Help Please! Starter motor problems
14 replies to this topic
#1 MR77LX
MR77LX
  • 401 posts
  • Name:Rabs
  • Car:1977 Holden Torana LX
Posted 26 July 2009 - 02:18 PM
Hey All,
I have a 304 Injected motor in an LX Torana and the starter motor is not sitting flush with bell housing.
I have the VR/VS small starter motor fitted to it.
I had removed the starter motor to fit some headers on and now it�s not going back in. I even jacked the motor up from its mounts and tried fitting it to the starter so nothing is in the way and the starter still won�t sit flush. Can it be damaged?
The starter motor goes in all way but when you tighten up the bolts, the starter moves back and leaves a gap between the housing.
When I lowered the motor back down, I noticed the solenoid is hitting the bottom frame.
Any help would be great!
#2 ls2lxhatch
  • 5,335 posts
Posted 26 July 2009 - 02:26 PM
What else did you change or unbolt during the extractor install?
Where is the inspection cover?
#3 MR77LX
MR77LX
  • 401 posts
  • Name:Rabs
Posted 26 July 2009 - 02:52 PM
During the extractor install, I had taken off the starter motor and the engine mount bolt, cause I lifted the motor to one side so I can fit the headers on. No inspection cover came with the motor.
When I bought the motor and gear box, I could have sworn that the starter motor was sitting flush to the housing.
#4 ls2lxhatch
  • 5,335 posts
Posted 26 July 2009 - 03:53 PM
When you lifted the engine the mount on the other side may have slid down on the k-frame which would move the engine over possibly causing the starter motor to hit the k-frame. Check the engine mounts are evenly spaced on the k-frame.
I am not familiar with the gearbox you have however I would expect some sort of gap between the starter and the housing for the inspection cover plate.
Edited by ls2lxhatch, 26 July 2009 - 03:59 PM.
#5 MR77LX
MR77LX
  • 401 posts
  • Name:Rabs
Posted 26 July 2009 - 04:23 PM
I have a T5 Manual transmission fitted to it. However is the solenoid suppose to be hitting the bottom of the K frame? Because I have read many articles on this forum saying that the VR/VS starter motor will fit. Should there be a gap for the inspection cover? If so that means the problem is the solenoid hitting the bottom of the K frame. The engine mounts are perfectly spaced because the bolts are in there.
#6 _homer_
_homer_
Posted 26 July 2009 - 05:00 PM
What sort of engine mounts are you using?
I just installed one of the small starter motors into my torrie yesterday and it fit no problems (304 V8). And it was flush. Maybe the wrong starter???
#7 TerrA LX
Posted 26 July 2009 - 05:25 PM
Does the ring gear still engage correctly?
Don't like the look of that hitting the chassis.
Edited by TerrA LX, 26 July 2009 - 05:27 PM.
#8 MR77LX
MR77LX
  • 401 posts
  • Name:Rabs
Posted 26 July 2009 - 05:38 PM
Homer, where did you get you starter from and how much? I�m using HQ engine mounts and plates.
The funny thing is that the starter motor was already in the motor and I had removed it to fit the headers. I didn�t pay much attention but I don�t think the solenoid was hitting the side of the K frame originally. I raised the motor back up again so the solenoid does not hit the K frame and tried fitting the starter motor. It fits but the problem is when you tighten both bolts, it moves back a couple mils creating a gap between the starter and the bell housing. The problem I think might be with the starter. I don�t get it AH!
Its hard to see, but the ring gear looks like it�s engaged, I can�t test it. I have not wired it up yet.
#9 _rorym_
Posted 26 July 2009 - 06:36 PM
Wrong starter..sent you pics of the right one...
#10 _rorym_
Posted 26 July 2009 - 06:37 PM
Attached File  stubs.jpg   601.67K   14 downloads
Check the size of the body...this is a VN on one...you have an early HQ one..no way will it fit....send it back. I need to start charging you guys for this info.??..You know??
Edited by rorym, 26 July 2009 - 06:40 PM.
#11 MR77LX
MR77LX
  • 401 posts
  • Name:Rabs
Posted 26 July 2009 - 07:05 PM
Thanks Rory, the starter that I have is the original one for that motor. It�s a VR model.
It�s weird because it was fitted to that motor and I pulled it off to fit the headers.
However, I will take your advice and grab one with a smaller body.
#12 _homer_
_homer_
Posted 26 July 2009 - 07:11 PM
I went out and took a couple of pics for you.
The first pic is taken from under the car and the second pic is looking from the top of the engine throught the extractors.
The third pic is what it is attached to.
And I bought the starter from Repco for around $150 I think.
Edited by homer, 26 July 2009 - 07:13 PM.
#13 MR77LX
MR77LX
  • 401 posts
  • Name:Rabs
Posted 26 July 2009 - 07:26 PM
Thanks Homer !!!
P.S - Your motor looks good, nice and tidy.
#14 _rorym_
Posted 26 July 2009 - 07:34 PM
^^ Thats the sucker you need.
Some of the VN/VRs for some reason copped the big body starters..you need the smaller one.
Edited by rorym, 26 July 2009 - 07:34 PM.
#15 _@milco@_
_@milco@_
Posted 26 July 2009 - 10:05 PM
yep wrong starter for sure........
