Fabricating a transmission tunnel
27 replies to this topic
#1 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 06 August 2009 - 11:28 PM
I�m in the process of making a transmission tunnel (as the person I have asked is taking ages to do it and I�m pretty close to doing it myself)
Just wondering what�s the difference and what is preferred, Cold rolled or Hot rolled sheet metal.
I�m thinking of using 1.6mm-2mm thickness, I�m thinking 2mm may be too thick??
Bart
#2 rodomo
  • 18,039 posts
Posted 06 August 2009 - 11:41 PM
Some info in this thread, post #6 refers to hot/cold rolled:
http://www.gmh-toran...showtopic=37019
#3 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 06 August 2009 - 11:46 PM
Thanks mate
Cold rolled it is :spoton: :spoton: :spoton:
If it turns out i will take some pics :D
#4 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Posted 07 August 2009 - 12:09 AM
buy my EH transmission tunnel off ebay....cut the top off your tunnel and drop it on weld it up.
http://cgi.ebay.com....=STRK:MESELX:IT
#5 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 07 August 2009 - 05:26 PM
Thanks FastEH
I have already cut out the tunnel and bought cold rolled sheet metal, should arrive Tue so I will be withdrawing for a few days for not doing any work on the Torri
The RB25T Nissan box is pretty tall and fat so your tunnel my not be the go.
Thanks anyway, good luck with the sale on fleebay :D
#6 _2DR_
_2DR_
Posted 09 August 2009 - 11:15 AM
as suggested already cold rolled is best 1.15 or .95 is the best (and closest to original thickness) i have found but depends on what shapes your trying to create.2mm will be to thick imo
good luck look forward to some pics.
#7 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 09 August 2009 - 02:26 PM
Interesting, my tunnel is about 1.8mm thick.
I want to stay with that roughly
#8 _2DR_
_2DR_
Posted 09 August 2009 - 05:28 PM
1.8 mmm not having measured mine ill have to take your word for it but most of my other panels are about 1 to 1.2mm i wonder if they made the floors thicker than exterior panels?
#9 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 09 August 2009 - 06:28 PM
Yes I would say so.
I believe exterior panels are thinner. I had safety in mind so i went 2mm, dont want a fly wheel in my foot. The motor im using is capable of revving over 8000rpm. You just never know. :blink:
#10 ls2lxhatch
  • 5,332 posts
Posted 09 August 2009 - 10:31 PM
The tunnel in my LX varies from about 1.0 mm to 1.5 mm presumably depending on how much the metal has been stretched or shrunk and how cleanly I cut the holes.
#11 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 10 August 2009 - 07:11 PM
#12 _2DR_
_2DR_
Posted 10 August 2009 - 08:47 PM
ls2lxhatch - sounds like a good prognosis
bart - looks like fun 2mm will be a bartard to shape
#13 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 10 August 2009 - 09:07 PM
Yeah it will be but fortunately there wont be too much shaping to do. It�s not too multi dimensional
#14 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 11 August 2009 - 10:59 PM
Still early days, looks a little too angular, but then i probably shouldnt worry too much about asthetics since its just a tunnel.
#15 _2DR_
_2DR_
Posted 12 August 2009 - 05:08 PM
looking good
#16 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 14 August 2009 - 01:48 AM
This is my home made folder originally made to fold aluminium, to my surprise it folded 2mm cold rolled steel.
Tunnel progress, i have tappered the back end of the tunnel a little more.
#17 racean69
racean69
  • 782 posts
  • Name:Rod
  • Car:LH sedan
Posted 14 August 2009 - 09:07 AM
looking good bart...top job :spoton:
#18 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 14 August 2009 - 12:24 PM
Time to fully weld it in today.
#19 _2DR_
_2DR_
Posted 14 August 2009 - 02:32 PM
:spoton:
#20 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 14 August 2009 - 10:50 PM
Fully welded
Real prick to get my head in there, welded a little blind near the fire wall but got there at the end.
Edited by Bart, 14 August 2009 - 10:52 PM.
#21 rodomo
  • 18,039 posts
Posted 14 August 2009 - 10:59 PM
Love your shed mate. Looks like mine :D
Better than some of the gurly sheds you see :stirpot:
AND.. I have bent sheets with a bender just like that :clap:
#22 Heath
  • 18,393 posts
Posted 14 August 2009 - 11:12 PM
LOL I could not work in a shed like that, but clearly Bart can. That looks sensational! Very simple in its form (which I'm sure made it much easier to shape) but it just looks perfect. No excessively large dimensions... looks like there is still a fair bit of room left in the footwell for your feet to operate in etc. Tops!
#23 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 15 August 2009 - 10:44 PM
Thanks mate its a little crowded in there but does the job, occasionally trip over shit lol
I have plans on building a 8m X 5m out back maybe a little bigger, have to see what the bloody council allows, damn Nazi's :<_<:
#24 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 15 August 2009 - 10:45 PM
Yeah I know what you mean, as mentioned its a little crowded, but builing something bigger in the future. The damn Pontiac takes a lot of space. :blink:
#25 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 15 August 2009 - 11:16 PM
Had a bit of an accident today, while welding the outside of the tunnel with an oxy (as its much nicer weld) the inside of the car caught on fire, to be exact the damn plastic lower heater duckting which is right near the tunnel/fire wall. Got the extiguisher out but screwed the duckting and a coupl of wires. Not happy but could have been worse i guess. Sometimes it feels like im just digging a bigger hole for myself. ut my passion for cars and my Torana keeps me going. :cry:
Edited by Bart, 15 August 2009 - 11:16 PM.
