I did very little panel work before getting it blasted and I am glad I didn't. It seems the stress relieving qualities of the bead blast is very good at shrinking metal slightly. This was very handy as a few dents in the roof have been substantially reduced and a couple of shrinks I was planning on doing are no longer required !! Overall the car is in great shape. No previous repairs at all, a few pin holes of rust in the screen recesses and one hole about the size of a match head under the drivers rear scuff plate. Take that UC haters !!!
Anyway I carted it off to a friends panel and paint business and spent a full day cleaning it out, repairing a few minor blemishes and fully removing all traces of paint, seam sealer and primer from the outside of the car with a wire brush in the end of a drill. I then rolled it into the booth and watched while it got a good coat of 2K etch and a few coats of 2K High Fill. An hour later I loaded it back up and took it home. I now have to grind some of the primer out and perform a few repairs before taking it back for some more High Fill. Here are a few more pics of it once I got it back home.....
It looks pretty good in the pics with the matt yellow primer but it still needs a bit of bog wiped over it. There is no shortage of minor dings to attend to and the engine bay needs some filler too. No point dribbling about it, I better hook in !!
