'Purple' build thread
589 replies to this topic
#126 Statler
  • 6,317 posts
Posted 17 April 2012 - 12:51 PM
A couple of pics of the x-member.
About 1/2hr work & $25 in steel. If you are doing this, slide the angle sections 'outwards' & tighten the bolts before tacking. That way, when the metal shrinks in the welding process, the bolt holes align again. :)
A small amount needed removed from the cast brace on the box. Simply a small notch with the grinder.
Up & fitted.
Next on the adjenda....... pipes.
Take 1 fresh set of Pacemakers, a high lift jack, a smashed finger & a whole bunch of swear words..... & end up with this...
Spot the problem?
#127 _nial8r_
_nial8r_
Posted 17 April 2012 - 04:34 PM
Prepping the new bar for install.
Proof the engine is in.
hey Col what water pump are you using to get the gilmers to line up.
#128 Statler
  • 6,317 posts
Posted 17 April 2012 - 11:05 PM
It's a stock VN pump. The waterpump pulley just scrubbs. Nothing a minute with the flap disc wont fix.
I don't think i'm going to end up using the Gilmer. Not because i don't want to, but because i might not need to :)
For the first time since conception, ( & a trap for young players. lol) , i'm thinking about deviating from the original concept. Ironic that i'm usually the voice saying ' make a plan & stick to it'!
The pipes are going to need some manual bending to make them right. I figure if the finish is going to be marked, i may as well make them fit right, then get them HPC coated.
Things are happening.
Edited by Statler, 17 April 2012 - 11:12 PM.
#129 _Quagmire_
_Quagmire_
Posted 17 April 2012 - 11:33 PM
lol
your lucky
when i fitted mine to a hx ute many moons ago
I smashed 2 spark plugs..had a fight with the ex misses cause she brought the wrong ones(186 not holden v8),
couldn't get the auto colum selector rod to clear
,scrached and marked the paint to the point i shoundn't have wasted my $$$
,countless scrapes/skinned knucles/swear words shouted
and the rear exhaust/mufflers fell off on the trip home....and i had the use of a hoist to do all this after work hours on a saturday
lucky it had a frdge full of beers at the time :)
oh the things we do when we are young dumb and....
#130 Statler
  • 6,317 posts
Posted 20 April 2012 - 02:44 PM
Did someone say it needed some balls?
#131 Ruts
Ruts
    How Fast!?
  • 1,118 posts
  • Car:Blown A9X replica, Black SS hatchback, LH SLR5000
Posted 21 April 2012 - 11:25 AM
Doesn't look like a 6-71 to me.......ppffffttttt.
#132 _Bomber Watson_
Posted 21 April 2012 - 02:57 PM
I cant wait to see how you join a gilmer belt up to a serpentine belt.....
#133 xu2308
xu2308
    Grail Hunter
  • 4,704 posts
  • Name:AL
Posted 21 April 2012 - 04:00 PM
Awesome Col, cant wait when you get it running, a video please of the beast purrrrrrrrimg
#134 Statler
  • 6,317 posts
Posted 21 April 2012 - 04:39 PM
The Gilmer has to come off Dj. I can't use it now.
I just sat the airpump on there to check for clearance. More modification required! :banghead:
#135 _Bomber Watson_
Posted 21 April 2012 - 05:39 PM
Thank god, i do so hate those things, on anything thats not supercharged.....Your supercharger doesnt count though lol.
#136 Statler
  • 6,317 posts
Posted 18 May 2012 - 01:49 PM
Lots of little things are holding me up, but i'm slowly making progress.
#137 _greenmachine215_
_greenmachine215_
Posted 18 May 2012 - 04:55 PM
Those pacemakers are a pig fit, makes you wonder if they used a torana
That had a front end collision as their trial fitting unit,becuase ive never heard of a set of pipes that just drop in with no hassles execpt custom made headers.
Lookin good tho, cant wait to see some engine output figures
#138 Statler
  • 6,317 posts
Posted 18 May 2012 - 11:38 PM
I'm a big fan of Pacemakers. This is the only set i have ever had that didn't fit out of the box. They aren't that far out, & i can use an oxy. lol
Bloody fuel injectors have been doing my head in. It's been one big comedy of errors. Hopefully sorted now though.
#139 Statler
  • 6,317 posts
Posted 29 May 2012 - 02:41 PM
New PWR radiator.
Kinda wishing they had drilled the mounting holes though.
I was just checking for clearance around the crank pulley.
#140 _greenmachine215_
_greenmachine215_
Posted 29 May 2012 - 07:38 PM
Rad looks nice n spicey!
What fan setup are you gonna run?
#141 308mate
308mate
  • 523 posts
  • Name:scott
  • Car:76 SS hatch (Royal Plum, Chevron Chamois interior), HQish Van (Orchid Metallic)
Posted 16 June 2012 - 08:41 PM
Nice mate. Luv the colour. Looks to be royal plum? same colour as my hatch was from factory. SLow & steady, enjoy....
#142 Statler
  • 6,317 posts
Posted 16 June 2012 - 10:43 PM
I bought the fan set up from PWR as well. It's mounted on the inside.
No Scott, not Royal Plumb. It's just...... ummm.... purple. ;)
#143 _Jol_
_Jol_
Posted 17 August 2012 - 08:24 AM
Looks great wish I was this far with mine
#144 _UCA350_
_UCA350_
Posted 29 October 2012 - 09:58 AM
About to tackle the same conversion.
What engine mounts did you use, Torana or HQ?,
I can see you used a UC crossmember but I will be staying with the original cross member.
Have you fitted a distributer yet?
#145 Statler
  • 6,317 posts
Posted 29 October 2012 - 11:09 AM
Torana mounts. I have been trying to use stock parts so anyone wanting to do similar can copy it.
Once the 'bunch of bananas' has been removed the distrubutor can be 'found' again. The kit comes with a new intake manifold which gives much better access to the dizzy. I am guessing at this point, but if i need to access/remove the dizzy, then i will need to remove the intake pipe first.
I'm waiting on the remodified fan box coming back from the paintshop so i can fit the intake.
#146 _UCA350_
_UCA350_
Posted 29 October 2012 - 11:57 AM
I will be running a carb setup but with Torana mounts I should be ok with distributer clearence.
Did you have any issues with the headers and the cable setup on the bellhousing.
Looks like your brake booster cleared the VN covers.
Any other tips would be helpful.
#147 Statler
  • 6,317 posts
Posted 29 October 2012 - 02:34 PM
You have to modify the heater box to get clearance on the 304 tappet covers.
I haven't fitted the clutch cable as yet, but i don't forsee any clearance issues.
#148 _LH SLR 3300_
_LH SLR 3300_
Posted 29 October 2012 - 07:28 PM
Unusual you had to modify your heaterbox to clear the rocker cover, my orange LH with VN headed 5.0ltr didn't need it, both my EFI 5.0ltr LHs needed modification to clear the fuel rail though.
#149 Statler
  • 6,317 posts
Posted 29 October 2012 - 07:34 PM
What he said ^ :)
#150 Statler
  • 6,317 posts
Posted 20 November 2012 - 02:11 PM
Remodified, modified heater box.
I finally have enough clearance for the blow off valve. :)
Edited by Statler, 20 November 2012 - 02:12 PM.
