Torana's new shoes!
473 replies to this topic
#301 orangeLJ
Posted 23 August 2011 - 04:38 PM
More pictures-
parts pile, its funny how much space it all takes up when you pull it all off!
port comparrison
The rear of the inlets and the throat have had more work than anywhere else on this head, by no means massive, but should be enough considering that its similar to the purple car, but with higher compression and a bigger lump stick.
and just some more shots when I was pulling it down
ALSO!
puppy dawg!
#302 MRLXSS
  • 12,413 posts
Posted 23 August 2011 - 06:52 PM
I know the feeling of it taking up space! Mine is the opposite now! Its great to finally put it all back together and make some space!!!
#303 _Liam_
_Liam_
Posted 23 August 2011 - 07:34 PM
That engine looks good even naked...
#304 xu1kid
xu1kid
  • 364 posts
  • Name:anthony
  • Car:lj gtr xu1
Posted 26 August 2011 - 10:40 PM
what fuel u ruuning this engine on bp 98? comp is up there
#305 orangeLJ
Posted 27 August 2011 - 09:02 AM
Avgas :)
But it should hack 98 ookish
#306 orangeLJ
Posted 27 August 2011 - 12:45 PM
Also had another look at the.rocker studs, they are push in, but have been pinned :)
#307 _mumbo_
_mumbo_
Posted 29 August 2011 - 09:55 AM
Ha thats why they have not pulled :)
#308 orangeLJ
Posted 07 September 2011 - 06:26 PM
Haha, yeah id say it is!
New ventilated and slotted rotors turned up, need to get them turned down now.
Split and disassembled the calipers, pistons are all good, have kits waiting so just waiting on them to get hot tubbed. Going to paint them black I decided, nothing flashy lol.
Front end is in hifill, waiting on a mate to paint it all, then its ful steam ahead!
#309 orangeLJ
Posted 29 September 2011 - 03:53 PM
Front end is all shiny and smooth!
Went for black again, I dont think I could hack having it orange, would get dirty too quickly. So gloss black it is!
Hopefully have the front end back together saturday morning, just need to pull the stubs off the one in the backyard to replace my UC front stubs.
Bought a bearing kit for my box today, so giving that a go over the weekend as well, fingers crossed it all goes to plan.
Things still needed to do-
-Clean and paint block/head
-Port match manifolds
-Smooth and paint manifolds (going black again)
-Clean and paint some parts of my webers
-polish/paint a whole heap of ancillary pieces
-Rebuild gearbox
-rebuild front end
-mock up brakes to sort out caliper-rotor clearances to turn them down
-Get brake lines made
-finish new extractors+HPC
-build exhaust
and probably a heap more!
I plan to get it running and driving again this weekend using some of the old parts (old brakes, old extractors etc) to get it to the paint shop, so that will give me the time to get the rotors and brake lines sorted, as well as finish the new pipes, so when it comes back from the panel shop, I'll be able to bolt it all up.
Still havent decided on brake pads.
I was going to buy some DS25000 ferodo pads, but at $260 for the set, im a little hesitant, so looking at some cheaper options at the moment.
#310 _UXTorri78_
_UXTorri78_
Posted 29 September 2011 - 06:33 PM
looks awesome mate :) very tough looking torri. whats the name of the company you got the tappet covers from?, ive been looking around for a while and cant seem to find anyone who does them,
cheers, matt
#311 orangeLJ
Posted 29 September 2011 - 07:58 PM
Bocam in victoria is the joint, theres a few of them.getting around now, I might have.to.change.soon to stay original! Haha.
#312 orangeLJ
Posted 14 October 2011 - 03:36 PM
time for some pictures :)
New rotors
Compared to origianl (no they wernt on the car, I was running UC gear) rotors
Trial fitting it all up
Turning down the rotor diameter
Not sure if I posted this, but I veed out the usual crack in the crossmember and filled it with weld, then ground it off semi flat (didnt want to take too much away)
Then hi-filled it and everything else.
Then it got gloss blacked :)
Time for a friendly intermission-
Edited by orangeLJ, 14 October 2011 - 03:39 PM.
#313 orangeLJ
Posted 14 October 2011 - 03:53 PM
cleaned up and rubbed the sump
Sump gasketing-
Painted the engine
Modified and smoothed the thermostat housing. I cut the heater outlets off flush and brazed them shut, them shaped and smoothed the whole housing.
Calipers have been stripped, acid bathed and repainted :)
Only drama Ive got at the moment is my tappet cover doesnt fit with head studs.... seems a pretty stupid move to make a "race" rocker cover that doesnt fit with something performance related like head studs. I contacted bocam and for $66 I can get a new set of bolts and a spacer plate that will make it fit, not a heap of cash, but it still gives me the shits. It shouldnt need a spacer plate... And with a spacer plate, i need to then run two gaskets and all the headaches that will bring, plus look like shit.
So Im tossing up modifying the cover with the die grinder and the tig, but we will see how I go.
in all its previous glory :)
I fitted my dog with some fully sick front glow neons
My dog being a great guard dog! sleeping on the job!
Also, just some extra photos,
Some of the spares-
all up between me and my old man we have 8 186-202s stashed away, plus 4 celica boxes and 4 aussie boxes. So I think we are good at the moment!
there is also an LC GTR burried under the insulation for the new shed :)
#314 _TJ355_
_TJ355_
Posted 14 October 2011 - 11:21 PM
Looking great man she gonna stop alot better now
#315 orangeLJ
Posted 17 October 2011 - 07:14 AM
Yeah definitely should stop a shitload better.
The cast iron calipers are a little heavier than I'd like, but it should be worth the trade off!
I just cant wait to get it driving again, its been like 4 months off the road now. After the drag day this weekend though its basically full steam ahead.
#316 orangeLJ
Posted 19 October 2011 - 09:04 PM
Thought Id throw these up too-
Got some more done today-
rebuilt my calipers-
Shiny things-
Front end is all loose assembled ready for springs/shocks/brakes then its all go from there
ohhhh and had these cut too-
#317 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 19 October 2011 - 09:39 PM
what did it cost you to have the flanges cut?
#318 orangeLJ
Posted 20 October 2011 - 06:28 AM
I can do em for $35+post.
I need to make my pipes first to make sure.they are all good (the template fitted fine)
Then i'll start selling them, works out a fair.bit cjeaper than any of the ones ive seen around
#319 orangeLJ
Posted 20 October 2011 - 01:23 PM
Well torana is officially registered again, was cutting that a bit fine....
another week or two and it would have passed 90 days and needed a blue slip, Id lose my plates etc etc.
Seems like I pay all this rego each year and the car is only on the road for half that frOcking time, pretty pathetic....
$530 for my bloody CTP, plus $400 odd for rego and $400 odd to comp insure it for the year.
Adds up when Ive got 4 registered cars in our house. Karlies Greenslip on the ute is even worse because Its classed as a "commercial vehicle" what a crock.
#320 _lc202_
_lc202_
Posted 20 October 2011 - 02:48 PM
Very impressive Chris, what make simmons are those wheels exactly? your car is neat, straight and exactly what a 4 door ought to be. And the new motor sounds like a bit of fun, even if it isn't an 8 Posted Image
Just one more question, what calipers are they? volvo 4 pots or something else?
just read this entire epic thread, awsome car
x2 on the caliper set up
#321 orangeLJ
Posted 20 October 2011 - 03:06 PM
Thanks mate.
Years ago I had a complete write up on the car from dingy olive green crapbox from the wreckers to what it was after the first build, but after a dummy spit I had it deleted a while back, so the thread could be another 20 pages if it was all here! haha.
Calipers are Hilux 4 piston, rotors are BMW slotted and vented.
#322 _mick74lh_
_mick74lh_
Posted 20 October 2011 - 09:52 PM
Sweet. Love the magazine photos. Looks bloody unreal!
#323 orangeLJ
Posted 14 November 2011 - 11:44 AM
Well the box is almost back together, all fresh bearings and tolerances adjusted, just waiting on one more bearing today and will finish putting it back together tonight.
Saturday this week is for getting the box mated up to the engine and clutch etc sorted, then sunday is mounting it all on the front end, hubs etc back together and rolling it under the car.
If all goes to plan (which it rarely does) should be close to firing it up on sunday arvo
#324 _beige_lj_
_beige_lj_
Posted 14 November 2011 - 12:21 PM
Not long now!! I really enjoy reading and looking at what youve done so far, pretty interesting stuff :) Keep the pics coming
#325 _TJ355_
_TJ355_
Posted 17 November 2011 - 11:00 PM
awsome work dude i take my hat off 2 ya
