LXCHEV - The Ongoing Story of 'My Beast'
445 replies to this topic
#201 adrianh08
adrianh08
  • 219 posts
  • Name:Adrian Haynes
  • Car:1974 LH
Posted 02 August 2010 - 10:09 PM
Mate over the years ive seen some trashed engines at my old mans workshop and yours would certainly get an honourable mention!
I can only imagine the noise it made when it let go.
It is sad when faithful old engines decide to take an early retiremement package.
Best of luck getting the funds together and putting a new heart into the mighty Torana. (All Toranas are mighty!)
#202 LXCHEV
LXCHEV
  • 3,609 posts
  • Car:'76 LX - 383 Chev
Posted 02 August 2010 - 10:55 PM
Cheers guys for all the comments and words of encouragement. It does inspire me to push on and come up with the next battle plan. At least the title of this thread is very appropriate now "The Ongoing Story".... not sure if that's a good thing.... hahaha...
Anyway, Tiny - at the time it let go, I was at the top of 1st gear, a decent amount of revs, about to click 2nd, when the almighty shatter sound occurred. Now that I've seen the carnage, the sounds make a lot of sense, LOL. I knew it was serious, but in the time it took me to pull it apart, I'd talked myself around that it was only something minor :)
Andrew, cheers for the great advice as usual. I do like the idea of sourcing a 4 bolt 350 block. (What better excuse to upgrade from this 2 bolter). I'm keeping my eyes open, but in no hurry with the rebuild. If my stroker crank is stuffed, I might rebuild it as a plain jane 350 this time around. I've got some serious thinking and decision making ahead.
Edited by LXCHEV, 02 August 2010 - 10:56 PM.
#203 _BlownUC202_
_BlownUC202_
Posted 03 August 2010 - 11:47 AM
Ive seen a few 3516 cat engines do the same and most of the time its been apprentices doing valve sets wrong causing the valve bridge to come free and jam the valve open then it snaps and the piston starts to break up then it smashes through the liner in the end it throws a rod or 2 and you get this
sorry to go off topic a bit but thought id share some carnage pics.
#204 LXCHEV
LXCHEV
  • 3,609 posts
Posted 03 August 2010 - 12:01 PM
Nice!!
#205 _Gunmetal LH_
_Gunmetal LH_
Posted 03 August 2010 - 07:50 PM
A big one...
[url="]
#206 Tiny
Tiny
  • 10,018 posts
  • Name:Tiny
Posted 03 August 2010 - 08:46 PM
Interesting mate!
I mean it's a terrible situation, and one NO ONE hopes to ever be in, but as you said, it's done now and now just have to decide on what to do!!
Apparently E85 is being released commercially here in Caltex servos so i'm considering making a few "upgrades" to the Q! Hmmmmmm.....
Just another thought to add to the equation!
I know life takes a change in direction, Just make sure you will be happy with it rather than spending 80% of the money to get 50% of the enjoyment! (I look back on how i built the monaro and lament on whati could have done if i had of spent the WHOLE ammount all at once!)
ANyway mate, All the best with it, If theres anything i can do to help let me know!
(I've got a 400chev crank/rods/pistons sitting here out of the old engine you could have cheap ;P Just needs a grind/linish!)
Cheers!
#207 LXCHEV
LXCHEV
  • 3,609 posts
Posted 15 August 2010 - 11:25 PM
If piston bits got under the intake then they will be in every cylinder so check all the conrods for straightness. Chuck the pistons out. Get the crank checked to make sure its not bent.
Hey Struggler, just curious.... why do you say throw the pistons out?? Once I rip the bottom end apart, I was planning to have a professional go over my crank, rods, and pistons... if anything is salvageable, it will save me cash. I'd rather buy 1 new conrod and 1 new piston, as opposed to a full set of 8. Especially the pistons - they are SRP forgies, and haven't done huge km's.
#208 _BAILLIE_
_BAILLIE_
Posted 16 August 2010 - 02:23 AM
Wow, awesome pics.
You sure did it properly hey, but no, it wasn't your fault.
Always blame it on the apprentice. Posted Image
Which is great except when you are the apprentice..
Anyways, it's great that you can focus on the positives hey.
Definately chuck another 5 speed in it, imo, 1 more vote for that anyway.
Or you can just admit that you broke your car good and proper.
I'll help you out if you want, and trade you my VN V6 wagon for your busted Torry.
It's already got a 5 speed, although the motor in the VN may also cactus itself any day now too...
All the best mate, hope things work out ok : )
#209 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 16 August 2010 - 09:30 PM
Hi Brett, the shrapnel usually goes through the engine before it stops dead. Bits end up stuck between the piston and head/bore and cause damage that isn't initially obvious. When it all comes apart you will be surprised at the injuries. It just isn't worth the risk. No-one wants to blow up twice !!
Also 1x SRP will be about half the price of a full set.
If you can sleep at night knowing what 7 of your pistons have been through then fair enough. It is always the things you can't see that cause problems later. If you bought that engine to me and said throw it back together I wouldn't reuse the pistons or rods and I would be reluctant to reuse the crank without a grind and crack test (which would pay for a new 9000 series Scat crank anyway). When my engine suffered a similar fate I binned the lot, no sorry, I kept the rods for use as trophys. I can't afford to have it fly apart again.
JMHO.
#210 LXCHEV
LXCHEV
  • 3,609 posts
Posted 16 August 2010 - 10:37 PM
Cool, I will take that on board. I did price up an individual piston, and I'd be looking at $79.95 (U.S.) + postage (surprisingly cheap) - so you can see why I've been considering this. A new set of these pistons costs around $550 (U.S.)for 8. But as you've said, I'm not sure what my quality of sleep would be like each night if I did re-use all the current bits!!
PS. Tiny - thanks for the kind offer earlier too (on the 400 crank/rods/pistons). But if my crank is no good, then I'll end up going for a brand new aftermarket crank I think. But thanks mate!
Baillie, damn apprentices!! I'll pass on the VN, it's missing 2 cylinders for my taste :)
#211 _mick74lh_
_mick74lh_
Posted 16 August 2010 - 11:33 PM
Are you aiming to have it back on the road this summer Brett? Jees its a tough looking car!
#212 LXCHEV
LXCHEV
  • 3,609 posts
Posted 17 August 2010 - 10:05 AM
Cheers Mick! But nah, it's highly unlikely to see the road this Summer... more likely next year sometime. If I really wanted to, I could, but it's just that I have a thousand other priorities in life at the moment. Single income with wife and baby now, is easier said than done! I don't know who costs more - the wife or the baby, but combined, they really add up, LOL. I am seriously considering selling my hatchback, that would speed up the process nicely :)
#213 orangeLJ
Posted 17 August 2010 - 10:46 AM
If you plan to sell the hatch, let me know :)
Mum wants a hatch, Ray wants to buy her one AND Ive always had my eye on those wheels! haha
#214 _mick74lh_
_mick74lh_
Posted 17 August 2010 - 08:16 PM
I havent got a wife or a kid but I can understand not having enough time or money. Theres always something pinching both of those things.
#215 _TJ355_
_TJ355_
Posted 17 August 2010 - 09:02 PM
Sell the hatch and spend the coin on the beast i recon
#216 _BAILLIE_
_BAILLIE_
Posted 18 August 2010 - 09:32 PM
Baillie, damn apprentices!! I'll pass on the VN, it's missing 2 cylinders for my taste Posted Image
Yeh, wise choice. Damn P plate laws : )
I still miss my old hatch, wish i had never sold it.
My consolation was that i made sure she went to another good young kid who would treat her right and add the correct number of cylinders.
And i thought it was a bit tough in those days, nowadays i'm out of the market by a long shot.
Tell you what though, if you're ever feeling lonely, just put an ad up for a hatch and you'll get call after call of people wanting to speak with you : )
That was when the Trading Post was still a newspaper.
#217 _AD_75_
_AD_75_
Posted 19 August 2010 - 04:04 PM
I'd be inclined to keep the hatch over the sedan! it will appreciate and hold its value much better then a sedan..even one as nice as yours. Put a 350 in the hatch! :spoton:
#218 LXCHEV
LXCHEV
  • 3,609 posts
Posted 31 August 2010 - 11:03 PM
Well guess what... I finally got in touch with Jason and Jade to get some copies of the official Easternats photos from 2008. This was the year when I first developed my oil pressure problem (what I believe was wiped bearings)... not bad that I still got another 2 years out of the engine. Maybe the blow-up was not even related.. who knows. But let it be a lesson to everyone else - don't ignore changes in oil pressure!
Anyway... this is what caused it in the first place.. thanks again to Jason & Jadey for the pics!!!
Got a few other cool pics I will post over the next few days too....
#219 _SS Hatchback_
_SS Hatchback_
Posted 03 September 2010 - 09:21 PM
Thats some serious smoke there Brett, and hate to be the bearer of bad news but the older the wife and baby gets the more they cost so spend now :) also an excuse to get the Torry on the road faster
#220 LXCHEV
LXCHEV
  • 3,609 posts
Posted 22 July 2011 - 10:16 AM
Wow.. long time with no updates on my old pile of junk I still like to call a Torana!
Quite a few things have happened in the last year or so:
* Sold my LX hatchback :(
* Got retrenched from work :(
* Finally had a closer look at LXCHEV's bottom end - discovered everything is still mint, so I never had any bearing problems. The blow-up was 100% related to valve hitting piston. Nice to know :)
* All of a sudden, Brock is already 18 months old. He's been upgraded from baby status, to little monster toddler status. What happened?!!!
Anyway, these next photos may disturb and upset Torana fans.... please don't ban me from these forums for car abuse.....
She might be in a very sad state right now, but the local neighbourhood cats have taken a liking to it...
#221 DanWA
DanWA
  • 2,440 posts
  • Car:LS1 LX 4 Door
Posted 22 July 2011 - 10:25 AM
We've all got those pics mate
Can't wait for its resurrection!
#222 LXCHEV
LXCHEV
  • 3,609 posts
Posted 22 July 2011 - 11:02 AM
You and me both!
Guess what, I've also fitted up some sexy roof racks to the car....................... luckily it was back in 1998 though!
How's that for an old photo! They're 2 of my mates with my car, after a 5 hour drive to Mount Hotham. We were all just little 18 year olds :)
So should I re-fit the roof racks to LXCHEV?
#223 _mick74lh_
_mick74lh_
Posted 22 July 2011 - 12:52 PM
All the outside needs is a clean. I know you'll know all the little things about your own car that aren't perfect and shit you but last time I saw it, I thought it looked awesome. Good luck sorting out the motor. It really is a sweet car.
#224 Tiny
Tiny
  • 10,018 posts
  • Name:Tiny
Posted 22 July 2011 - 01:09 PM
Hey mate!!
Glad to hear you ha e fou d the time and energy to look at the beast again!
Don't feel bad mate, life travels quickly of late and with a youngun it's understandable that the car has to sit for a while!
I've actually had a few things done of late, must be something in the air!
#225 MRLXSS
  • 12,413 posts
Posted 22 July 2011 - 01:32 PM
Hurry up and get it back on the Road! I wanna go cruising with ya!
Have you got a goal date to have it sorted out yet? End of the year? It'd be great for us to both have our Torries at the Knox Cruise nights again!
