'Purple' build thread
589 replies to this topic
#426 _LS2 Hatch_
_LS2 Hatch_
Posted 01 November 2014 - 04:48 PM
That's called building a custom car. To " your" liking, not what others think is "correct"
Mine doesn't even have door handles!?! ;)
#427 Statler
  • 6,317 posts
Posted 15 November 2014 - 11:53 AM
Screwing around the idea of different rims.
I sat the OM's up just because i can. :)
Screwed one of the plates on today. Still pinching myself that i got them. :)
#428 Potta
Posted 15 November 2014 - 12:51 PM
Hard decision on the wheels Col, they both look pretty good.
And as for the plates, well done mate, what a score!!  :clap:  :clap:
#429 _j.e.d._
_j.e.d._
Posted 15 November 2014 - 01:23 PM
Gold wheels looks good Col, but better to look at the whole car to decide  B)
#430 fatslr
fatslr
  • 1,247 posts
  • Name:Garth
Posted 15 November 2014 - 03:23 PM
Nice arse
I reckon black one side gold the other
#431 Statler
  • 6,317 posts
Posted 25 February 2015 - 03:03 PM
Got a couple more things crossed off the list.
Rear swaybar mounted. I fab'd up a couple of Commodore type mounts & welded them to the housing. It's never plesant welding 12" from your nose overhead.
Door trims finally arrived. They are now fitted. Interior is looking good. Sarina Upholstery donated new clips. ( i presume they were donated because i didn't get an invoice) They will also be fitting the rear seat covers for me. ( which is when i will probably get the invoice) lol
I'm still looking for a rear shelf or kick panel speaker cover if anyone has a spare. The last one was lost in the post.
The wiring harness arrived too. Big thanks to Matt LH3300SLR for taking care of that. Matt, if you read this, that diagram you drew up for me should be made Forum knowledge! It's brilliant mate! Thank you!
Next on the list is to fix a little bit of rust from a hidden rats nest & rework the million $ exhaust to go around the Brown Davis tank. Baby steps in between pain periods.
#432 hanra
  • 10,975 posts
Posted 25 February 2015 - 04:47 PM
You went with LX door trims?
#433 _330OLX_
_330OLX_
Posted 25 February 2015 - 05:33 PM
Will it be ready for the road trip to Toranafest 2015 Col?
#434 Heath
  • 18,393 posts
Posted 25 February 2015 - 07:21 PM
Get those OM's out to 9" and 11" and you'll be looking good.
#435 Ice
  • 15,202 posts
Posted 25 February 2015 - 07:29 PM
You know your gunna paint the V5s black they will look pretty good imho
#436 Mort
Mort
  • 2,760 posts
  • Name:Mort
Posted 25 February 2015 - 11:21 PM
Top job Col, won't be long before the whiteboard is clean at this rate.
Did you manage to get the fuel lines finished to the engine bay.
#437 Statler
  • 6,317 posts
Posted 26 February 2015 - 10:26 AM
The interior is from 'Black'. I prefer the LX stuff over the LH stuff.
It probably will be Bruce but i don't know if it will be there.
Change rotors, fill/drill rear axles, replace front/rear suspension, order new inner/outer bands ........... nah! That's an expense i don't really need. Stick with the V5's ( but i will change the color)
Just waiting on some more P-clamps m8. The firewall plate is being re-done which is holding me up.
#438 slar
slar
  • 498 posts
  • Name:AL
Posted 26 February 2015 - 07:23 PM
Looking very nice Col
#439 Statler
  • 6,317 posts
Posted 26 February 2015 - 07:50 PM
Thanks Al. I'm still waiting on your locks. Seems they have been busy.
#440 slar
slar
  • 498 posts
  • Name:AL
Posted 26 February 2015 - 07:56 PM
No worries it'll happen when it happens lol
#441 Statler
  • 6,317 posts
Posted 02 April 2015 - 01:03 PM
Dummy fitted up some intake bits to check for clearance.
Tail pipes are done. Tank is fitted for the last time.
purple%20tail%20pipes%201_zpsjmzqzfxb.jp
#442 Statler
  • 6,317 posts
Posted 08 May 2015 - 05:12 PM
Tail pipes re-done.
That will teach me to tighten up the wheel nuts. All the clearance faded away.  :banghead:
Rear end is finally back on the ground.
I started making the firewall plate in November last year. Finally finished after 1 failure, 2 machinists & 30 bottles of scotch.
Time to start the wiring. Shoot me now! :banghead:
#443 IMORAL
IMORAL
    Bored
  • 2,568 posts
  • Name:Paul
  • Car:LX SS HATCH - IMORAL
Posted 08 May 2015 - 09:15 PM
That looks good col
#444 Statler
  • 6,317 posts
Posted 09 May 2015 - 06:21 PM
Thanks Paul.
Baby steps between pain periods. :)
Thanks to Rob today for the fuel hose. :spoton:
#445 Statler
  • 6,317 posts
Posted 12 May 2015 - 02:59 PM
Fuel reg now lives on the firewall.
#446 SmacT
SmacT
  • 978 posts
  • Name:Sam
  • Car:LX 4dr 383, TKX, BW
Posted 12 May 2015 - 03:24 PM
Bit, by bit, by bit - good one. How does your clutch cable go with clearance to the headers? I was going to make up a simple bracket to hold it off the things, but interested to see how you have done it.
#447 Statler
  • 6,317 posts
Posted 13 May 2015 - 07:25 AM
The cable doesn't hang on the pipes but i haven't tried putting pressure on it yet.
I was planning on putting a 'P' clamp on the UCA mount to retain it.
#448 Statler
  • 6,317 posts
Posted 13 May 2015 - 07:29 AM
#449 Statler
  • 6,317 posts
Posted 07 October 2015 - 11:17 AM
Well .............. after a bucket full of enthusiasm at T-fest i am slowly crossing more things from the 'to-do' list.
Had a constructive session with the consulting engineer today. He is happy with the quality of work. I don't think the mod plate is going to be a problem. :)
Waiting patiently for the sparky to show up & wave his magic soldering iron over it, then maybe i can finally hear it run. He should be here this weekend.
Fuel pressure gauge fitted. Consol shifter surround ordered. Engraved ID tags ordered too. (National Engravers)
ALL of the mod plate guys i have spoken with refuse to put the mod plate in the boot. "Oh it has to go as close to the original tags as possible!"
So i am going to put the engraved tags in the engine bay & mount the stock tags in the boot.
I still have some custom pieces to fabricate in the engine bay, but that can wait.
Edited by Statler, 07 October 2015 - 11:19 AM.
#450 Bigfella237
Posted 07 October 2015 - 12:15 PM
I had the same idea, in fact I wanted to relocate the stamped chassis number to the "chassis" in the boot as well.
I was told I can do whatever I like with the VIN and Body Tags, but the Compliance Plate and chassis number have to stay where the manufacturer put them.
However if the mods were extensive enough that it could be classified as an "Individually Constructed Vehicle" then you effectively become the manufacturer and you can do what you like (within the ADRs).
Not sure about QLD but in NSW you can register a car without it's Compliance Plate providing it's been registered before, the chassis number is always the primary identifier.
