LC LJ Grommets
_les_
Posted 16 March 2009 - 07:01 PM
2805852 GROMMET FUEL UNDERBODY LC LJ
1039278 GROMMET CHOKE LJ
SP1982 GROMMET LC LJ INDICATOR LEAD LC
7416288 PLUG LICENCE PLATE LAMP MOUNT EH
7438395 GROMMET SPEEDO CABLE LC LJ HD HR
2806064 BOOT MASTER CYLINDER PUSH ROD DI
_SableMet7/73_
Posted 22 March 2009 - 11:31 PM
How about the firewall grommet that the engine bay
harness & the windscreen washer pump hoses pass thru.
Only been able to find 1 good 2nd hand one & there pretty
fragile these days.
I'll get a pic up tomorrow morning for you.
Cheers Jono
Posted 23 March 2009 - 12:18 AM
Gday Les,
fragile these days.
Cheers Jono
Hi Les
I second that!!
Bazza
Posted 23 March 2009 - 12:29 AM
Posted 23 March 2009 - 04:29 AM
_SableMet7/73_
Posted 23 March 2009 - 11:23 AM
Theres actually 2 separate grommets, it was a bit late when I posted, & I
hadnt looked at them for a while.
Heres pics of the Washer Hoses grommet & the Engine Bay Harness grommet.
I"ve got a washer hose 1 that I could send for a sample as the lip that fits the
firewall is split but the center is all there. The 1 on car I'll keep as the center is
buggered but the outside is OK & will stop my hoses chaffing.
Cant send a sample of the Harness grommet as only have the 1 on my harness
thats still resonable. Maybe someone else has a spare they could provide??
Let me know if you need the diameter of the firewall hole measured.
Cheers Jono
_OtG_
Posted 23 March 2009 - 11:37 AM
I may be able to help there, when I removed my loom a few weeks ago the old grommet split but I don't think I chucked it out and it might be still floating around in the shed. Will try to have a look this weekend if I have time (it doesn't matter that it's broken does it so long as it's in one piece so you can get measurements etc)??
Posted 23 March 2009 - 01:29 PM
i can't find the small rubber boots for the hand brake cables to go through the floor just behind the hand brake lever
_les_
Posted 24 March 2009 - 07:09 PM
OtG can you send the harness grommet?
Can anyone send the hand brake boot?
Samples can be sent to Les McVeigh C/o RSP P.O. Box 10 Somerton Vic 3062 and would be replaced with a new one when they are made. It usually takes about 6 months to make a grommet
Will that be all we need to make for the LC LJ, LH LX are next
Les
_OtG_
Posted 24 March 2009 - 07:18 PM
_SableMet7/73_
Posted 24 March 2009 - 11:05 PM
Whats the best way, an envelope or 1 of those padded
post bag things? Aussie posts a bit fussy sometimes.
They might think its an extra large H/Duty condom.
What about the grommet that the Heater box cable passes thru?
Is it the same as the Choke cable grommet?
I've got a NOS cable somewhere with a new grommet already
on it. I'll check it tomorrow.
Jono
_les_
Posted 25 March 2009 - 09:03 AM
Thanks Les
_SableMet7/73_
Posted 25 March 2009 - 11:28 AM
I found 1 of those padded Postpaks so I might as well use
it.
I'll get some pics of the Heater Box Cable grommet up this arvo
as I only just found it. Sorry cant send it to you as with the
plastic ends on the cable would probly bugger it trying to get it
off.
Jono
_SableMet7/73_
Posted 25 March 2009 - 10:05 PM
As you can see by the plastic mounts on the ends, the
grommet isnt coming off & its a new cable so I'm hanging on to it.
Anyone got a split 1 they could send to Les?
I noticed on the Rares site that they list SP3016 - Washer
Pump to Bottle Grommet. but theres no pic yet. Is this a new
one thats available that could be like the 1 I'm gonna send you?
J
_les_
Posted 26 March 2009 - 04:13 PM
Heres some pics of the Heater Cable & Grommet Les.
J
Jono SP3016 is the grommet were a pupmp could go on later models
Les
_SableMet7/73_
Posted 26 March 2009 - 04:37 PM
The sample of the Washer Hose's Grommet is on the way,
posted this afternoon.
Just in case its needed, the firewall hole for this grommet
measures 26.8mm.
Cheers Jono
_OtG_
Posted 29 March 2009 - 10:04 AM
It's split and perished but it's still in one piece - hope it's still useful to you.
_OtG_
Posted 30 March 2009 - 02:53 PM
_les_
Posted 31 March 2009 - 03:39 PM
OtG I will start the system as soon as the sample arrives
Thanks to both of you, when you see they have been released as a new product please remind me we owe you each a new one.
Can anyone think of any other grommets for LC LJ or has anyone got a sample of the handbrake rubber boot
Les
_SableMet7/73_
Posted 01 April 2009 - 12:39 AM
#21
_OtG_
Posted 01 April 2009 - 08:09 AM
Les
Do you mean the squarish rubber boots on the handbrake cables under the car?
If so, yes. My diff is out of the car at the moment with the cables and boots hanging off it already. I can soon send you one or both! I won't need them until the car is ready to be reassembled but that's most likely still quite a few months away.
Edit - just reread the the thread - not sure if these are the ones lcgtrrob is talking about. Suspect he's thinking of something different, the ones I'm thinking of are quite large.
Edited by OtG, 01 April 2009 - 08:12 AM.
#22
_les_
Posted 09 April 2009 - 03:43 PM
Just confirming grommet is sent mate... wiring loom grommet... along with another random one, may be something you already produce (if so you can bin it)... cheers
OtG
Recieved the grommets and sent one off for quotation the other we already make
Les
#23
_ozbox_
Posted 09 April 2009 - 04:21 PM
#24
Posted 09 April 2009 - 06:15 PM
Edited by lcgtrrob, 09 April 2009 - 06:17 PM.
#25
_OtG_
Posted 09 April 2009 - 06:26 PM
the handbrake boots i'm talking about are around 3"-4"long and around 1" in diameter and sit in the transmission tunnel just behind the handbrake-as ozbox said they are similar but i think one has a little larger flange where it goes into the floor
Rightio... in that case, I think we are talking about the same thing then.
Mine are just sitting in the shed still hanging off the cables, don't think they're damaged so should be good to use as a template. Will have a look at it over the next few days.
