechanics told me that Holden used to sell a similar tablet with EVERY water pump they sold! You got the pump, Gasket and two seal tabs!! If it's good enough for holden.. it's good enough for me!
But the bottom line is - I had a problem with the 400 Chev in the Monaro, and we could not pinpoint or fix it with "seal up" we used - and so i tracked down the Seal Tabs. After talking with the agent in Australia, I decided to try and become the NSW distributor because i love the products so much!
Keep on the lookout, I'm hoping to have these out there for everyone to see soon!
If anyone wants to try them, please PM me and i can send you details of your local supplier.
Tiny.
#22 _waz355_
_waz355_
Posted 20 March 2009 - 11:04 PM
Yeah I used to work for holden and back in the VR VS days we used to put 2 very large tablets into the system whenever you change the coolant. They only just fit through the neck of the radiator. You can still buy them.
#23 Tiny
Tiny
  • 10,018 posts
  • Name:Tiny
Posted 21 March 2009 - 09:05 AM
Ahh excellent!
I Belive they are if not exactly the same thing... then virtually the same thing!
Do they work with coolant?
Thanks Waz!
#24 _Terrible One_
_Terrible One_
Posted 22 March 2009 - 05:43 PM
What are they worth? I wouldnt mind putting a couple in my 202.
#25 _waz355_
_waz355_
Posted 22 March 2009 - 05:57 PM
Can't remember what they are worth, not expensive though. They do work with coolant and where also supposed to lubricate the water pump seal to prevent failure.
