Brown Davis Drop Tank Measurements
32 replies to this topic
#1 ls2lxhatch
  • 5,332 posts
Posted 18 July 2009 - 12:08 AM
Could someone please measure how wide the chamfers are on a Brown Davis drop tank?
#2 its Paul
its Paul
    Formerly lx8vd77
  • 1,577 posts
  • Name:Paul
  • Car:LXSS, VUSS, VESSv & the mighty HB
Posted 18 July 2009 - 08:26 AM
I made mine 25mm in and 25mm down giving it a 35mm width, this was copied from a Brown & Davis tank (all other dimensions differ).
Without hijacking your thread do you or anyone else know where I and get the alloy fitting for the sender??
#3 _ass308_
_ass308_
Posted 18 July 2009 - 08:27 AM
about 30mm max,and i didnt measure the top.i cant get to it.
thats a measurement from the bottom chamfer.
#4 _ass308_
_ass308_
Posted 18 July 2009 - 08:29 AM
sorry paul.i dont know where to get the,alloy fitting for the sender.
maybee see if brown davis will sell u one
#5 its Paul
its Paul
    Formerly lx8vd77
  • 1,577 posts
  • Name:Paul
Posted 18 July 2009 - 08:35 AM
Thanks Chris, but I don�t think they would supply one, they would want to sell me a complete tank.
Guess I could tell them I need to replace a damaged one. :P
#6 _ass308_
_ass308_
Posted 18 July 2009 - 08:38 AM
haveing just a bought a tank,i could give it ago for u.
gezz im clumsy with a trolley jack sometimes :tease:
#7 its Paul
its Paul
    Formerly lx8vd77
  • 1,577 posts
  • Name:Paul
Posted 18 July 2009 - 08:49 AM
lol
Mate that would be great, if you get a chance.
do the senders fit it nice and tight??
Sorry for the hijack ls2lxhatch.
Cheers Paul.
#8 its Paul
its Paul
    Formerly lx8vd77
  • 1,577 posts
  • Name:Paul
Posted 18 July 2009 - 08:50 AM
ls2lxhatch, are you making a tank??
#9 _ass308_
_ass308_
Posted 18 July 2009 - 08:56 AM
the sender fits 1st class.
i used a new sender seal from rare spares though
#10 ls2lxhatch
  • 5,332 posts
Posted 18 July 2009 - 10:54 AM
Thanks for the measurements, I am designing a tank to be built by a licenced fabricator. I can not decide whether to have the chamfered joins or straight butt joins.
You can get a VDO fuel sender modified to suit the Torana fuel gauge.
Browns Radiators in Perth will be able to sell you a modified VDO fuel sender. They may also be able to sell you the alloy fitting for the Torana sender.
Edited by ls2lxhatch, 18 July 2009 - 10:55 AM.
#11 its Paul
its Paul
    Formerly lx8vd77
  • 1,577 posts
  • Name:Paul
Posted 18 July 2009 - 12:39 PM
The reason for the 45deg edge is to stop the buckle and wave that you can get when welding, plus it looks good :D
thanks for the information.
#12 ls2lxhatch
  • 5,332 posts
Posted 18 July 2009 - 03:54 PM
Correct, Brown Davis use 2 mm sheet which requires the 45 degree join for strength and to eliminate distortion. If you use 3 mm sheet then the tank is heavier but the 45 degree join is not required. The 45 deg join is more complicated to design, cut and bend.
I am undecided which type of join I prefer in terms of appearance so I was planning to design two tanks and make prototypes of both.
There are pictures of both styles in this Torviki article.
#13 its Paul
its Paul
    Formerly lx8vd77
  • 1,577 posts
  • Name:Paul
Posted 18 July 2009 - 08:17 PM
Thats the article I used to make mine.
I'm making mine out of 3mm but with the 45degree, and you are correct it is a bit of a headf%$k to work out, I made a Galvanized one first to make sure the angles are right, all I need now is the time to finish it :D
Edited by lx8vd77, 18 July 2009 - 08:25 PM.
#14 hatchssv8
hatchssv8
  • 358 posts
Posted 22 July 2009 - 01:56 PM
Gents,
I have a CAD model file and accurate 1:1 scale drawings of the necessary pieces required to fabricate a drop tank. It is in the 45deg chamfer style.
The drawings have both cut lines and fold lines. It also includes all the small cuts required to achieve the chamfers in the corners.
I have these ready for when I want to make a drop tank for my car. Maybe we can get together and save you having to design the same thing. Open for discussion.
Cheers, Max
#15 its Paul
its Paul
    Formerly lx8vd77
  • 1,577 posts
  • Name:Paul
Posted 22 July 2009 - 07:28 PM
I wouldn�t mind a copy of that cad file, I could import it into my plasma programme and cut a tank out in minutes.
If you are offering to pass it on, I'll put my hand up. :spoton:
#16 _the gts_
_the gts_
Posted 22 July 2009 - 07:55 PM
hatch can you please send .cad file to [email protected]
hopefully this will work with turbocad
Go the 45deg Andy and let me know who cuts and bends for you. I can probably get trade price on the alum sheet if you need.
#17 ls2lxhatch
  • 5,332 posts
Posted 22 July 2009 - 11:27 PM
Max, thanks for the offer.
The reason I am designing a tank is that I want to incorporate the EFI pumps, surge tank and comply with the departure angle rule. The Brown Davis design does not comply with the departure angle rule and therefore can not be engineered in WA under the NCOP.
I used Google Sketchup to design the tank. I have made several prototype tanks from MDF and settled on the final design. I am waiting for the exhaust guy to check clearances before proceeding further.
Pictures here.
#18 _the gts_
_the gts_
Posted 23 July 2009 - 01:03 AM
HA HA i like the 172.4 measurement
#19 76lxhatch
  • 7,208 posts
Posted 23 July 2009 - 08:38 AM
ls2lxhatch, the very last photo on that page shows a tank that doesn't go very far forward - is that for exhaust clearance? Seems like there could be some extra capacity available by utilising that space (since you only have 65 litres), where does your final design finish up?
My tank has been custom made (I bought it almost completed) and it goes almost to the diff. This does create some issues with exhaust clearance but I think it would only require angling the sides in a bit further to make a big difference and still have plenty of capacity.
#20 ls2lxhatch
  • 5,332 posts
Posted 23 July 2009 - 11:11 AM
The space between the diff and the tank is for the exhaust and the Bosch 044 pump which mounts on the front. Each 10 mm further forward gives another 1.2 litres, the Google Sketchup volume calculator is very handy for this job. Once the exhaust has been completed I may be able to move forward 20-40 mm. The tank could also be made deeper but I did not like the look of the 210 mm deep version and it makes using a jack difficult.
The VE Commodore fuel tank holds 73 litres with a combined L/100 of 14.3, I figure 65 litres in a lighter car should give a usable range of around 450 km.
#21 LX 0076
LX 0076
  • 199 posts
Posted 23 July 2009 - 04:03 PM
Gents,
Cheers, Max
I Would also be interested in this if you could send it to [email protected]
Many thanks Jayson :spoton:
#22 hatchssv8
hatchssv8
  • 358 posts
Posted 23 July 2009 - 09:09 PM
I should have mentioned earlier.............(the earlier post reminded me)
I have made mods to the 120 litre version to accomodate the rear angle requirement, the asthetics (i dont particularly like the large Fish tank look) and the capacity.
The tank is approx 90 litres capacity, 180mm in height and is suitable for internal integrated pump/surge for EFI set up.
#23 _the gts_
_the gts_
Posted 24 July 2009 - 09:18 PM
so are you going to send the file?
#24 hatchssv8
hatchssv8
  • 358 posts
Posted 25 July 2009 - 10:51 AM
I am hoping for a "i'll scratch your back, if you scratch mine' scenario.
Any thoughts
#25 its Paul
its Paul
    Formerly lx8vd77
  • 1,577 posts
  • Name:Paul
Posted 26 July 2009 - 08:50 AM
mate, im not touching your back, people will talk :tease:
