Engine breathing question..
_draglc_
Posted 14 March 2006 - 08:47 AM
My new engine (done about 700kms) is breathing heavily out the breathers on the rocker cover and im a little concerned.
Until yesterday ive had a breather cap in one hole and a pcv valve with a rubber hose going into the manifold. No oil was coming out. Though when i take the pcv off, and put 2 breathers on, oil pisses out both. So that means that the pcv was sucking the oil through. Obviously i dont want to be burning oil so id like to avoid using that setup.
Its a brand new engine, that has been run in properly. The only thing i can think of is that the rocker cover is too short, and the rocker rollers are pushing the oil straight out..? I have a taller rocker cover at home i will try this afternoon.
Can you guys please let me know how youve set yours up? Whats the best setup for breathing on a 202?
Thanks,
A1
Posted 14 March 2006 - 11:07 AM
Will this setup be very effective?
Les
_draglc_
Posted 14 March 2006 - 01:11 PM
Im still hoping that a taller rocker cover will fix the problem.
A1
_Jewboy_
Posted 14 March 2006 - 01:17 PM
_draglc_
Posted 14 March 2006 - 01:26 PM
A1
Posted 14 March 2006 - 01:29 PM
If it is 2 hole you should have a breather style cap and the pcv or 'hockey stick" draft tube.
If you have the 3 hole style you should have a closed cap, a breather tube to the air cleaner and a pcv.
Posted 14 March 2006 - 02:06 PM
I see you've only done 700km's so far. I thought this should be plenty, but perhaps get another few hundred km's clocked up and see if it settles down. If you want to get really keen, perform a leak-down test on the engine - this will show you the true indication of the condition of your rings/valves etc.
_Dirty Deeds_
Posted 14 March 2006 - 02:34 PM
Im running modified (tall) rocker covers on old style heads.
By modified I mean that I have 1 K & N filter on each bank.
My engine is a heavy breather and I have been told that this is due to my exhaust system being inadequate. The engine is burning the gases but the exhaust is not disposing them properly.
My exhaust is Pacemaker extractors ( 4 into 1 ) into 2.5 inch pipe all the way through. I also run 4 standard ( walker ) mufflers.
Im not worried about the blow-by, I guess you get used to it after a while.
_jap-xu1_
Posted 14 March 2006 - 03:04 PM
dont tell me you babied it
_Yella SLuR_
Posted 14 March 2006 - 03:19 PM
Edited by Yella SLuR, 14 March 2006 - 03:20 PM.
_wildsix_
Posted 14 March 2006 - 03:43 PM
It had roller rockers and a tall baffled valve cvr. It would suck up 1/2ltr in 30km.
It was suffering from blow by, and too much oil being pumped up into the head, with it not draining back quick enough.
If its a new motor, did you install the rings correctly?
_draglc_
Posted 14 March 2006 - 06:24 PM
So i put the pcv valve back in it, and the other end back in the manifold, with just the one breather, and not one bit of oil comes out.
Turns out the rocker cover i have at home is the same size :S
Could it also be oil pressure? Mines not a HV pump, but as soon as the engine starts, the guage goes up to over 80, the max on the oil gauge. Its not an electrical fault, it will only do it when the engine is running.
I also did a compression test on it today at work, got between 170 and 180psi in each cylinder. That was dry test too, i ran it for a few mins before i did it.
I guess what im getting at, is that im sure the engine is healthy, i think its just a combination of high oil pressure and low rocker cover thats allowing oil to spill out the rocker cover. Its annoying though that its getting sucked back into the manifold to be burnt, so while i dont have blowby, its still burning oil...
Suggestions? Comments?
A1
_coupe202_
Posted 14 March 2006 - 06:37 PM
_draglc_
Posted 14 March 2006 - 07:46 PM
_1QUICK LJ_
Posted 14 March 2006 - 08:01 PM
dont be scared to give it a hard time its better for it than to drive like a grandma
Posted 14 March 2006 - 08:04 PM
_Yella SLuR_
Posted 14 March 2006 - 08:09 PM
_draglc_
Posted 14 March 2006 - 08:25 PM
the engine has not been babied, ive loaded it up mountains, and raced up and down mt nebo and mt glorious (brisbane), it has been run in properly!
A1
Edited by draglc, 14 March 2006 - 08:26 PM.
Posted 14 March 2006 - 10:05 PM
_SSHatch_
Posted 14 March 2006 - 10:45 PM
I have a 350 Chev in the Hatch. Has always been a heavy breathing engine. Always blowing oil out the breathers before I blew it up and still does it after rebuild.
Engine now has over 10,000klm on it and still pumps oil out when given a thrashing. It gets extremely bad when revved hard and on a long run in the country.
A mate following me the other day actually commented on the blue smoke billowing from under the car on the hwy.
I have been chasing an answer to this problem since I built the engine twelve months ago. Everybody simply suggests to put a catch can on it. This is fine but will only hide the problem and not cure it.
Any suggestions as to what may be causing it.
I am going to try a leakdown test in the next week or so but dont reckon this is the problem as the engine has always done it.
Cheers,
PJ
#21
_1QUICK LJ_
Posted 14 March 2006 - 11:04 PM
alot of cheap rocker covers dont have very good baffle designs.i would be suprised if the rocker cover is filling up that much with a std pump unless theres a restriction on the oil return holes somewhere , i would say its more than likely the baffle design which is allowing oil to come out with the crankcase pressure, some rings take a couple of thousand ks to bed in properly if they are hard such as chrome face sets.
most people stay away from chrome rings for this reason and they are hard on the bore no need for them really except very dusty conditions.
if it doesnt settle down then theres another problem such as piston clearances or ring gaps.
#22
Posted 14 March 2006 - 11:05 PM
Like the avatar PJ, hehe
Les
#23
_Keithy's_UC_
Posted 15 March 2006 - 03:16 AM
Look in the trading post as they retail for $175 new...
From this:
To this:
Keith
#24
_draglc_
Posted 15 March 2006 - 07:13 AM
A1
#25
Posted 15 March 2006 - 03:01 PM
Pretty Smick looking donk you got there Keithy, good job.
Les
