LX under construction
#176 _nial8r_
Posted 31 October 2010 - 02:34 PM
#177
Posted 01 November 2010 - 02:23 PM
Get that rad support done!
.... and Orange is an AWESOME colour for an LH / LX 4 door!
Edited by notna, 01 November 2010 - 02:24 PM.
#178 _nial8r_
Posted 19 May 2011 - 08:03 PM
seems i only took a pic of one side
this is after i cut all the rust spots out, gezz these kinda repairs shit me
this was the worst spot were i found the T-Shirt stuffed and a tonne of bog over the top
had to put it back together in a couple of different pieces
but i got there in the end
and back in 2K etch
now i just have to fix the beaver panel that i replaced as i dont like how its sitting, then get the radiatpr support back on smooth the engine bay out and then send it of to get a boot floor & tub's fitted
#179 _Liam_
Posted 19 May 2011 - 08:20 PM
#180 _Kush_
Posted 19 May 2011 - 10:41 PM
#181 _nial8r_
Posted 20 May 2011 - 04:01 PM
Edited by nial8r, 20 May 2011 - 04:01 PM.
#182
Posted 20 May 2011 - 05:34 PM
Great work Lee, Keep at it, and keep posting photos, you know we all like photos.
#183 _nial8r_
Posted 20 May 2011 - 05:50 PM
#184 _A9XOSS_
Posted 20 May 2011 - 08:32 PM
#185 _nial8r_
Posted 21 May 2011 - 08:47 AM
#186
Posted 21 May 2011 - 10:28 AM
I'm taking a month off work in 4 weeks. My job is mega stressy.... If i don't take the month I will burn out. I'm planning to wok on my SL/R every day, so watch out mate!
#187 _nial8r_
Posted 21 May 2011 - 04:19 PM
#188
Posted 21 May 2011 - 06:38 PM
I'm no expert, but sometimes you JUST gotta go with your gut feeling. My father in law spends half a day measuring everything 20 times, and it shits me like you wouldnt believe. NIKE had the idea.... JUST DO IT!!!!
#189 _nial8r_
Posted 21 May 2011 - 07:05 PM
#190 _nial8r_
Posted 21 May 2011 - 07:10 PM
after i got it off, i didnt drill the spot welds out on this as i couldnt really see were they were so i tapped away at them with a sharp chisle and hammer and only got one pull through
and well this is the lower section off. its for sale if anyone wants it
Edited by nial8r, 21 May 2011 - 07:13 PM.
#191
Posted 21 May 2011 - 09:31 PM
If you "hang" the rad support on top of each inner guard, and clamp it like you are going to weld, how does the rest line up? I clamped and welded in those 2 places, and THEN had to raise it up, pulling the inner guards with it, to line up the holes where the spot welds were split.
I reckon that when you remove the rad support, its only then that things move out of alignment, because the rad support holds quite a few different things in place.
Lots of push and shove mate! Show it who the boss it!
LOL! You never know mate!!
#192 _LH SLR 3300_
Posted 21 May 2011 - 10:23 PM
#193 _nial8r_
Posted 22 May 2011 - 08:56 AM
#194 _nial8r_
Posted 31 May 2011 - 08:00 PM
all the holes were i unpicked it are all filled in useing the copper backing plate that worked a treat, thx again for the info fella's
always got a pressure pak of etch to cover up while i move onto other repairs
now the fun part was shaping up the inner lower section, it has a slight bow in it so i has to get the wife on the blow torch heating the new piece while i tapped away useing a big pice of 10mm plate steel for the edge untill i got the right curve, it took a bit but i got there in the end
all welded in, i left a 5-10mm overlap so that i could blend it in when it was cleaned up, in the 2nd pic i had to do 2 small repairs either side of the centre section.
then it was time to clamp the outter section on so that i could mark out the new inner section and cut it to shape
all stripped back and ready for some 2k etch
all in 2k etch finally
now all i have to do is give it a day or so and then brush some seam sealer over the welded section on the front before i attach the outta section, then its right to go back on the car saturday morning
Edited by nial8r, 31 May 2011 - 08:08 PM.
#195 _Kush_
Posted 31 May 2011 - 08:26 PM
Also, I wish my missus helped me with my car..........
And I wish I had as many clamps as you....... Clamps are like getting your mates over to hold stuff that don't complain or annoy you or offer their stoopid opinions all the time
I'm DEFINATELY going to have to buy more clamps.
Edited by Kush, 31 May 2011 - 08:29 PM.
#196
Posted 31 May 2011 - 09:40 PM
I only learnt the copper behind the hole trick recently too. Wish I had known that one earlier!!
Quality work as usual mate. Looking forward to seeing you work in fitting it.
#197 _Liam_
Posted 31 May 2011 - 09:55 PM
#198 _nial8r_
Posted 01 June 2011 - 09:10 AM
The copper backing for filling holes make life so much easyer and neater too, i only wish i had a decent lump as the the bit of copper pipe a made flat got f%$king hot real quick but it did the job and i only need it now to fill the holes at the front of the inner gaurds and the ones on the ends of the rails but this time i will try not to forget its hot
when i look back at the pic's i think to my self that doesnt look to hard but most of it is just time consuming as with the lower section i couldnt just have a good run at it as i had to keep the heat down so that it didnt warp thats the worst part, well for me anyway cause every time i stopped to let it cool a bit i fired up another ciggy next step is to get the support back on then trim and smooth the rails and find someone that will restamp the number that is on the R/H side when i replace both the battery tray and the same on the other side. then i should be right to send it off to have the whole new boot floors and tubs done while i start on all the hanging panels.
#199 _BrettLH253_
Posted 02 June 2011 - 10:47 AM
#200 _nial8r_
Posted 02 June 2011 - 11:48 AM
have a gander at some of " Dirtbags " build threads, he turns wheel barrow loads of mangled rusty metal in to show quality cars. he has a talent that alot of us envy
