Yep, one more UC with a SBC project !!!
476 replies to this topic
#326 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 13 May 2012 - 10:40 PM
Awesome Struggler, can you get Yella doing sub-11's as well?
Anythings possible with cubic dollars ! :D
#327 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 23 May 2012 - 07:41 PM
I have spent a bit of time lately tidying up the interior. New door trims (easy to clean buckskin vinyl), handles, window winders, pinchweld and kick panels. I had to take it all out last week to weld a bracket on the floor.
First another disclaimer....... modifications shown here are for use in a vehicle that will never see use on public roads. I can't recommend
you try this at home on your road registered vehicle.
The Andra tech inspection highlighted the fact I only had front brakes. I had always intended to fit the rears one day, just never got around to it. The car pulled up fine at WSID from 133 MPH so I wasn't too concerned. My front brakes are operated by a short stroke, low volume, single circuit master cylinder. It doesn't have the fluid displacement required to activate rear brakes. I wasn't really keen on swapping master cylinders to a dual circuit unit so decided to operate the rears independantly. I built a hand operated brake lever (basically a hydraulic handbrake) using an identical master cylinder as the front. I found an old Commodore handbrake lever and modified it to activate a pushrod and built the rest to suit from scrap steel. I haven't tested it yet (no rear calipers) but moving the lever through 60 degrees will move the piston through its full stroke. It should work fine. Now if one system fails I still have a back-up to pull me up.
Here are a couple of pics......
Attached File  P1020536.JPG   125.77K   2 downloads
Attached File  P1020537.JPG   120.67K   3 downloads
Attached File  P1020538.JPG   113.39K   2 downloads
Attached File  P1020539.JPG   108.23K   3 downloads
#328 _greenmachine215_
_greenmachine215_
Posted 23 May 2012 - 10:48 PM
Nice rear brake setup, when I read that you pull up a 10sec car on front brakes only I thought to myself Ive done some pretty sketchy shit but frOck that lol
Why don't you fit a tandem master with a line locker, that way you got piece of mind, and the best of both worlds,
By the way that interior gives the car a real innocent granny look, I love it
#329 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 06 June 2012 - 07:26 AM
...Why don't you fit a tandem master with a line locker, that way you got piece of mind, and the best of both worlds...
I will probably get around to fitting a dual circuit setup in the future but if I do it will need to be under the dash so I will have to do some serious planning before then.
By the way that interior gives the car a real innocent granny look, I love it !
Thanks.
Rear brakes are all in and operational.
Spent a couple of days at the painters last week cutting out some fluff and stuff from the paint and buffing some other bits. Had to do a couple of touchups as well where I dropped stuff onto the fresh paint. It really looks great now, far better than I ever envisaged.
Still need to get myself a race suit and some roll cage padding but as soon as that is done I'm back to the track !
Edited by Struggler, 06 June 2012 - 07:26 AM.
#330 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 01 July 2012 - 09:25 PM
In the last month I got myself a race suit and various other odds and ends required to run in the 10's.
Today I got it up to WSID to have a few runs at the test n tune.
Ran a base line pass first up.... 10.07.
Adjusted the 1-2 shift light up to 7K, gained 3 hundreths.
Changed rear springs to softer, taller units, lost 6 hundreths (all in the 60', pity, as it drove a lot nicer).
Tried to give it more timing, slowed down another 4 hundreths but didn't lose any MPH !
Put the old springs back in, wound the timing back to 34 degrees and took off the exhaust resonators.... 9.991 !
Did another pass to back it up, 10.005.
Put it back on the trailer and came home a happy man !
I have a small hesitation on the line that needs investigation that may net a few hundreths. Will whip the carby off and have a look in the next week or 2 to see what thats about.
Hope to have some pics and possibly a video in the next couple of days.
#331 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 01 July 2012 - 09:38 PM
Here is a link to a Youtube vid a mate just uploaded.....
#332 _Bomber Watson_
Posted 01 July 2012 - 09:47 PM
Thats frOcking awesome Struggler.
#333 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 01 July 2012 - 09:52 PM
Awesome, congratulations
#334 LXCHEV
LXCHEV
  • 3,610 posts
  • Car:'76 LX - 383 Chev
Posted 01 July 2012 - 09:55 PM
MASSIVE WELL DONE MATE :)
#335 _LJ355_
_LJ355_
Posted 02 July 2012 - 08:03 AM
Well done mate cant wait to get back out with my new setup
#336 _ass308_
_ass308_
Posted 02 July 2012 - 08:12 AM
nice work struggler
#337 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 02 July 2012 - 09:33 AM
Thanks guys, a nine sec pass is definately a milestone.
Here are a couple more vids my mate took....
Edited by Struggler, 02 July 2012 - 09:35 AM.
#338 Tiny
Tiny
  • 10,018 posts
  • Name:Tiny
Posted 02 July 2012 - 10:18 AM
Holy crap mate!
Well done to you!!
It looks so nice and calm coming off the line, very very nice!
#339 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 02 July 2012 - 11:55 AM
And one of a 10.1 pass.. http://www.youtube.c...=1&feature=plcp
#340 fatslr
fatslr
  • 1,247 posts
  • Name:Garth
Posted 02 July 2012 - 04:54 PM
Man that has got to be the best UC in the world great work Struggler
#341 mr5000
mr5000
    chief break-everything
  • 3,455 posts
  • Car:77 lx 4door
Posted 02 July 2012 - 05:23 PM
that is awesome well done mate
#342 _berro59_
_berro59_
Posted 02 July 2012 - 10:44 PM
That is quick!
You have got to be stoked. Well done!
#343 _greenmachine215_
_greenmachine215_
Posted 02 July 2012 - 11:09 PM
10.1 is stupidly quick what the hell was that kinger runnin?
I love your car mate, awesome to finally see it in action
#344 warrenm
warrenm
  • 2,117 posts
  • Car:1972 LJ Torana
Posted 03 July 2012 - 08:02 AM
Well done, looks good off the line. Looks like it must be easy to drive, your able to check a few emails, check out the http://www.gmh-torana.com.au site while your driving. :spoton:
#345 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 03 July 2012 - 07:02 PM
Thanks, maybe not the best but I'd like to think its not too bad !
Thanks mate !
That is quick!
Thanks, yes, very happy with its performance so far.
#346 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 03 July 2012 - 07:07 PM
Thanks ! The Kingswood has some huge blown or turbo engine in it, ran 8.8 at 151mph on that pass ! Was quite tidy too but very much a light weight.
Thanks mate ! The car does drive very nicely, smooth off the line and as straight as down the track.
Once I have done the burnout I hit the START icon on the laptop to log the pass. No time for emails ! Officials were quite impressed with the laptop stand and security.
Edited by Struggler, 03 July 2012 - 07:10 PM.
#347 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 06 July 2012 - 08:49 AM
I have been set straight on the Kingswood.
It is not a big engine, or a blown one !
It has a 412 CI SBC with SB2.2 heads. The engine was built here in the ACT and was actually in a mates VL Calais (the Beauchamp VL) running 8.7 odd ets and it weighed less than 3000lb.
It is obviously well set up and to run those numbers is a real achievement !
#348 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 09 July 2012 - 11:12 AM
Here is a pic of the Kingswood in question... Posted Image
And a couple of my UC..... Posted ImagePosted Image
Pics courtesy of cacklingpipes.com.
#349 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 26 November 2012 - 02:03 PM
Time flies when your having fun ! Its been almost 5 months since the last update and a heap has happened.
Unfortunately during this time I had a bit of a health scare and had to back off on a few things. Fortunately I'm back together now and getting back to speed.
I have also been busy with customer engines and have a couple of builds and dyno results I might share in another thread. I have found some time though to get back to the track recently.
I did quite a bit of work on the carby, my 830 annular discharge, that has served me well to date. The car had a lean spot just off launch that I couldn't tune around. I tried bigger jets, pump shooters etc, even an 850 base but nothing could get rid of the flat spot that would see the car leave the line, dip down momentarily, then accelerate away. The car also seemed to be slowing slightly, a couple of MPH and about a tenth initially. In desperation I decided to give it a few runs on alcohol and see how that would go. I ran a couple of BP98 fuelled passes in the low tens then drained the tank, added 20L of Methanol and swapped the carb to my 950 Alky Holley. Well that woke it up ! No flat spot off the line and felt heaps faster. Fastest times to half track yet by a tenth and a couple of MPH but slowed in the top end to run 9.928 at 133. I ran it again to check......9.928 at 133 ! Talk about the consistancy of running on alcohol !
Next meeting I stuck with the petrol and the car was now running 10.2's at 129 so I knew I had a problem. All the loss was from the 330' on so I started looking at fuel pressure. Seems there was a problem there somewhere so I pulled the tank and lines out expecting a blockage but it was all pretty good. Fuel pressure at idle now was erratic and I decided to pull the pump off. Unfortunately it appears the fuel pump pushrod and roller cam have had an altercation and the pushrod is mushroomed over. I tried getting it out of the block with vice grips and a slide hammer but to no avail. Looks like the engine will be coming out for some repairs and a cleanout. I have dropped the oil and cut the filter open and aside from a whole lot of bronze from the pushrod tip it looks pretty clear. Hopefully I didn't wear it down to the hardened steel as that stuff will mess bearings and cranks up badly.
As for the carb flat spot, after consulting with a few experts it appears I may have outgrown this carb. The size of the engine isn't compatible with the small venturi annular discharge booster and it looks like I need to revert back to the traditional down leg style in order to overcome the issue. I should be able to borrow an 850 and if this does indeed fix the problem I'll get the boosters swapped over in my carby.
As luck would have it I have been assembling a low-buck 350 to have some fun with at Summernats so I have another engine almost ready to go in. Its no real grunter but should push the car into the 11's. More details on that one later.
I also found time about a month ago to allow Paul Beck from Performance Street Car magazine to take a few pics of the car and run a feature in his magazine. The magazine should be in newsagents later this week so keep an eye out (it has a pic of Gary Myers new Mustang on the cover) . Here is a pic or 2 I took at the photo shoot......
Attached File  P1020666.JPG   107.99K   5 downloads
Attached File  P1020668.JPG   75.21K   4 downloads
The pics were taken right on twilight and used a long exposure to get good colour saturation so I'm hoping they should come out well.
I'll post some more details of the other engine later this week, stay tuned !
#350 _Duncs_
_Duncs_
Posted 27 November 2012 - 01:41 PM
very nice and tough little car! Alcohol is good shit :)
