big nut master cyl
59 replies to this topic
#26 _lx-304_
_lx-304_
Posted 05 March 2009 - 06:28 AM
phew,i was hoping that was it was,and not the jerry springer version.
dave
#27 Kockum
Kockum
  • 477 posts
Posted 05 March 2009 - 09:21 AM
I also have a 1974 Big Nut with 'N'. The 1968 big nut that is on a 68 Monaro is interesting because it does not specify Disc or Drum. It is on a Disc brake car which has the bail wire tag stamped Disc.
D.
#28 _HQ SS_
_HQ SS_
Posted 05 March 2009 - 09:10 PM
So there is more than one person that has a N on there master cylinder and it is interesting
to see that they are both 1974 made master cylinders as well.
So does anyone else have any others like this or another letter other than A N or P.
Kockum I have been told that the early master cylinders were not stamped with disc or drum,
someone with more knowledge on the subject may be able to confirm or deny that.
Cheers Paul.
#29 Kockum
Kockum
  • 477 posts
Posted 05 March 2009 - 11:59 PM
HQSS , the monaro big nut does not have a cast date on the underside of the cylinder body like LJ--HQ type do . It has HOLDEN and what appears to be a 7 digit part /cast number only . I will try to post that number later today . I have also seen cast iron HK --LC and LJ type master cylinders that have the long snout without the big nut . I must say that these style cylinders look very strange indeed .Perhaps DR .TERRY may be able to shed some light on this topic . D .
#30 _scottya!_
_scottya!_
Posted 06 March 2009 - 04:41 PM
These are the underside casting numbers on these 2 big nut masster cylinders
master 10J4N
master 15J6R
would these casting numbers have any significanse to what they are ?
#31 Kockum
Kockum
  • 477 posts
Posted 06 March 2009 - 05:43 PM
The cast/part no. on the bottom of the 1968 Monaro big nut is 7433138.
Scottya! your big nut 10J4N / 22H4 could be very desirable for someone with a L34, SLR5000 or HQ Monaro wanting to put it back to a matching numbers car.
Just for interest, here is a photo of a cast iron cylinder which has a long snout instead of a big nut. This example was on a HK Monaro on display at the Monaro Nationals in Bathurst.
D.
#32 Dr Terry
Dr Terry
  • 3,324 posts
Posted 07 March 2009 - 12:48 PM
The cast iron brake master cylinder without the big nut could be one of two types.
1. Early in the HK series GM-H must have had problems with producing enough brake master cylinders to keep up with car production. They imported a number of Delco-Moraine master cylinders from the U.S. to supplement supply, which were of similar design to the 'big-nut' variety but had the snout pictured above. They were that similar, they even used the same rebuild kit.
2. There were various other companies in those days (not just PBR), which supplied aftermarket Holden brake master cylinders & one or two of those also look similar to the one pictured above. The brand names ABS & Quinton Hazell come to mind.
Dr Terry
#33 Kockum
Kockum
  • 477 posts
Posted 08 March 2009 - 08:10 AM
DR TERRY , thanks for the information . I have just checked out a stash of cast iron master cylinders and there was one HK / LC long snout cylinder . This cylinder has no identification numbers /letters anywhere on it . D
#34 FLY_AGAIN_XU-1
FLY_AGAIN_XU-1
  • Banned
  • 1,653 posts
Posted 11 March 2009 - 09:46 PM
Firstly, did,nt the square top master cylinder first originate late 1971 early 1972 ??? Should,nt a HK be fitted with a round top master cylinder Part Number 7433138 ??? To my knowledge the ones with the long snouts and no nut were fitted to cars with factory and or dealer fitted air conditioning ??? Question :
Can you NUT it out ?
^^^^ 23H8 (23-8-1968) HK (Note no A or P)
^^^^ DISC 9E9 (9-5-1969) HK (Note no A or P)
^^^^ DISC 5J9 (5-9-1969) HT (Note no A or P)
ADR 4 : Seat Belts
ADR 5A : Anchorages for seat belts and child restraints
ADR 7 : Hydraulic brake hoses
^^^^ THE KEY
Who supplied Hydraulic brake hoses to Holden in the early 1970,s ???
Can you NUT it out ???
B.
#35 Kockum
Kockum
  • 477 posts
Posted 12 March 2009 - 09:18 AM
IMHO the 327 Monaro I photographed at Bathurst probably has the wrong style cylinder on it. It should be like this one which has the HK - G and LC rounded-off chambers and lid.
D.
#36 FLY_AGAIN_XU-1
FLY_AGAIN_XU-1
  • Banned
  • 1,653 posts
Posted 12 March 2009 - 03:43 PM
^^^^^^^^ These were mainly found on top of the line Brougham,s and later the early Statesman,s (That had air conditioning ???)
Any one nutted it out yet ???
:fool: :wtf: :deal: :stirpot:
#37 FLY_AGAIN_XU-1
FLY_AGAIN_XU-1
  • Banned
  • 1,653 posts
Posted 12 March 2009 - 03:55 PM
Dr Terry
[/quote]
^^^^^^^ A CLUE
#38 _scottya!_
_scottya!_
Posted 12 March 2009 - 04:10 PM
I give up !!!
#39 meanmachine72
meanmachine72
  • 2,033 posts
  • Name:Jono
Posted 12 March 2009 - 08:47 PM
no nuttin idea man......
#40 FLY_AGAIN_XU-1
FLY_AGAIN_XU-1
  • Banned
  • 1,653 posts
Posted 13 March 2009 - 09:26 AM
Come on guys !!!!!!!
The answer is there in front of ya,s !!!!!!
When did the bignuts first get A and P stamped into them ???????
ADR 7 became effective from Janurary 1970
How any more clues do ya,s want ??????
:dohdoh:
:nudie:
^^^ When did you become a emoticon Johnno ? lol
#41 FLY_AGAIN_XU-1
FLY_AGAIN_XU-1
  • Banned
  • 1,653 posts
Posted 13 March 2009 - 09:46 AM
Dr Terry
#42 Collo
Collo
    ( . Y . )
  • 114,647 posts
  • Car:A Black POS
Posted 13 March 2009 - 11:07 AM
'A' is for ABS, 'P' is for PBR and other letters represent the respective manufacturer?
#43 Kockum
Kockum
  • 477 posts
Posted 13 March 2009 - 11:10 AM
Are you saying that the A = ABS and P = PBR?
Do you know what company is represented by N?
If this turns out to be correct, given that the nuts are removable, a more "permanent" identifying mark of the manufacturer would have been a mark cast in the cylinder itself.
Here is another question I have wondered about. One is stamped Holden, the other Delco.
Perhaps Dr Terry can advise when the change in the lid stamping took place.
D.
#44 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 13 March 2009 - 11:19 AM
Hi
According to the ABS website - they didn't commence business until 1981.
Bazza
#45 meanmachine72
meanmachine72
  • 2,033 posts
  • Name:Jono
Posted 13 March 2009 - 11:48 AM
:dohdoh:
:nudie:
[/quote]
hahahahaha.....point taken bruce!!! i guess now is when i :blink: became that emoticon
promise to be sporting a 12 pack by toranafest!!!!lol :blink: :tease:
#46 FLY_AGAIN_XU-1
FLY_AGAIN_XU-1
  • Banned
  • 1,653 posts
Posted 13 March 2009 - 03:59 PM
D.
If i was a betting man (Which im not) my money would be on Nasco (Replacement) AC Delco supplied parts to both Holden and Nasco did,nt they ???
Certainly makes sence that P = PBR though according to Bazza,s research it appears that ABS did,nt commence business until 1981 ???
I think we may need some valueable input from Dr Terry or Dattoman to complete this one...........................
:nudie:
#47 FLY_AGAIN_XU-1
FLY_AGAIN_XU-1
  • Banned
  • 1,653 posts
Posted 14 March 2009 - 09:17 AM
The answer we seek may well be on the actual brake hoses themselves........
The original ones i have here are all marked PBR and believe it or not are also dated
Has anyone got some original brake hoses from 1970,s cars HT, HG, HQ, HJ, HX, or LC, LJ, LH, LX that are not PBR ones ??? And of coarse must be original fittment........ :banghead:
Could A = A C Delco (Just a guess)
Edited by FLY_AGAIN_XU-1, 14 March 2009 - 09:24 AM.
#48 FLY_AGAIN_XU-1
FLY_AGAIN_XU-1
  • Banned
  • 1,653 posts
Posted 14 March 2009 - 01:20 PM
#49 Collo
Collo
    ( . Y . )
  • 114,647 posts
  • Car:A Black POS
Posted 14 March 2009 - 01:43 PM
I'll have a look at my hoses in a min. I'm out strippin it it now, just came in for a beer and a quick look on here.
#50 _scooter_
_scooter_
Posted 14 March 2009 - 03:37 PM
My 8/73 XU-1 has PBR brake hoses (stamped on end)...they are a bit dirty to find any numbers at this stage. I had them replaced as they were leaking so I suppose they would have been the originals.
cheers,
scooter
