What pedals are these?
#1 _Patrick_
Posted 05 April 2009 - 04:52 PM
Seems my Torana project has hit the wall, everything is being sold off. :(
Im hoping to find out what model these pedals are from, just in case they are worth something to someones conversion as i seem to recall certain manual pedal setups can be worth a bit.
Cheers,
Pat
#2 _Roadknight_
Posted 05 April 2009 - 06:33 PM
#3 _HQ SS_
Posted 05 April 2009 - 11:30 PM
If you have a look here
http://gallery.oldho...SS/Tech/Pedals/
Opps I just realized that I have not put a picture of a HQ-J manual brake peddle there yet.
But there is a clutch peddle picture there.
Cheers Paul.
Posted 06 April 2009 - 12:18 AM
#5 _ozbox_
Posted 06 April 2009 - 06:37 PM
also save me doing another post to hq ss..the 3rd clutch pedal you have listed is a hz/wb 6 cylinder pull type..v8 is a different pedal again..im not sure you knew that so i thought i would tell you...im not trying to be smart....cheers greg
Posted 06 April 2009 - 08:51 PM
Not sure on the pedals from the original post. Can only be LH/LX 6cyl or HQ/HJ with rat-trap. My original thought was HQ/HJ.
#7 _HQ SS_
Posted 07 April 2009 - 01:17 AM
This is a HQ set up.
Greg I do not mind being told new information at all. I knew there was a difference between 6 and 8 pull cable peddles as they have different part number in the parts book but what the difference was I did not know.
So from what is posted above a V8 peddle is shorter in over all length to a 6cyl peddle in the HZ and WB type.
If this is correct as this
is a picture I just took showing the three peddles on a long bolt to show there lengths and the pull one is shorter than the other two.
Now I am really confessed.
Cheers Paul.
#8 _ozbox_
Posted 07 April 2009 - 05:03 PM
Posted 07 April 2009 - 05:27 PM
The above is why the WB 6cyl pedal in the photo is shorter than the HX/HZ type as the HX/HZ one pivots using the same hole as the WB V8.
(I've purposely called the full cable WB and the half cable HX/HZ to avoid confusion. Late HZ is actually the same as WB).
I'm not sure why the HQ/J one you have there is longer than the HZ pedal as HQ/J use the same pivot hole as HZ and V8 WB. When I get time i'll have a look at all the pedals I have at home. Maybe the HQ has a longer brake pedal but I was certain they were the same length as HZ/WB.
#10 _HQ SS_
Posted 07 April 2009 - 10:39 PM
Thanks for the reply Yel327.
I still am a little bit confused as I have fitted the clutch peddle out of my V8 HZ ute in my SS to fit a 5spd conversion which use's a pull cable set up.
But that is in the lower hole on the HQ and the peddle is too short compared to the std one.
Here is a picture of the set up in the HQ.
But I have another two peddles that look and measure up as being the same one is out of car and one has been refitted in to my HZ ute and now looking at it, it is a little bit to low as shown in this picture.
So if this is a 6cyl peddle and it should be in the top hole it will sit even or a little bit higher than the brake peddle I would guess.
Which would be right.
But if the V8 peddle is shorter that the 6cyl peddle would that account for the miss alignment in my HQ.
I measured the peddles and all three measure the same as in this picture.
So is that correct for a 6 or a 8 peddle or am I doing it all wrong.
If anyone has a picture of a V8 peddle I sure would like to see what the actual difference is.
Thanks for you patience Paul.
Edited by HQ SS, 07 April 2009 - 10:40 PM.
#11 _ozbox_
Posted 07 April 2009 - 11:07 PM
#12 _HQ SS_
Posted 08 April 2009 - 12:11 AM
The peddle in this last picture is the same peddle that I had in the picture of the three types in my shed at oldholden.
That is why I am trying to sort out what is what.
The one at the top looks to be the same as my HQ peddles that why I said it was a HQ/J type.
I'm so confused.
Paul.
Posted 08 April 2009 - 05:51 AM
I probably won't get a chance to get all my pedals out and suss it out until next week.
Byron
#14 _HQ SS_
Posted 08 April 2009 - 08:05 PM
No rush at all, it all works alright in the HQ it just looks a bit strange thats all.
Cheers Paul.
