Commodore Booster to LH/X Rear Discs
108 replies to this topic
#101 _m_att_
_m_att_
Posted 13 August 2013 - 06:12 AM
Thanks Dattoman. I will use master suggested in the previous posts
#102 _UFO304_
_UFO304_
Posted 28 October 2013 - 04:36 PM
Will the P10037 Master Cyl work with the standard Torana double diaphragm booster?
I'm running commodore calipers on the rear, HZ ones front. Changing the lines are easy, but will it all bolt up and enable me to remove the Proportioning valve off the guard?
#103 dattoman
  • 16,487 posts
Posted 28 October 2013 - 09:30 PM
Nope
P10037 is diagonal mount
#104 _nicko_
_nicko_
Posted 01 March 2014 - 09:39 AM
Sorry but can someone explain how to shorten shaft, do you cut and weld? Doesn't the heat affect/damage any internals?
#105 TUF 308
TUF 308
  • 169 posts
Posted 09 March 2014 - 08:48 AM
Cut and weld yes. I soaked a rag with cold water and placed it around the booster and bottom of the shaft, no problems
#106 _nicko_
_nicko_
Posted 09 March 2014 - 10:27 PM
Thanks tuf 308 just wanted to make sure before I destroy a good booster
#107 Evan
Evan
  • 1,287 posts
Posted 07 August 2014 - 11:01 PM
Sorry to bring this thread back up but i have read it back to front and dont believe anyone has asked.
I'm taking most people are changing over to the commodore boosters because they have a single diaphragm booster to start with and want the dual.
I have a standard Torana Dual diagram brake booster with the P7210 master.
Is there a replacement 1", internally bias master cylinder that will bolt onto my Torana booster?
Evan.
#108 dattoman
  • 16,487 posts
Posted 07 August 2014 - 11:28 PM
Nope
That would be too easy
#109 Evan
Evan
  • 1,287 posts
Posted 08 August 2014 - 09:34 PM
hahahahha, Thanks Datto. Cleared that up for me.
Looks like ill purchase another P7210 as its nearly $100 cheaper than getting Perth brake parts to recon my old one.
Evan.
