Correct Inlet manifold for LX SLR5000?
#1 _DrFegg_
Posted 17 March 2009 - 06:28 PM
Im trying to locate a correct inlet manifold to suit my 1976 LX SLR5000. I realize this may be difficult but Ive got to try anyway. Can anybody help me with information on what i should be looking for (casting numbers , what shape are the inlet ports etc.?) ? The vehicle is a manual and runs a 4 barrel quadrajet, (which I believe is the original carby) and currently has an edelbrock performer manifold. Also what distinguishes the air cleaner from the later models? I have one (bought from evilbay) but im not sure its correct for the pollution set up.
Thanks all.
Posted 18 March 2009 - 09:58 AM
Early (water heated): HT/HG and HQ/HJ (LH and early LX are the same as HQ/HJ) (plus the modified HQ one for LH L34 engine);
Late (exhaust heated): HX/early HZ and late HZ/VB. Late LX is the same as HX/early HZ with the barrels down each head face (as opposed to flat in this area).
#3 _DrFegg_
Posted 18 March 2009 - 06:19 PM
I believe the car to be late 1976 as it has standard pollution gear (i.e cannister etc) I take it that particular ADR is in relation to the addition of the pollution gear? So if its a late 76 car it will have an exhaust heated manifold. Are there any particular numbers relating to this, or can somebody supply a photo of one so I can identify the difference visually.
Ta.
Posted 18 March 2009 - 06:51 PM
#5 _DrFegg_
Posted 18 March 2009 - 07:12 PM
Posted 18 March 2009 - 07:44 PM
here are a couple of pics I hope help. The first few are an ADR 27A manifold, the second batch are the non ADR27A manifold, which is the type you want. Sorry the second batch of pics are not great, but you should be able to note on the ADR27A manifold the provision for the pipes from the manifold to the auto choke on the carby, the large lump on the front drivers side, and the long sausage like pieces down each side. You'll see on the early type manifold a flat plate at the front drivers side near the carby with 2 bolts, and on the passenger side a fitting with a rubber plug because is'a a water heated manifold.
ADR27A
ADR27
#7 _DrFegg_
Posted 18 March 2009 - 07:56 PM
Posted 18 March 2009 - 08:14 PM
Posted 19 March 2009 - 05:10 AM
Posted 19 March 2009 - 07:02 AM
The change-point is 1/7/76. So if the compliance plate has ADR27 on it, it should be dated 6-76 or earlier. If the plate has ADR27A on it, it should be dated 7-76 or later. The early LX 5.0-litre V8s are same as LH & HJ. The later LX 5.0-litre V8s are the same as HX. The early type canister is the same from 1-75 to 6-76. As yel327 has mentioned, the canister was altered slightly at the time of the ADR27A engine changes.
Dr Terry.
Posted 19 March 2009 - 11:07 AM
Posted 19 March 2009 - 01:45 PM
#13 _DrFegg_
Posted 20 March 2009 - 07:48 AM
regards to all.
Drfegg
p.s if anyone happens to see one around,hear of one ,please let me know. Ta.
#14 _DrFegg_
Posted 03 June 2009 - 09:35 PM
Id like to clarify a couple of points in my search for a manifold with the part number 9929854 (not found one anywhere!) IS the inlet manifold with the part number 9929853 the same?( I have found plenty of these) If not what differences are there? I believe i need the same manifold off an LH L31 (as mine is an early LX , non ADR27A) but one of the members here has told me his LH L31 ,74 had a 9929853 part on his car. He also had heard that its not uncommon for the last digit of the casting numbers to be different. Could this be correct? Can i just use a 9929853 manifold? Any help would be greatly appreciated as ive only got the photos that red posted on this thread , to go by.
#15 _MR & MRS L34_
Posted 07 June 2009 - 10:53 AM
Posted 07 June 2009 - 12:22 PM
Does anyone have a manifold with 9929854 cast on it??
The following is a quote out of this thread which further illustrates differences between part and casting numbers.
http://www.gmh-toran...php?showforum=6
I think you will find that those numbers are 'casting numbers' as none of the numbers appear in the Parts Catalogue. The bearing cap numbers are the same as on my NP motor. The bearing caps were common to all 202 engines.
The piston number is again a casting number but it differs to any in the thread below:
Posted 07 June 2009 - 02:29 PM
Posted 07 June 2009 - 04:41 PM
The casting numbes on GM alloy parts are often one digit different to the part number.
#19 _DrFegg_
Posted 08 June 2009 - 12:44 PM
Posted 08 June 2009 - 01:55 PM
#21
Posted 08 June 2009 - 03:16 PM
Dr Fegg, all pre ADR27A manifolds are basically the same except for the heater hose threaded hole to the LH side of the thermostat on HT-HG examples. The photo you posted up earlier is a HQ style manifold by the look of it which is what a pre ADR27A Torana would have fitted.
#22 _turbovlcalais_
Posted 30 October 2013 - 06:15 PM
hi ive got a inlet manifold with the part number 9929853 and my torana is a 5/76 is this the correct manifold for my motor
Edited by turbovlcalais, 30 October 2013 - 06:17 PM.
