Torana without front swaybar
18 replies to this topic
#1 Heath
  • 18,375 posts
Posted 03 July 2009 - 04:20 PM
I was under the impression that all LH-UC, L4-V8 cars were fitted with a front swaybar (only one type) from the factory.
Is this not the case?
The K-Frame in my car doesn't have holes for the swaybar's U-bolts; where the swaybar is clamped to the crossmember towards the rear of it
(my car came with no front swaybar).
The lwr wishbones have the angled boss kinda thing for the connecting shaft thing to fit through. Was there a different kind of swaybar which mounted in a different style? Didn't get clamped against the crossmember?
I think it is an LH L6/V8 K-frame
#2 76lxhatch
  • 7,199 posts
Posted 03 July 2009 - 04:39 PM
No I know a lot of the early ones didn't have them at all, changed mid LX I believe. Mine's a late 76 LX 253 V8 and it never had one, they have the holes in the LCA but not in the cross member as you've described. You can just drill the cross member and fit one as long as it doesn't foul on your extractors.
Edit: mine's an SS too
Edited by 76lxhatch, 03 July 2009 - 04:42 PM.
#3 _LH SLR 3300_
_LH SLR 3300_
Posted 03 July 2009 - 04:41 PM
From my understanding all RTS (Radial Tuned Suspension) equipped Toranas 4,6 & V8 got swaybars from factory, but pre-RTS Toranas only got swaybars from factory on V8 & or SLR models. I'm sure more knowledgeable people may correct me.
#4 _rorym_
Posted 03 July 2009 - 06:57 PM
My "Spotlight on" says..
LH
SLR Stabiliser bar front
LX
Front bar SLR and SS Hatchback
Rear bar
SLR/SS and V8 models.
Explains why they handled like shit...
RTS Post April 77
Front bar all models.
Rear bar all models
Explains why they handled so much better.
#5 _nial8r_
_nial8r_
Posted 03 July 2009 - 07:56 PM
come to think of it my clucker dont have a sway bar either........... :huh:
#6 Statler
  • 6,307 posts
Posted 03 July 2009 - 10:27 PM
Didn't the A9X have a front swaybar which was 'reversed'? i.e, went forward from the control arms?
#7 _Squarepants_
_Squarepants_
Posted 03 July 2009 - 10:46 PM
I would like to fit this design to my car, as the front swaybar mounts are the first thing to hit the ground when my car bottoms out. I've replaced them 3 times due to damage.
One steering specialist (when I was getting a wheel alignment) asked me if I had been jumping my car!
One day, when I have too much money...
#8 ToRunYa
ToRunYa
  • 2,073 posts
  • Name:Em
Posted 04 July 2009 - 03:04 AM
boris never had a swaybar, it got fitted when the v8 went in...
#9 rodomo
  • 18,030 posts
Posted 04 July 2009 - 03:14 AM
Skip the front sway bar.
Read your sig.
Just don't try and go around corners. :tease:
Edited by rodomo, 04 July 2009 - 03:17 AM.
#10 Toranavista
Toranavista
    'Let There Be Rock' 1977
  • 2,862 posts
Posted 04 July 2009 - 08:46 AM
Not in standard road form from factory.
Also RTS was first released with the Sunbirds built from around Sept 1976. The official release was November 1976.
All others received the update from build dates of around Feb 1977. offical release not sure of but probably that April 1977 date mentioned by Rorym.
#11 micklx
micklx
  • 1,785 posts
Posted 04 July 2009 - 10:33 PM
Probably better for them to hit the ground, than the extractors, which is the first thing on many cars.
#12 _Kermit SLR_
_Kermit SLR_
Posted 05 July 2009 - 09:52 AM
Were all sway bars the same diameter? LH, LX, UC? All interchangeable?
#13 Heath
  • 18,375 posts
Posted 05 July 2009 - 06:43 PM
Thanks guys!
#14 _Torrie_Man_
_Torrie_Man_
Posted 07 July 2009 - 10:55 PM
Is this what you mean?
Edited by Torrie_Man, 07 July 2009 - 10:57 PM.
#15 _Squarepants_
_Squarepants_
Posted 08 July 2009 - 05:11 PM
Rogee! :spoton:
What brand is that? Whiteline?
#16 76lxhatch
  • 7,199 posts
Posted 08 July 2009 - 05:19 PM
Yep looks like the Whiteline one, mine is a grey bar but everything else is identical
#17 _Torrie_Man_
_Torrie_Man_
Posted 08 July 2009 - 06:44 PM
it is a whiteline bar
#18 _Squarepants_
_Squarepants_
Posted 08 July 2009 - 07:05 PM
How sturdy are those mounting brackets? They look like they might flex a bit.
#19 76lxhatch
  • 7,199 posts
Posted 08 July 2009 - 09:30 PM
They're quite solid against up/down movement, thicker material than the control arms
