NEW MR5000 Build Thread
306 replies to this topic
#276 LXCHEV
LXCHEV
  • 3,608 posts
  • Car:'76 LX - 383 Chev
Posted 16 January 2020 - 08:37 AM
Awesome!
#277 mr5000
mr5000
    chief break-everything
  • 3,455 posts
  • Car:77 lx 4door
Posted 16 January 2020 - 02:51 PM
I’ll put some pics up later but I also managed to score a motec data logger dash have started to play with it still bubbling my way around using it can’t get the af sensor to work properly unsure if it’s a faulty sensor or if ive wired it wrong great bit of kit though looking through data after a run
#278 mr5000
mr5000
  • 3,455 posts
  • Car:77 lx 4door
Posted 16 January 2020 - 02:55 PM
Other new additions include a gz motorsports vacuum pump
Also now run a aeroflow vacuum pump kit for the brake booster which I highly recommend for any one struggling with brake vacuum it’s not to loud but keeps great pedal feel even after multiple hard braking at a motorkhana day
#279 mr5000
mr5000
  • 3,455 posts
  • Car:77 lx 4door
Posted 16 January 2020 - 03:52 PM
Here’s a picture of the dash when I fire bought it testing
#280 mr5000
mr5000
  • 3,455 posts
  • Car:77 lx 4door
Posted 14 November 2020 - 07:53 AM
Haven’t done any real progress on the car of lAte but have got a new home for the car bought a place and decided to give the garage a floor coating before I moved in it had a crappy epoxy on it already but lifted in parts and was becoming porous I used rustoleum rock solid after doing heaps of research and watching videos pretty happy with it went down easy prep work is key like all painting. makes cleaning up mess super easy also the decorative chips help hide the shittyness of the concrete
Used rustoleum primer first before laying down the coating unless the concrete is perfectly flat you end up using bit over double what rustoleum say the product will cover 8e7620044d7d1f7b94ae4e44fe47299c.jpg
#281 Holdenbn74
Holdenbn74
  • 150 posts
  • Name:Brendan Nichol
  • Car:LH
Posted 14 November 2020 - 10:26 AM
Great idea, looks good too
#282 rodomo
  • 18,037 posts
Posted 14 November 2020 - 11:00 PM
Well done Ryan  :spoton:
#283 mr5000
mr5000
  • 3,455 posts
  • Car:77 lx 4door
Posted 15 November 2020 - 07:37 PM
Bit more of a close up personally a big fan of decorative chips hides a lot of stuff
#284 Peter UC
Peter UC
  • 770 posts
Posted 15 November 2020 - 08:01 PM
Nice, hopefully those decorative chips don’t hide bolts when you drop them on the ground
#285 mr5000
mr5000
  • 3,455 posts
  • Car:77 lx 4door
Posted 17 November 2020 - 07:46 PM
Haven’t had a chance to do any real work on it yet so time will tell if it makes things harder to spot
#286 LXCHEV
LXCHEV
  • 3,608 posts
Posted 17 November 2020 - 10:26 PM
Looks excellent Ryan - huge improvement! Now we need a photo with the mighty Torana too :)
#287 mr5000
mr5000
  • 3,455 posts
  • Car:77 lx 4door
Posted 19 November 2020 - 07:41 PM
As requested by Shubes excuse the mess still working on storage solutions and need to get onto the electrical in the shed previous work was very much a blind handyman effort
#288 rodomo
  • 18,037 posts
Posted 19 November 2020 - 09:08 PM
Better than your old carport and tarps mate :spoton:
#289 LXCHEV
LXCHEV
  • 3,608 posts
Posted 19 November 2020 - 09:41 PM
Excellent! Aaaaaand... it's full!
#290 Rockoz
Rockoz
  • 4,030 posts
  • Name:Rob
Posted 20 November 2020 - 08:19 AM
Run 16mm2 wires to the shed from the box.
It may sound like overkill, but it wont be a whole lot more expensive than the 6mm2 that most would be okay with.
It ensures the voltage drop isnt much, and you will be able to do a lot without it tripping the breaker at the board.
LED strip lights, which are the new fluoro replacement are about 70 to 80 bucks each froma wholesaler.
You can change their brightness and white intensity as well if you choose to.
Apart from that, lots of power points and a dedicated circuit for a welder.
Rob
#291 ReplicarSLR
ReplicarSLR
  • 518 posts
  • Car:Not anymore unfortunately
Posted 20 November 2020 - 03:36 PM
Rob
Yep agree do as Rob said, did my shed that way, do it right once and you’ll never look back. Sub board in the shed with lots of double outlets and a dedicated 15A outlet with a slow trip breaker on it for air compressor or welder.
#292 mr5000
mr5000
  • 3,455 posts
  • Car:77 lx 4door
Posted 22 November 2020 - 09:45 PM
Rob
Yep that’s pretty much what my sparky mate has planned aswell as overhauling the house power and switchboard
#293 mr5000
mr5000
  • 3,455 posts
  • Car:77 lx 4door
Posted 08 December 2020 - 07:51 PM
New dash arrived the other day from
Mako Motorsport to suit the data logger bit dissapointed they wouldn’t include the fan outlet or the ash tray but tbh I’ve never used either anyway should make the motec dash sit nice and neat instead of the cable ties that are currently holding it in place
#294 Heath
  • 18,385 posts
Posted 14 December 2020 - 08:26 AM
Sorry, are you going to cut a hole so the barrel vent is still present on the RHS on the dash?
#295 mr5000
mr5000
  • 3,455 posts
  • Car:77 lx 4door
Posted 16 December 2020 - 05:59 PM
Undecided on that yet if I can make it neat I will but otherwise not planning too I can’t say I’ve ever really used the fan in the car but I do prefer it visually to be there
#296 Heath
  • 18,385 posts
Posted 16 December 2020 - 11:32 PM
Keep in mind that barrel vent is not connected to the heater box or fan, it's just a direct feed from the plenum.
If you aren't using it, you should start driving your car more. Getting rid of ventilation has no benefit, and it certainly is a compromise... Visually and functionally.
Sent from my Pixel 4 XL using Tapatalk
#297 LXCHEV
LXCHEV
  • 3,608 posts
Posted 24 December 2020 - 08:52 PM
Was awesome to get out cruising last night mate - your beast sounds unreal. What's the details on the exhaust system?
Attached File  Ryan MR5000.jpg   123.74K   32 downloads
#298 mr5000
mr5000
  • 3,455 posts
  • Car:77 lx 4door
Posted 06 January 2021 - 09:52 PM
Extractors are custom 1 7/8 stainless 4 into 1s with merge collectors then it’s 3 inch all the way through with hooker aero chambers on it believe it or not it’s quieter now with the tail pipes initially had it dumped at the diff was a bit much
#299 mr5000
mr5000
  • 3,455 posts
  • Car:77 lx 4door
Posted 17 January 2021 - 12:36 PM
Been running Viking double adjustable shocks for about a year now but was never happy with how close they got to the caliper s for the rear disc so decided to have a crack at relocating the shock pick up point 937b69bfc08dacac00db609cf7056d0a.jpg
Edited by mr5000, 17 January 2021 - 12:43 PM.
#300 mr5000
mr5000
  • 3,455 posts
  • Car:77 lx 4door
Posted 28 January 2024 - 07:14 PM
So the cars currently eaten another starter motor had cvr unit break a circlip taking out another flex plate in the process so
While off the road this time have finally gotten into upgrading the brakes to something a bit more modern
After hunting around and trying to be budget conscious I’ve gone for some au calipers with bf falcon discs using adaptor kit from planet parts
Bought a jig to drill from ford to hq pattern
Still waiting on last bits to put the trans back in
Have a motorkhana booked in for April will be keen to put the set up to the test 0bfef523d7aa0b51b51e28567e823e20.jpg
