LX under construction
#1 _nial8r_
Posted 10 May 2009 - 12:18 PM
just arrived on the truck from VIC
off the truck in one peice
the young bloke taking it for a test drive around the back yard
couldnt help my self, had to sit the mags under one side to see what i thought of em as i only paid 150 clams for the 4 of em with rubber
here you can see the massive off-set from the back to front
second day home and the old 173 was getting ripped out
i will post more pic's up soon as i have the car stripped right down now ready to start on the rust repairs, mini tubs, also gotta fill in the old fuel filler hole behind the number plate and R/R radiator support as normal the whole bottom is..... well not there lmao like i sid i got a long way to go but it will get done sooner rather than later
#2 _torana_umunga74_
Posted 10 May 2009 - 12:40 PM
#3 _mowie_
Posted 10 May 2009 - 02:29 PM
Looks like a really good base.
Tom
#4 _nial8r_
Posted 10 May 2009 - 04:13 PM
Cheers Lee
Edited by nial8r, 10 May 2009 - 04:21 PM.
#5 _nial8r_
Posted 13 May 2009 - 12:13 PM
got rid of the badges and cleaned up around the holes with the trusty wire wheel on the drill
cleaned up inside if the holes with the milling bit, dont want and rusty shit left in the hole now
ends up looking like this, ready for welding..
started to fill in the 40 million holes that the old owner had made, most of them were screw holes for relays and crap
started on the other side of the engine bay and that when i ran outt'a gas.. not happy, but as you can see i havent even finished stripping the engine bay yet so still got something to do hey..
with no more gas i decided to clean up one of the rear bar supports and paint it, not happy with it so it will be getting redone again, i think today was just not meant to be..
before-
and after-
will have the rest of the day off i think
Posted 13 May 2009 - 12:16 PM
What size are those wheels? And are they Torana Stud Pattern?
#7 _nial8r_
Posted 13 May 2009 - 01:17 PM
pasenger side of support eh!
and driver side of the support eh! eh!
once all the repairs are done and it strppied down to nothing its off to the blasters,
Cheers Lee
Edited by nial8r, 13 May 2009 - 01:19 PM.
Posted 13 May 2009 - 01:36 PM
#9 _mello92_
Posted 13 May 2009 - 03:41 PM
Will keep an eye on how this one goes.
Edited by mello92, 13 May 2009 - 03:42 PM.
#10 _nial8r_
Posted 13 May 2009 - 04:32 PM
Cheers Lee
#11 _studricho_
Posted 20 May 2009 - 07:48 AM
#12 _nial8r_
Posted 20 May 2009 - 11:33 AM
now for some more pic's and maybe some help on something if possible ???
here goes...... i found the bit when i took the left gaurd off but there wasnt one on the right side but by the looks of things it goes here???? any ideas ???
this bit
and i think it goes here on the pillar were the 2 gaurd bolts go through from inside the kick panel but whats it for ??
and i thought i would chuck this pic in, its all the dirt from just under the 2 gaurds and the nose cone and yes that is a blue ciggy lighter for size reference, all up there was 5 dust pans full no shit !!
Lee
Posted 20 May 2009 - 11:48 AM
#14 _nial8r_
Posted 20 May 2009 - 12:04 PM
That piece is for aligning the guards. Dont throw it away, you may find it handy.
thx for the quick reply Rockoz i didnt chuck it for just incase reasons it went into the box of bits to keep thx again hey
Lee
#15 _nial8r_
Posted 14 June 2009 - 06:51 PM
here are the holes where the A/C hoses went,
and now one big hole,
the donor door for some metal, yes the door was stuffed
new piece cleaned up
stuck it behind the firewall to mark it out for the cut,
tacked a washer on it so i can hole it in the perfect spot and NO burnt finger either
see easy to hold,
stitched in place,
only a little tac on the washed so it just snaps off easy and no damage,
see easy huh
welded and cleaned up no more holes
hit with a couple of coats of Etch and wall'a
heres the other side where the loom, accelerator cable and clutch rod holes where,
and a bit of a front view of the firewall done and all etched
opps forgot this one of the firewall seem that i trimmed, it had the biggest overlap i have ever seen,,
drivers side pillar behind the gaurd, started as a pin hole of rust but after i chased the rust on the inside this is what i ended up with,,,
new piece in
the lower section of the support
cut the sucker out ready o make up a new one
the missing piece
drew up a new piece,
cut it out
and all bent into shape
and here it stitched in but not happy with it at all so im getting a whole donor support from Matt and the little lower section from paul who has feb'ed up many of these thx heaps to you both
more pic's to come
#16 _nial8r_
Posted 14 June 2009 - 07:00 PM
marked out the inner gaurds feadt to be cut and smoothed out left and right side,
both sides cut out,
shaping the new pieces, what fun that was
holes drilled so it could be plug welded to the rail like the rest of the inner,
left one in
right one in
now i just have to hit em with the dolly and file and then start on the support and the battery tray and other side and then i have been given my orders to finish the roof on the house, i have gurni'ed it and re-caped it all just gotta paint in about 2 days work then back into the Torana if anyones see's anything that might need some more attention please let me know, but be sure to let me down gently
#17 _ass308_
Posted 14 June 2009 - 08:07 PM
#18 _nial8r_
Posted 14 June 2009 - 08:14 PM
#19 _noslx_
Posted 14 June 2009 - 08:48 PM
Posted 14 June 2009 - 09:02 PM
I like the way you've made and welded in thoes patches, its starting to look very smooth, looks like its turning out to be a nice torry.
Cheers Paul.
#21 _homer_
Posted 14 June 2009 - 09:23 PM
#22 _nial8r_
Posted 15 June 2009 - 08:04 AM
#23
Posted 15 June 2009 - 08:10 AM
Looks awesome. Very nice repairs on the inner guards. I wanna know what they'll look like with paint over the top haha
#24 _studricho_
Posted 19 June 2009 - 10:48 PM
#25 _doogs_
Posted 22 June 2009 - 08:58 PM
Particularly like the way you used the washer on the peice you were welding in.
