186 versus 202 power potential difference .
Posted 15 April 2009 - 06:01 PM
new jzed head and 1.7 rockers ,
roller cam and lifters ,
triple 48mm webers
custom longer rods ,
lightened and wedged 202 fully counterweighted crank .....weighs 23kgs instead of the usual 28 kgs .
Custom pistons will be needed for the longer rods whichever engine l use
l also have a brand new , never been used 186 block still fitted with a new steel crank from the factory which l've been looking at and wondering about using instead of a 202 . . My question is , how much ( if any ) potential horsepower would l be giving away if l were to use the 186 as the basis for the new engine instead of a 202 . The 186 perhaps has more rev potential than the 202 .
Thanks for any ideas here .
#2 _gmlj6_
Posted 15 April 2009 - 06:06 PM
Posted 15 April 2009 - 06:45 PM
The 186 engine got a 3rd place one year & a 4th place the next (1970 & 71).
The 202 got a 1st place in front an XY GT-HO Phase III & almost did same, the next year (1972 & 73).
Nuff said !!
Dr Terry
#4 _NZ Toranaman_
Posted 15 April 2009 - 07:28 PM
In my 202 the car is noticably slower with a passenger, the 186 is good in a light car but add hills and/or additional people and it slows more than the 202. V8's hardly notice a 2nd person so I hope this gives a good reason to use a 202 over the 186.
Graham
Posted 15 April 2009 - 08:07 PM
The 179 got one 2nd place at Bathurst (1963).
Nuff said !!
Dr Terry
The Xu1's in 72 had that great equaliser called * rain * helping them out that year . Big ugly heavy HO's just couldn't get all that 400 hp down to the ground because it was so slippery . Was indeed a shame that they didn't pull it off in 73 , they certainly deserved to win . The lc 186 finished on the same lap as the HO's in 71 didn't they ?
#6 _gtrtorana_
Posted 15 April 2009 - 08:57 PM
Deep down you know what is the right engine. All I can say is it is great you are keeping it a 6, not going the boring V8 option for more power.In my 202 the car is noticably slower with a passenger, the 186 is good in a light car but add hills and/or additional people and it slows more than the 202. V8's hardly notice a 2nd person so I hope this gives a good reason to use a 202 over the 186.
Posted 15 April 2009 - 09:26 PM
When the 202 first came out, they were notorious for breaking pistons.
They would break the crown off.
The "old schoolers" were quick to can the 202 and it was common to hear "the 186 is a far better engine" and, of course, tell all their mates.
It didn't take long for Holden to sort out the problem but the damage was done and the stigma hung around for years.
No contest IMHO.
#8 _Pro_
Posted 16 April 2009 - 12:14 AM
a blue 202 will pump out more power than a red 186 because revs x torque = horsepower.
revs = same-ish stock, same modified.
torque = more
therefore
power = more.
Posted 16 April 2009 - 12:46 AM
who cares what happened 35 years ago?
Obviously not you but others might?
#10 _1QUICK LJ_
Posted 16 April 2009 - 01:39 AM
#11 _NZ Toranaman_
Posted 16 April 2009 - 05:07 AM
why are you using a longer rod?
Longer rods reduce the angle and therefore allow more revs and power throughout the entire rev range.
Posted 16 April 2009 - 10:19 AM
Posted 16 April 2009 - 10:40 AM
#14 _markbeath_
Posted 16 April 2009 - 11:12 AM
Bit of a story for the younger members:
No contest IMHO.
My dad who is a mechanic and has been for most of his 60yrs always said "the 186 was the greatest motor made". I say its because he had a 186 in a HD Holden which was his first and most loved car but he says was because easiest motor to work on, hardly broke and when it did, did not take long to fix.
#15 _tyre fryer_
Posted 16 April 2009 - 01:34 PM
The same can be said for 202s...
Posted 16 April 2009 - 01:52 PM
Posted 16 April 2009 - 02:36 PM
Everybody knows that for a street engine stroking it is the way to go. Hence 304/308 gets stroked to 350 cubes. 327 and 350 Chevs get stroked using a 3.75" stroke (377 cubes). 302C gets stroked to 351. And 186 gets stroked to 202 or bigger. It's just slightly different in that you don't bother with a 186 block when stroking to 202 because it's cheaper and easier to just use a 202 block.
l wasn't considering using the 186 block and making it a 202 . Because it's new /unused and with a new steel crank as well l was thinking that it was a good basis for a strong engine with having a virgin bore so it would have maximum block stiffness .
#18 _Pro_
Posted 16 April 2009 - 03:19 PM
Posted 16 April 2009 - 04:15 PM
#20 _NZ Toranaman_
Posted 16 April 2009 - 04:17 PM
#21 _threeblindmice_
Posted 16 April 2009 - 04:20 PM
#22 _bon_scott_
Posted 16 April 2009 - 08:29 PM
#23
Posted 16 April 2009 - 08:59 PM
Back in the day 202's had a bad rep for fuel consumption too....Holden only advertised HP figures and as far as the public knew there was 7 HP difference between a 186 (130 HP) and a 202 (137 HP)....also alot of the the cars 186's came in were lighter...I know that a 186S HT Monaro goes against what I am saying...but i'll back a 186 powered HR or LC versus a HQ 202 anyday.
#24 _Bomber Watson_
Posted 16 April 2009 - 09:12 PM
Up the mighty Two O's.
#25 _gtr161s_
Posted 16 April 2009 - 09:22 PM
I would have thought a lightened flywheel would more suit racing at constant high revs thus retaining power but in a street situation you can't drive it a max revs all the time so you would loose the torque advantage of the heavier flywheel
Why not try a turbo...they go like a scorched cat
4 user(s) are reading this topic
0 members, 4 guests, 0 anonymous users
