u can get away with no cable on a 350,but not a 700r4.
im lead to believe the only difference basicaly,between a 700r4,and a700460le is the computer.700460le gets its throttle
position from the computer,a turbo 700r4 needs the cable,for throttle position.this gives pump presure
i forget exactly why u dont need it for 350.although u dont need it it was still recomended to run it.and 350s can still kick down with vacum advance.a 700r4 has no vacum advance
Yes, that's about it. I believe that on a TH350 the cable is for kickdown only & the vacuum modulator alone controls the pressure. If you disconnect the cable it will not effect upshifts or downshifts, except for the lack of full-throttle kickdown.
The TH700R4 (4L60) on the other hand has no vacuum modulator & relies totally on the cable for TV pressure. If you disconnect the cable on these boxes, they drive like a dog.
4L60-E (VR onwards) is fully electronic, with no cable or modulator.
Dr Terry.
