Also the thermostat housing isnt tapped! so if its original thats how it has always been.
But, if you want to you could swap the thermo housing for tapped one , drill the hole in the pump and run the heater hoses down the RH side.
Mine isnt as original, but there is more than enough hoses and crap on the LH side of engine as is, i prefer it my way for tidyness.
"Your drip problem"
Just thinking
Your AC is an under dash type i think? pic of LH under dash would help.
Is the condensate drain blocked on this unit? should have a drain hose on the bottom of it somewhere? to let the water out.
Edited by LX2DR, 03 May 2009 - 06:01 PM.
