6 CYL Trimatic
21 replies to this topic
#1 _wjr2980_
_wjr2980_
Posted 09 July 2009 - 03:27 PM
As the title says, are 6 cylnder trimatics called a TH180??. Have been looking on the net for a shift kit for my tri box and came across one for a TH108. Can any one tell me if this will work and were they can be brought from.
#2 _Phantom10_
_Phantom10_
Posted 09 July 2009 - 03:31 PM
i was looking at one for my LC, went and saw our local Sprint and he can get them in
#3 76lxhatch
  • 7,208 posts
Posted 09 July 2009 - 04:49 PM
Yes they are a TH180 or a 3L30, much cheaper to buy rebuild kits etc from overseas.
Watch out though because yanks had lots of different versions, some with lock up converters, and the Aussie ones (esp V8) mostly had more clutches and pistons to suit.
#4 _wjr2980_
_wjr2980_
Posted 19 July 2009 - 07:32 PM
Can I use a v8 vl trimatic to replace my blue 202 holden 6 trimatic. I know I would need to swap the bellhousing ( im assuming they can be swapped over ) but is there anything else that would need doing??
#5 76lxhatch
  • 7,208 posts
Posted 19 July 2009 - 07:40 PM
Umm, it can be done but I can't remember whether the input shaft setup is different for the V8 converter or not, same length so I'm thinking it must be the same. Aside from that the V8 one will have more clutches and different shift control springs but that won't be a major issue.
If you wanted to stick with 6 cylinder specs you can build one good trans out of the two, just remove a couple of clutches from the V8 one and put the piston and input shaft from the six cylinder version in it (plus the shift control springs in the valve body).
#6 _Bomber Watson_
Im running a v8 box behind my six with a bell housing swap, no worries.
But i wouldent recommend trying the swap yourself if your not handy with auto's.
#7 _wjr2980_
_wjr2980_
Posted 20 July 2009 - 05:39 PM
Sorry guys its not a v8 trimatic but a rb30 turbo trimatic. Is it still just a matter of changing the bell housing on this model also or is the input shaft different also??
#8 _Drag lc_
_Drag lc_
Posted 20 July 2009 - 07:20 PM
trimatic= t180
doubt a auto that late model would fit 202.
cheers hayden
#9 76lxhatch
  • 7,208 posts
Posted 20 July 2009 - 07:47 PM
^^^ Huh? All Trimatics/TH180s/3L30s are the same basic trans
Didn't realise that the Trimatic was available behind the Nissan motor but I guess that would make sense if the Jap box is not up to the turbo (or maybe it has been changed). Should change over nonetheless
#10 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Posted 21 July 2009 - 04:53 PM
the auto behind the RB30 was a jatco 4 speed.
#11 _@milco@_
_@milco@_
Posted 22 July 2009 - 12:33 PM
yep ^^^
#12 _oldjohnno_
_oldjohnno_
Posted 27 July 2009 - 07:22 AM
If you swap bellhousings on a tri you should make/borrow an alignment tool to make sure it's properly centred.
Trimatics were also used on Geminis and these are a source of el-cheapo high-stall (around 2500-3000 behind a 202) convertors.
#13 claysummers
claysummers
  • 3,641 posts
  • Name:Clay
Posted 01 September 2020 - 07:30 PM
Old thread I know but hey.
Picked up a six cylinder trimatic today for $30 and wondering what it might be out of. The ID plate has the painted letters polished off but it has a calibration and maybe a serial number stamped on it. It has a black plastic converter cover, electric kickdown and passenger side shift shaft. I just got it to dummy up in my EK van along with a 149 bare block for $10 as they were ridiculously cheap.
I notice there is provision in the case for driver side shift which is what suits the setup I am using, EK hydramatic column shift and wondering if the brains trust can advise if it is straightforward to change sides for the shifter shaft.
I do have a HQ trimatic service manual as well as Google but as I am very lazy I thought I would ask here first.
Clay
#14 yel327
  • 13,661 posts
Posted 01 September 2020 - 08:36 PM
Left shift Trimatic can come from console shift HT or HG but these aren’t electric kick down so it must be from a UC, VB-VK or some WB. The Trimatic base (TH180) was a left shift box and was modified for RH shift by GMH using an internal crossover setup. So to modify it you’ll need another box for the mechanism and also an auto trans shop to do it for you. Best bet is to find another RH shift box, any column shift HT to WB or any HQ-HZ or LH-LX plus even some UC and rebuild it using good bits from both. They aren’t hard to find, as a 6cyl box are still basically scrap alloy. Even look in Coronas with Starfire or in Gemini and see what side the selector is on.
#15 yel327
  • 13,661 posts
Posted 01 September 2020 - 08:57 PM
Here is a good one from a HQ in Sydney, $80:
https://www.gumtree....nder/1255969372
Another in QLD with some 186 shaped scrap metal with it for $120:
https://www.gumtree....ator/1255686338
Another in QLD for $100:
https://www.gumtree....rbox/1255215721
#16 claysummers
claysummers
  • 3,641 posts
  • Name:Clay
Posted 02 September 2020 - 08:00 AM
Thanks Byron. I already have a few of these trans. Meant to say it has the early bell housing with bottom cut off. VC VK have the later full bell housing so are ruled out.
I thought the plastic converter cover, assuming original, might be a giveaway and I am speculating WB or VB.
I have the shifter set up already using a modified EK Hydramatic column shift with powerglide quadrant indicator lens and HZ shift gate. Not a collapsible column but acceptable for 202 in SA at least.
It will do as a dummy for the van build and may be of use for parts to rebuild one of the others.
#17 yel327
  • 13,661 posts
Posted 02 September 2020 - 08:07 AM
Not all the later ones have a full bellhousing. I used one from a VK 3.3 EFI in my WB 1-tonner in the early 90's, it was a low kM car that had an under-dash fire. It was a half type bellhousing and was the original box for the car. I have seen a mix of both in Commodore, mainly 4cyl and 2.85 that have had the full bellhousing. I also bought a VK EFI engine around 1992 to put in my LX, and it had the half type bellhousing as well before I separated it (used a manual box).
#18 claysummers
claysummers
  • 3,641 posts
  • Name:Clay
Posted 02 September 2020 - 08:38 AM
Thanks Byron. Learnt something.
#19 UCSLE
UCSLE
  • 710 posts
  • Name:troy
  • Car:Goggomobil
Posted 02 September 2020 - 12:38 PM
the vk trimatic i had was a half type bellhousing with a hole in the top of the bellhousing for the est pickup .
if i remember right the case will need drilling for the crossover shaft to convert
#20 claysummers
claysummers
  • 3,641 posts
  • Name:Clay
Posted 02 September 2020 - 04:10 PM
Cheers troy you've nailed it wondered what the funny hole was. Should be good calibration for a warm blue motor.
I had an injected VK berlina. Maybe because they are stronger, it had the full bell housing. Was a good thing in a way. The bells and whistles were crap and radiator and exhaust leaky. The stereo died. The timing gear went between port Augusta and iron knob. But it got us up and down the oodnadatta track and merienie loop road to Uluru and hermansburg and back. I used to sit and give it throttle on the brake and smoke the rears a bit and it never complained once the bugs were fixed.fb100b73a1dd07a81cca819687621d55.jpga95f6ad3e302f313960618417becf04e.jpg
#21 claysummers
claysummers
  • 3,641 posts
  • Name:Clay
Posted 02 September 2020 - 04:14 PM
Probably wouldn't bother if I have to convert sides as I have two others
#22 yel327
  • 13,661 posts
Posted 02 September 2020 - 04:24 PM
The engine it was fitted to in a VK is basically identical to a blue motor, just has the EST rather than a normal HEI dizzy. Only the VK carby engine had EST, the EFI engine had a normal blue type dizzy. The EFI Trimatics I've had were the normal bellhousing with traditional cover however the VK service manual supplement reckons the EST has the open converter bellhousing and the EFI has the closed one. The calibration is different for the EFI engine. I think it had a different converter too. The VK service manual supplement lists all teh differences between them.
LP is the carby VK Trimatic. LR is the EFI engine.
