What to do about my 9 inch diff
_mowie_
Posted 09 May 2009 - 03:08 PM
About three years ago i purchased a 9 inch diff housing and two 31 spline axles to suit which came from a small truck apparantly.
A couple of days ago i rang a local company to get it shortened, have torana mounts put on and ends put on to take my vs disk brakes. The guy told me that i would need new axles as the standard ones will be too thick to get past my brakes. All up i got a quote of $1650 if i supply the housing.
What should i do? Change to different brakes, or throw the current axles away and get the new ones, or cut my losses and go for a 10 bolt. I'll be running a fuel injected 400 chev with a turbo 350 behind it.
Any help would be great.
Tom
_kingy_
Posted 09 May 2009 - 03:13 PM
if there really is no way, for those dollars you may as well convert to floaters and keep your brakes.
And find a new diff man...
_mowie_
Posted 09 May 2009 - 03:15 PM
Id change the brakes, but im struggling to see why it cant be made to work.
Thats the thing they are quite reputable.
thanks for your help though.
Tom
_ass308_
Posted 09 May 2009 - 03:22 PM
this is the bracket that holds my skyline caliper to my 9 inch.
i cant see why the hole in the middle couldnt be made big enough to take your axels.
the brakets,stone guards,calipers,reconditioning the calipers cost $1400.and id reckon syline brakes are heaps better than vs ones
_mowie_
Posted 09 May 2009 - 03:28 PM
haveing had vr-vs breaks on my nine inch,i cant see why they wouldnt fit.the guy that did the work stuffed the vr-vs set up,up.so i changed em to skyline breaks
Ive rebuilt my calipers but judging by the size of that hole im pretty sure they would fit through that.
_ass308_
Posted 09 May 2009 - 03:58 PM
the backing plate that holds the hand brake shoe, was between the end of the axle and this 9 inch cap.
it also has a big whole in the middle.all u need to do is enlarge the hole on the plate, that holds the hand brake shoe to take the axle.
i also have the enclosed type bearing.
_Squarepants_
Posted 09 May 2009 - 04:04 PM
I would be getting another opinion from a different shop.
_scottya!_
Posted 10 May 2009 - 08:01 PM
Would definately be getting second opinion.
_mowie_
Posted 10 May 2009 - 08:18 PM
I'll be ringing the differential places listed in street machine. If it is ok with those axles ill just take the housing in and tell them to do it then the axles at a different stage.
Cheers for your help.
Tom
_scottya!_
Posted 10 May 2009 - 08:44 PM
be F100 axles.
Certainly get another opinions.
_mowie_
Posted 11 May 2009 - 12:07 PM
i'm going to call another place just to be sure.
Tom
_scottya!_
Posted 11 May 2009 - 01:11 PM
is running true. Not uncommon for a old housing to be running 1/2 inch out of true line from one tube end to the other. Will save
a lot of problems in the long run.
Just a quick question, is it a big tube F100 housing or a XA onwards housing ?
cheers scott
_mowie_
Posted 11 May 2009 - 01:23 PM
Thanks for all of your help.
Tom
_scottya!_
Posted 11 May 2009 - 04:53 PM
You will notice the centre housing is quite narrow where it tapers down to the tubes.
Basically the big housing is considerably wider in the centre housing where it tapers down to the tubes.
The area i am talking about is where the top trailing arms are mounted.
would be alot of clearance issues with the up and down movement of the upper contol arms.
See if you can get a pict. of your housing so you can post it up.
cheers scott
_mowie_
Posted 11 May 2009 - 07:19 PM
Next time im home ill have to have a look.
Thanks for your help.
Tom
_mowie_
Posted 17 May 2009 - 07:18 PM
I was home over the weekend and took some photos of the diff.
Tom
Posted 17 May 2009 - 07:38 PM
The axels in those early diffs ,while not crap,are probably the weakest 9inch axle.If you decide not to use it and go with a later housing,those early ones are REAL popular with the nostalgia hotrod crowd.You could get good coin for it.
_mowie_
Posted 17 May 2009 - 08:26 PM
Posted 17 May 2009 - 08:36 PM
But I may be wrong on the ID.Measure it up and see.Mine was under an EJ and was not shortened.LHs are only about an inch or so widerthan an EJ,from memory.
_memorylane-spare-parts_
Posted 18 May 2009 - 07:51 AM
Sorry to tell you that diff that you have is from a mid 70s f100 not from a tank fairlane look at the mounts are on the top of the housing but you mite still get good money for it as it has a old school hat on itInteresting..... how much do you think they would fetch?
#21
_Squarepants_
Posted 18 May 2009 - 04:31 PM
The upper mounts on this one...Hi Tom, I dont have a picture of the big F100 housing. The housing in this picture is basically a standard 9 inch housing.
cheers scott
Are they the modded HQ trailing arm style that I've been reading about in other threads?
#22
Posted 18 May 2009 - 04:54 PM
Good spotting Darryl.
I must be going blind or something.
#23
Posted 18 May 2009 - 09:59 PM
_mowie_
Posted 19 May 2009 - 11:32 AM
BTT, i have 31 spline axles going through commy disk brakes no worries....
Thanks Bomber,
Are they original axles or are they billet ones?
Tom
