hey i have a 308 with a big cap holden dissy in it. Can anybody tell me which way the 2 wires go from the dissy( i pretty sure they go to the coil but which is + and - is that right) also what else goes to the coil is it a 12v wire from the acc.
2. how may wires go to the starter?? there is the big one straight from the battery and is there one more or 2 more and what are they?? thanks
need help wiring up a dissy and startor on 308
_erin6807_
, May 19 2009 01:28 PM
1 reply to this topic
#1 _erin6807_
Posted 19 May 2009 - 01:28 PM
#2 _@milco@_
Posted 19 May 2009 - 10:05 PM
coil needs 12v from loom and neg from tacho if fitted.
um
dissy both go to coil dunno what color wires do you have?>
starter
should have one from battery , one spade plug from loom and one ring connector that bolts on from loom if i remember correctly?
where are you mabe some one frm the forum could pop round and give you a hand?
um
starter
