Supercharged 202 UC
#51
Posted 10 May 2009 - 03:33 PM
#52
_FCCOOL_
Posted 10 May 2009 - 04:04 PM
he also has a buick roadster pick up, he goes by the name buickroadster on forums, his buick has a valiant 265 with a big m112 eaton and offcourse LPG.
here is a motor he recently built for a vauxhall,
http://www.youtube.c...0...eurl=http:/
its a m90 on gas, it had to be fitted above the motor to fit under the narrow hood.
he is a bit of guru on fitting superchargers with gas to 4's and 6's
#53
_Brad1979UC_
Posted 11 May 2009 - 12:58 AM
doing some reading on bypass valves...This site quotes that
hmm.. sounds ALOT like whats going on with mine and would explain it.It opens on throttle lifts, preventing a big pressure build-up between the supercharger and the throttle. (In this respect it�s like a turbo blow-off valve, but in the case of a positive displacement supercharger, the pressure build-up when the throttle is closed can be very high � in fact, high enough to stop the supercharger and slip it against its belt drive.)
Yea oldjohnno, when the BOV vac nipple was connected to the vac line, i think it was actuating on idle, but you right its noisy!! it was making a ridiculously loud sound i shut it off straight away, like a higher pitched sound that the s/c makes without its pipes, ill have to get a mate over and try again, and see a) if pulley gets hot
Cheers FCCOOL, i have come across that vid before, nice setup, he might just be the guy to speak to if i get completely stuck! Nice setup you've got too, saw it in another thread
#54
_oldjohnno_
Posted 11 May 2009 - 07:08 AM
#55
_Brad1979UC_
Posted 13 May 2009 - 12:33 AM
#56
_Brad1979UC_
Posted 08 June 2009 - 09:28 PM
Though it does badly need a good dyno tune, seems to be flat spotting above 10 inhg and onto boost, havnt driven it yet but you can tell in the vid.
I have plumbed back the bov as you can tell in the photos. Its still pretty damn loud. The plumb back piping and hosing was pretty fiddly but got it to work. Its running infront of the radiator and in through the holes to the sides of the headlights.
#57
_holdskool_
Posted 31 July 2011 - 10:58 PM
