Mini tubs for lx hatch
_L76LXHATCH_
Posted 05 July 2009 - 11:06 PM
Posted 06 July 2009 - 10:01 AM
If anything a hatch would be easier.
Hope this helps.
_L76LXHATCH_
Posted 06 July 2009 - 02:38 PM
There are some pics and a bit of a rundown of what I am doing to my 4 door in this thread.... http://www.gmh-toran...showtopic=35451
Hope this helps.
Cheers for that mate it was pretty helpful!!! Im just toying up if I should move those back rails for some more room as you have done?? Im kind of trying to stay legal with it all as it will have to go over the pits when Im done as Im in the slow process of sloting a L76 Gen 4 into an LX Hatch. Bit of homework is required but should be worth it!!!!
Motors runing a fairly mild cam and a few other little bits and pieces and should be somewhere around 500fwhp (for now!!), Should get up and go!! and be a bit of fun to drive..
Cheers for the help!!
_sshatch355_
Posted 06 July 2009 - 09:48 PM
anything in particular u want to see or just general all over??
_L76LXHATCH_
Posted 06 July 2009 - 11:30 PM
Any info you have on how you did it would be a great help as I dont really want to have to cut the rails at all as it might affect me when I go over the pits??
Email me or post pics and info on here? Whatevers easier for you? Some detailed pics would be great!!
Also did you shorten your diff up to suite the tubs(what lengh?) or offset your wheels? (what offset/size?)
Thanks for the help!
_greenmachine215_
Posted 07 July 2009 - 01:15 AM
If you get your diff cut short enough and wheel offsets right thats a good start, If you cut the inner gaurd out and weld it agains the chassis rail, remove the dust covers from the shocks and roll the gaurd lips you can just squeeze a 285 under there
i run 265's unflared with the above mods with no hassles, the next set of tyres will be 285's
Heres some pics to show what was done.
ROLLED OUTER GAURD LIPS
DUST COVERS REMOVED FROM SHOCKERS FOR CLEARANCE
Hope these pics help out a bit.
marc
_moot_
Posted 07 July 2009 - 07:21 AM
_moot_
Posted 07 July 2009 - 08:29 AM
also be aware that a 275 et street is 10 mm+ wider on the same rim than a normal 275/50. infact my 305/30/19's are the same width as a 275/50/15(wall to wall measurements)
Posted 07 July 2009 - 09:35 AM
In fact you can further beat the rail in at this point and fit a 26x10.5x 14 slick.
_L76LXHATCH_
Posted 07 July 2009 - 06:39 PM
Thinking of moving shocks inboard aswell anyway..
Hey greenmachine215 Would you know the lengh of your shortened diff?
Thanks guys, appreciate it!
