Nissan 4 spots tutorial to LH.
108 replies to this topic
#26 _rorym_
Posted 20 June 2009 - 10:05 PM
Lets not get too carried away boys! lol!
#27 AbsynthHatch
AbsynthHatch
  • 736 posts
  • Name:Mark
Posted 20 June 2009 - 10:18 PM
Thanks Rory, a superb effort once again. I have cut my caliper mounts out of 12mm aluminum plate, you mention that you have had problems with bending. Would I be better off starting again using steel plate? :cry:
#28 _brett_32i_
_brett_32i_
Posted 20 June 2009 - 10:30 PM
i cant believe neil didnt say anything?
hope i dont upset anyone, but i wouldnt be recommending people follow that conversion.
That bracket is very narrow, and there is drilling, tapping, grinding going on to the stub axle.
heres my version..Posted Image
#29 AbsynthHatch
AbsynthHatch
  • 736 posts
  • Name:Mark
Posted 20 June 2009 - 10:34 PM
What calipers, stubs etc have you used Brett?
#30 _brett_32i_
_brett_32i_
Posted 20 June 2009 - 10:38 PM
by memory..
ea? hubs.
uc stubs
callipers were the sumitumo ones. not sure if they are 33 or 32, gts or gtr?
edit
oh and use the qfm pads!! i have the h somethings, the ones under the a1's
Edited by brett_32i, 20 June 2009 - 10:43 PM.
#31 _rocket_
_rocket_
Posted 20 June 2009 - 10:57 PM
Wheels vary..15" Simmons dont go anywhere near fitting but 14" Hotwires do...so you will need to check your wheels offset and mount face/spokes if they clear. The NISSAN comes off tomorrow.
If you use a 10mm spacer, they clear the nuts on the back of 15x9.5 inch Simmons, thats what Im running on the front.
#32 _rorym_
Posted 20 June 2009 - 11:14 PM
What size rim Brett? I am guessing it is not a 14 or 15" as needed by Rocket and me. This version works for us. The bracket is steel, not alloy..if you can bend it be my guest. The grinding is to bring the caliper in to clear said rims. Drilling and tapping a steel stub sits OK with me.
Edited by rorym, 20 June 2009 - 11:21 PM.
#33 _brett_32i_
_brett_32i_
Posted 20 June 2009 - 11:23 PM
my bracket is steel too.
16" rim
#34 _rocket_
_rocket_
Posted 21 June 2009 - 07:46 AM
When I got this conversion make up about 5 yrs ago, the company that I used, Race Engineering in Sumner Pk, Brisbane designed it to use 15 in simmons, thats why we modded the stubs, as Rory says to use smaller wheels, a 14 x8 Hotwire fits straight on aswell. This conversion is not something I just thought up, it was designed and made by this company to suit what I needed it for. I havent had any problems with the alloy bracket, but if steel makes you feel more confident, way to go.
#35 _rocket_
_rocket_
Posted 21 June 2009 - 07:54 AM
The calipers are GTR 32 import units.
#36 _torana_umunga74_
_torana_umunga74_
Posted 21 June 2009 - 05:06 PM
yeah i dont want 16" wheels, i want to upgrade the brakes and too much is not enough. none of this looks out of my reach.. wat steering arms are they?
#37 _rorym_
Posted 21 June 2009 - 05:18 PM
UC.
#38 _rocket_
_rocket_
Posted 21 June 2009 - 06:16 PM
Standard lx on mine.
#39 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 21 June 2009 - 07:42 PM
Just looking at Rory's and Brett's brackets I would go with the Torana stub. This allows the bracket to be a bit beefier and doesn't upset the steering geometry.
Nice work guys, well done !!
#40 _rorym_
Posted 22 June 2009 - 06:57 PM
But cant fit 15s Struggler...a requirement for Rocket and me.
#41 _Racelx_
_Racelx_
Posted 22 June 2009 - 08:05 PM
Another awesome post Rory, Between this one and the R31 skyline diff post your research and ingenuity have been invaluable.
As I will be running VT 296 x 28mm discs with 16" V5 Simmons I gather I will need to modify the template to suit the larger discs. Any ideas on the size difference or whether you believe the standard template will suffice
Tim
#42 _rorym_
Posted 22 June 2009 - 08:16 PM
Your bracket would be more like Bretts Tim..You would get away without the grinding and drilling thing because of the bigger wheels...If you trial fit with alloy brackets to get your template you could then get them done in steel. The basics are there..just a bit of fiddling for your application. Looking at Bretts pic, you could nearly guessimate the size and differences just looking at/measuring the bolt up holes..if you get my drift.
#43 _evil UC hatch_
_evil UC hatch_
Posted 22 June 2009 - 08:23 PM
Diddn't Datto mention that the other larger callipers are to suit a 296mm rotor, would RaceLX just be able to use that on the same bracket??
#44 _rorym_
Posted 22 June 2009 - 09:05 PM
DOH!..Of course he would! I did it already!..Go back to the pic with the pad hanging outside the disc...thats the 296 caliper.Thanks Jas!
#45 _evil UC hatch_
_evil UC hatch_
Posted 22 June 2009 - 09:52 PM
No worries Rory, I had actually been thinking of that last night, I will most likley be running 16" wheels so the clearance wont be an issue then. I will have to have a play around with it once I get myself an income again
#46 _Racelx_
_Racelx_
Posted 23 June 2009 - 07:48 AM
Hi Jason
I did look at the AP Racing calipers that Datto has talked about previously, however looking at around $1500 for a pair compared to around $400 for nissan 4 spots (rebuilt) I cant really justify the additional $1000 odd dollars despite the fact AP racing ones are the ducks guts.
Now if i had won the $50 mill........
#47 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 23 June 2009 - 09:07 AM
Why not ? The caliper mounts on a Torana stub are closer to the spindle than they are on an HQ stub axle. What am I missing ???
#48 76lxhatch
  • 7,205 posts
Posted 23 June 2009 - 09:13 AM
I was wondering that too Struggler, I can only assume that the bolts interfere with each other - perhaps where the new hole needs to be drilled in the HQ stub would be halfway across the standard hole on a Torana stub?
#49 MRLXSS
  • 12,413 posts
Posted 23 June 2009 - 09:18 AM
Wow! Great tutorial Rory!
Thanks for sharing and also everyone else's insight! It's what this forum is all about!
This might be a conversion for when I upgrade my front end next time! For the moment HZ brakes are pretty good! HAHA!
#50 _rorym_
Posted 23 June 2009 - 05:41 PM
^^ Have a look at Bretts pic and the rim clearance. Also bearing in mind as I said previously, different rims give different clearences.Thats a 16" in the pic I am guessing...unless I missed what you are refering to?
Edited by rorym, 23 June 2009 - 05:44 PM.
