Frock me. What hope have we got.
ID tags- The dodgy ones
#551
Posted 29 May 2016 - 08:45 AM
#552
Posted 29 May 2016 - 09:10 AM
Actually,
they do say on their home page that they need a copy of your licence papers to stamp them. And when you go through some of the other makes that they do, it appears they use the same font stamp for all of them which would look out of place on a Holden plate.
There would be over a thousand words in their terms and conditions, but the legality of these things is not even mentioned.
bentley-id-plate.jpg 126.92K
2 downloads
datsun-id-plate.jpg 108.67K
2 downloads
maserati-vin-plate.jpg 111.55K
2 downloads
#553
_Skapinad_
Posted 29 May 2016 - 09:16 AM
#554
Posted 29 May 2016 - 09:51 AM
Ha, that Holden PSN plate isn't identical to an original LC or LJ. The corners have too much radius to start with.
#555
Posted 29 May 2016 - 11:33 AM
and my VIN tag is so battered from engine parts etc,
a new one would look wrong.
By the way, the Ebay Tag Ad is searchable now,
just type in - LC ID
#556
Posted 29 May 2016 - 08:17 PM
#557
Posted 29 May 2016 - 09:54 PM
Actually,
Like I said a while ago, Rare Spares should do the tags as a replacement tag if your original tag is lost or destroyed but with RS in corner etc. By the look of this someone has started it up.
#558
Posted 30 May 2016 - 02:58 PM
Just discovered this:-
That plate is an obvious repro, plus if they don't have access to tens of 1000's of samples they'll never get the text in the right spot with the same wear consistent with other tags around them. Unless they have the original as a sample then it doesn't really matter.
#559
Posted 30 May 2016 - 03:04 PM
My L34 has the old type as well. A funny shaped pin punch was used to insert them, then the hole filled with a hard tar. They changed to the pop rivets about the end of '74.
It looks to me like the pin on the pop rivets was hollow. Any rivet you buy from the hardware store would be a solid pin, and they snap off deep inside leaving a bigger hole.
Thanks to Datto and Brad for the following.
Rivet change happens into early HJ. Some cars have a combination of small and large rivets depending upon the delay between the body plant and the assembly plant, and also depends upon how the assembly plant operated eg Acacia Ridge put the BODY and VIN tags on in the body plant whereas Pagewood didn't put the ADR tag and VIN plant on until late in the assembly plant process.
#560
Posted 30 May 2016 - 04:23 PM
#561
Posted 05 June 2016 - 10:48 PM
LJ 82311 1972 Adelaide tags & chassis number cut on ebay. http://www.ebay.com....7AAAOSwxvxW7nyu
Can someone do a screen shot of the ad, I tried but no luck.
Posted 05 June 2016 - 10:55 PM
#563
Posted 06 June 2016 - 07:58 AM
Haha, just looking again at the pic of the chassis number, it looks like bog around the number. Been cut out and welded in once already.
#564
_Skapinad_
Posted 06 June 2016 - 08:17 AM
I copied some pics of some tags that were for sale last weekend off a supposed LJ V8 together with a cutout body no. I have pics of all the numbers underneath. In the small plate number it looks like its an I after the J, definitely doesnt look like a 1.
Small plate no-82311JI210208
Model - LJ82311
Body No - 1851-A
Trim - 578-46E
Paint-568-5091
Chassis no - ALJ10611A
Same tags ??
#565
Posted 06 June 2016 - 08:22 AM
Same tags ??
I'd reckon so Adam.
#566
Posted 06 June 2016 - 08:35 AM
lol, somebody post him this link.
http://www.gmh-toran...-10#entry782196
s
Edited by StephenSLR, 06 June 2016 - 08:35 AM.
#567
Posted 16 July 2016 - 10:04 PM
Can't post pics for some reason
#568
Posted 16 July 2016 - 10:15 PM
A must have mancave display...for 6k...
#569
Posted 16 July 2016 - 10:16 PM
Classic
#570
Posted 17 July 2016 - 08:23 AM
#572
Posted 17 July 2016 - 09:13 AM
Now we just need someone to message him and get the numbers. Just tell him you want to run a check to see if the VIN is consistent with the chassis no.
s
Edited by StephenSLR, 17 July 2016 - 09:16 AM.
#573
Posted 17 July 2016 - 09:17 AM
From the same seller of the LC GTR tags at Tivoli, North Ipswich.
LJ XU1 body tag.
http://www.gumtree.c...-tag/1118721959
Posted 17 July 2016 - 09:25 AM
s
Chassis number looks like LC20825B
Compliance date 1/71?
Edited by S pack, 17 July 2016 - 09:28 AM.
#575
Posted 17 July 2016 - 09:47 AM
I didn't realize that you can hide your location on Gumtree.
