MRLXSS - The Complete Build Thread
839 replies to this topic
#301 _greenmachine215_
_greenmachine215_
Posted 21 July 2010 - 09:47 PM
There are the larry perkins kits by ACL And as far as i know they havnt made them for a number of years
But they were a very popular kit to buy price wise for performance was really good without going overboard.
Id check the crank for numbers and perhaps do a google search or just pop into your local speedshop, Definately never seen a stock crank in that decribed form.
slap it back together and throw it on the dyno, If you like the figures keep it, if not Stroke it :)
#302 _SS Hatchback_
_SS Hatchback_
Posted 21 July 2010 - 09:50 PM
Well it went hard enough for him to write it off, anyway its always a good start with those heads and manifold as you would think anyone putting those on has done some work to it hey, hope all turns out better than you expected and this should surely drop the numbers for you at Heathcote :spoton:
#303 MRLXSS
  • 12,413 posts
Posted 21 July 2010 - 10:01 PM
Bring on at least Club 12!
#304 76lxhatch
  • 7,205 posts
Posted 21 July 2010 - 10:10 PM
was told it was a 330 stroker
Just measure the big end journals
#305 _@milco@_
_@milco@_
Posted 22 July 2010 - 11:33 PM
yeah the big ends should be 2inch, and a stroker crank will look like a normal holden crank because its a holden crank offset ground ( as you know i.e your 253 stroker)
so it should have a holden crank 2 inch big ends, chev or hemi rods and chev pistons..... also you should clean up one piston top and try and get the part number off it to work out what it is...
#306 _Brad1979UC_
_Brad1979UC_
Posted 22 July 2010 - 11:57 PM
He told me that when he bought it, he was told it was a 330 stroker with a big cam and 'it went really hard' hahaha
So yeah, keen to pull it apart and suss it out
HAHA reminds me of my motor, turns out it was a 330, DID have a massive cam, but valves and pushrods were bent as! Always imperative to strip em down first ey to see what you really scored. Unfortunate about the non-stroke, I think you'll still be able to put together a damn hot combo though. It's quite exiting putting one together I reckon!
all this talk about stroking leaves us open for rodomo to make a 'what's with it with you young blokes and stroking?' type comment :o
#307 MRLXSS
  • 12,413 posts
Posted 23 July 2010 - 08:37 AM
Exactly my thoughts... First thing i looked for was different pistons. I'm pretty sure i can see 'Holden' pressed on the pistons from the underside. Not to worry! It'll be interesting to pull the motor down and see what it all is.
Yeah, the fun and games of buying 2nd hand! The best thing though is you get everything so much cheaper! I am keen to pull it down though, because it is exciting putting it together and knowing everything about it!!!
HAHA! I have been waiting for Brodomo to chime in...
Edited by MRLXSS, 23 July 2010 - 08:39 AM.
#308 orangeLJ
Posted 23 July 2010 - 10:27 AM
whats with all you mexicans and stroking....
#309 _lxss5l_
_lxss5l_
Posted 24 July 2010 - 02:11 AM
Hi matt. I've been reeding this thred on and off for a wile now I always get puled of the computer. I have to say You've got a dam great looking car from everything you've done to it and I like the interior . And you're new motor looks clean sounds interesting I recon it should go alright . So you have hq a9x style front stubaxles with the harrop steering arms? did you have eny dramers with them not having eny stopers?
#310 MRLXSS
  • 12,413 posts
Posted 16 August 2010 - 06:10 PM
Here are a few pics of the progress!
Excuse the eyesore of an engine bay... That is getting fixed now! No more mismatched colours and messy wiring!
Still lower than a few torrys i see getting around and its got no motor in it!!!
Update with the motor... Just had a Stage 1 Crow cam, standard pistons and rods (But they are A9L rods). Still not sure what the crank is, but is in good nick and is definetely aftermarket of some form....
It's pulled right down now as you can see in the pics, It's going to get a new cam (Still have to suss out what one) Then we tidied up and put back together... I really really want to put in a 355 crank etc in it now, but the funds don't agree. So it'll be a hot 308 for the moment that will have parts that will be interchangable when i go the next step on the 355.
Huge thanks to Ryan for coming over on Sunday and giving me a hand....
#311 _Barman_
_Barman_
Posted 16 August 2010 - 06:31 PM
I just seen that "old" hatchback in the background there and im willing to come pic it up and get it out of your way OK...
#312 MRLXSS
  • 12,413 posts
Posted 16 August 2010 - 09:52 PM
HAHA! Dreaming Barman! One day i'll get to it!
#313 _Brad1979UC_
_Brad1979UC_
Posted 16 August 2010 - 10:42 PM
Nice work, not sure where you like getting your cam(s) from Matt but I'd recommend speaking to Trent or Clive from clive cams in Ferntree Gully, great guys, knew their stuff well, they ground the cam I currently have in mine and refaced my lifters (clevo lifters apparently :P), Trent even helped me with a dizzy after hours :D. Mines grind no. 241 if you want to compare.
But yea looking good :spoton:
#314 _mick74lh_
_mick74lh_
Posted 16 August 2010 - 11:15 PM
Matt this is gonna be ace! Good luck getting it all together. Did you end up finding out what that vibration was?
Mate mine sits like a 4WD with no engine in it!
#315 MRLXSS
  • 12,413 posts
Posted 17 August 2010 - 09:03 AM
Sweet Brad, you're not the first person to mention Clive Cams, I actually think Justin mentioned them in comparison to going a crane cam. What did the custom grind cam cost you?
The vibration was the uni joints, when i dropped the tail shaft the rear uni was just mushed! I think i need to address my pinion angle.
#316 LXCHEV
LXCHEV
  • 3,609 posts
  • Car:'76 LX - 383 Chev
Posted 17 August 2010 - 10:55 AM
I would also recommend Clive Cams. They did my original cam in the 383, and to date it was still the best cam ever! As Brad said, they also reface lifters to make sure they're perfect. (Even "out-of-the-box" brand new lifters are not perfect), so this is money well spent. I can't remember prices off the top of my head, but they are very good. Plus they're nice and local to you as well.
Good to see some progress, bring on the smooth (and orange) engine bay!!! Yeee har.
#317 _Brad1979UC_
_Brad1979UC_
Posted 17 August 2010 - 07:05 PM
Hey mate dug up my receipt, was $204 ex gst, but then of course add a set of lifters on top of that.
I actually found out about them when I was ringing around trying to find out who ground the monsterous cam that was in the stroker when I got it, turns out it was Clive and advised me that I didn't want to put that stick back in my motor through wear marks which upon my first inspection were not visible to me, and that it was just too big for my application anyway, and made me exactly what I wanted.
#318 _mick74lh_
_mick74lh_
Posted 17 August 2010 - 08:14 PM
Ar yeah I had the same problem with my rear uni. Just a worrying vibration under load that would come and go. Turns out the cups were missing bits and all the roller bearings had fallen out. That drag day probably finished yours off.
Hey Clive cams were good. I went there with Brad when he got his cam for his V8 and Clive himself came out, took a look at the damaged lifters we'd brought in and said "those lifters are f--ked! Anything else you wanna know?" Ha ha very funny guy.
#319 MRLXSS
  • 12,413 posts
Posted 17 August 2010 - 10:27 PM
Wow, that is cheap!!! I was expecting around the $400 mark and upwards... I'll definetly go down and have a chat with clive and suss something out.
Yeah, the roller bearings in my caps had been turned into a metallic grease! LOL!! All fixed now though, but its only a short term fix (until they wear out again)
Edited by MRLXSS, 17 August 2010 - 10:30 PM.
#320 _mick74lh_
_mick74lh_
Posted 18 August 2010 - 10:16 AM
How would you possibly adjust/alter your pinion angle?
#321 MRLXSS
  • 12,413 posts
Posted 18 August 2010 - 10:28 AM
To be perfectly honest, I'm not sure... Some talk about making adjustable top trailing arms... Others have said if you put a big arse 3" Tailshaft and unis on, that will fix the problem. To be honest i'm not sure...
#322 orangeLJ
Posted 18 August 2010 - 10:39 AM
Id say it depends on where the problem lies, you might have to raise/lower the gearbox mount too.
You really need to get under it with the engine and box in it and see where the dramas are.
#323 MRLXSS
  • 12,413 posts
Posted 18 August 2010 - 10:59 AM
^ Yeah that's another point Chris, I guess there is more than one way to skin a cat. Needs to get up on a 4p Hoist to see how it all sits when under weight...
#324 orangeLJ
Posted 18 August 2010 - 11:28 AM
Yeah thats the big thing, needs the weight on the wheels to have the suspension in the right spot.
Ive never really had to deal with it much, little bit when I put the celica box in the LJ, but its got a std diff, so it was only the gearbox that needed adjusting up and down.
There is a thread on here somewhere that discussed pinion angles and how to fix it. if you dare use the search function you MIGHT find it! haha.
also, reply to my email from yesterday douche rag!
#325 MRLXSS
  • 12,413 posts
Posted 19 August 2010 - 10:05 PM
Alrighty, Updates.
K-Frame is out and apart, got to clean it all up, re-paint it and press in you bushes and ball-joints. I have to get this car handling better! Found a few small things that would have had negative effects on the handling. So they will be addressed and fixed.
Whats the best way to clean up the Kframe and control arms etc for paint? Will a wire wheel do the trick? Or Get them blasted?
Here are a few crappy pics.
