Installing k frame
#1 _1ARC_
Posted 11 May 2009 - 11:02 AM
The process that I have followed is: using a floor jack, I aligned the k frame and secured the front four bolts to the sub frame (including new bushes). That was the easy part. I used lubricated scrapers to assist the rear k frame arms to be located to the mounting point on the sub frame. Here is where I have hit that brick wall. The rear holes between the sub frame and the rear k frame arm do not line up. It seams that the k frame needs to move forward which is difficult as there is no slack for a forward movement.
I appreciate to know your experiences and the tricks of getting a k frame bolted into place without slitting the dummy. Photos would also be a help.
Posted 11 May 2009 - 11:34 AM
If not, try loosening the chassis nuts up top and see if the lower holes can be aligned.
By the way, is the k frame you are fitting the same one which was removed from your car?
Cheers, Max
Posted 11 May 2009 - 11:35 AM
#4 _TRRANA_
Posted 11 May 2009 - 12:29 PM
#5 _1ARC_
Posted 11 May 2009 - 01:15 PM
Have you tightened the four nuts on the chassis rails before you attempted to locate the bolts on the lower two holes (your brick wall) I have always located all bolts in the chassis and k frame prior to fitting nuts and tightening. Lifting the k frame parallel to the chassis rail makes the job of aligning the holes much easier.
Cheers, Max
I had the 4 bolts with the bushes in position and the nuts finger tightened. The k frame is the same as it came off. I have tried to lift the k frame parallel but no luck.
Do you locate the bolts with the 4 front bushes both top ond bottoms in position?
Cheers John
#6 _1ARC_
Posted 11 May 2009 - 01:18 PM
The four front bolts and bushes have quite a bit of slop/movement available, have you actually tightened them? They may be holding it in the wrong spot
No I have not tightened any of the bolts. I am sure that it has to do with having every think lined up. The problem is if I line up the 4 bolts first there is no room for any movement to allign the rear bolts.
Posted 11 May 2009 - 01:45 PM
I haven't done this job yet but it will be on the cards when i get around to statring on Tracie's car so i am looking forward too the answers and fixes to the problem.
Would it possible for you to take photos of what you have already done just so the gurus have a bit more of an idea of the problem you have and it will help the rest of us if we come accross The Brick Wall .
Mort
Posted 11 May 2009 - 02:08 PM
They are fixed on the chassis & there is no adjustment there.
Leave the top [4] rubbers off, just fit the lowers, then push,shove,swear until it ligns up, fit top rubbers/washers/nuts & tighten........beer time!
#9 _chrome yella_
Posted 11 May 2009 - 02:31 PM
#10 _1ARC_
Posted 11 May 2009 - 03:02 PM
Put the outrigger bolts in first.
I even tried this but found that the 4 bolts would not allign and would not go past the front bush cup. Cheers
Posted 11 May 2009 - 03:04 PM
Posted 11 May 2009 - 03:06 PM
That's how i do mine.
Sorry for the confusion.
Posted 11 May 2009 - 03:48 PM
JMHO
#14 _1ARC_
Posted 11 May 2009 - 03:51 PM
I meant.....the 4 bolts go up with the lower rubbers on, leave 10 mm for clearance,then fit the out rigger bolts.
Is the 10mm clearance from the top of the lower bush to the bottom of the sub frame?
Do you have the lower bush resting on the k frame or are they resting in the hole of the sub frame?
Posted 11 May 2009 - 03:59 PM
When the outrigger bolts are in, use a screwdriver to locate the lower bushes.
#16 _scottya!_
Posted 11 May 2009 - 06:07 PM
Generally if it wont fit, you got to call it every swear word you know, even make up a few words.
Throw the spanners, leave it for a couple of hours and when you come back to it,
it will fall back into place like you wont believe . Its like magic, its amazing how it happens.
#17 _Lhover_
Posted 15 May 2009 - 10:03 PM
I would imagine over the years some Torrys have had a hard life and a small knock on the k frame or small shunt would turn the k frame into a stessed member meaning when you go to refit it it may need slight persuasion
Good luck
Chuck.
Edited by Lhover, 15 May 2009 - 10:16 PM.
#18 _darrenmark1_
Posted 15 May 2009 - 10:18 PM
If it don't fit hit it harder!
Edited by darrenmark1, 15 May 2009 - 10:19 PM.
#19 _the gts_
Posted 18 May 2009 - 10:52 PM
They are a pain in the a$$. Anyone who says they go in easy is making up stories!
Just curious - has anyone checked the manual? what does that say?
#20 _The Baron_
Posted 19 May 2009 - 05:45 PM
I take my hat off to them!!!!!!
#22 _the gts_
Posted 19 May 2009 - 10:59 PM
yes i do mine with everything attached engine, trans, wheels etc as a whole complete roll in assembly
#23
Posted 20 May 2009 - 07:56 AM
That's the only way I've ever been able to get it properly lined up, I reckon this method lends itself to dropping the body onto the frame as opposed to raising the frame into the body.HMMM sounds like the 4 engine bay bolts are first to put in.
#24 _1ARC_
Posted 20 May 2009 - 10:58 AM
As I had the front end rebuilt all components are tight with no give in any direction. I found that the trick is to lift the k frame so that it is aligned with the angle of the frame of the car. To do this I used two jacks, one to lift the weight and align the front bolts and the other to lift/lower the rear arms to ensure that the right angle was maintained. This worked well.
The other thing I did was that I used a cabinet markers G clamp to clamp the rear arms in wards. This allowed me to lift the k frame and allow the rear arms to go over the lip on the sub-frame where the rear bolts align with the rear arms.
It took my son and I three patient hours to do this. Not every thing is as easy as it is made out to be.
