supercharged gemini help
10 replies to this topic
#1 _2_many_torries... never!_
Posted 27 May 2009 - 01:26 PM
Hi i need some help with my gemini. i have fitted a sc14 supercharger and 2" su in a draw thru setup on my 1600 gemini. i have tried everything i know to get it to run properly but to no avail so hopefully someone will have a clue.
the su seems to be fine( although it could need a completly different needle i am not sure) there are no leaks in the intake system, the supercharger is only geared to run about 6 psi at max revs. the timing is locked at about 15 degrees and has the vacuum advance disconnected.
when i start it the car idles fine and will rev pretty well ( not perfect) with no load. when driving it will drive fine when not making boost i.e. light throttle but as soon as the boost gauge hits positive the car will die and if i back off again to part throttle it will drive fine and really smooth. if i plant it and keep the throttle down sometimes when i lift off it will backfire. my onlt thought is that maybe the fuel pump isnt up to supplying it with enough fuel or something funny is happening with the fuel when on boost and it wont let it through... anyway here are a few pics. any help would be great thanks
#2 orangeLJ
Posted 28 May 2009 - 08:56 AM
Looks like you are still using the standard clutch pulley on the s/c?
What do you mean by die? does it conk out completely or just starts to misfire? Id be checking my plugs (if you can get enough driving time) to see if tis rich/lean.
What needle is in the carby?
Is the carby opening all the way up under load (ie. the piston isnt being obstructed by anything?)
If the blower is hitting boost and the carby isnt letting enough air/fuel in, then it would act like a blocked exhaust or similar where the car just wont go anywhere.
Pull the cabry off, check the butterfly in the rear, make sure it functions correctly, maybe throw a rebuild kit at it, check what size needle its running (should have two or three letters stamped on the needle) Im guessing its a carby issue.
#3 _Trigger82_
_Trigger82_
Posted 28 May 2009 - 11:57 AM
Hi, Im not a carby person but two quick things come to mind,
1. Is the carb capable of supplying the needed fuel
2. Is the old Ignition system not up to the task trying to ignite the fuel under boost (fuels harder to ignite under pressure)
also once the cars running right you may need to change down to a colder plug due to the higher combustion temperatures. it almost sounds like a fueling issue, do you have the means of hooking up a incar fuel pressure guage to see if the pump is supplying enough fuel if your thinking it may be the pump?
#4 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 28 May 2009 - 12:06 PM
Just a guess
May be the carbys not supplying enough fuel.
Adjust or modify carby (if not already as turbo's need modified carbys)
Or replace carby all together
Can someone here advise what carby to use as there have been a few turbo carby 202's here.
#5 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 28 May 2009 - 12:09 PM
Just a guess
Oh the ignition under boost is a good point too. Perhaps eliminating that would be the cheapest and simplest? VL turbo ignition coil perhaps? (Before playing with the carby?)
#6 orangeLJ
Posted 28 May 2009 - 12:10 PM
the 2 inch SU should be fine for a 1.6 on only 6psi
Other options are a small DCOE weber, or a stromberg, or twin carbs etc.
#7 V-SLR5000-P
V-SLR5000-P
  • 1,311 posts
  • Car:L34 x 2
Posted 28 May 2009 - 12:40 PM
That big fat SU is sufficent to feed a blown 1600. The blower would not make the calculated boost if the carby is not big enough to pass the required volume of air. Check usual SU tuning items, needle centred in jet, piston free throughout its travel, oil in the dashpot. Otherwise l'd try a richer (thinner) needle, or give the one you have a light file. But, theres no going back once you file it! SU's dont like a heap of fuel pressure but the system must be able to maintain 3-4lbs pressure at all time. You should also aim for around 32 degrees total timing including 15 initial.
#8 _oldjohnno_
_oldjohnno_
Posted 28 May 2009 - 01:54 PM
Some of that bracketry doesn't look all that rigid. I'm wondering it's flexing and allowing the blower to stall and the belt to slip when it loads up under boost.
#9 _TUFF_
_TUFF_
Posted 28 May 2009 - 02:36 PM
2 many torries maybe try www.ozgemini.com if it has anything to do with gemini's... they will know
#10 _2_many_torries... never!_
Posted 28 May 2009 - 04:43 PM
thanks guys, i will pull the carb off and check it out again, everything moves freely and seems to be ok but ill give it a clean and blow out and then probably put electric ignition in i the dizzy(anyone know an easy conversion for a gem?) . might look at a new pump too and a pressure regulator to keep it about 4 psi, ill let you know how it turns out
#11 _BambooRon_
_BambooRon_
Posted 28 May 2009 - 07:41 PM
My little gem was putting the sparks out, after some basic mods-
rebuilt the dizzy-adjusted advance springs reset timing-
new coil and ballast resistor-mechanical secondary carby mod on the nikki
NOW pulls 7000 rpm-no more breaking down in the ignition-go jimmy
