Bleeding Brakes
Posted 11 August 2009 - 07:26 PM
Posted 11 August 2009 - 07:29 PM
FJ is a pig to bleed cause the fluid has to go in odd places to get to the wheels
Have you adjusted everything first ?
#3 _nial8r_
Posted 11 August 2009 - 07:35 PM
try strating the car and pumping the pedel
try using brake bleeder bottles so you can open all the bleeder nipples at the same time and then start pumping the pedel
try pushing some brake fluid with a syringe into the brake line from either end then conect em back up and start the pumping again ( warning: this is the messy way but has been known to work )
hope this might help
Posted 11 August 2009 - 07:38 PM
So no mad pumping
And starting the car will have no effect on a FJ master as its unboosted
Unless the cars been modified and has a non original master and or remote booster fitted
More details required please
#5 _Squarepants_
Posted 11 August 2009 - 08:34 PM
Connect it to the bleeder, plug in the air line, crack the nipple, watch and wait???
Don't know the system on an FJ but from what I've seen of these vacuum jobs, they're magic.
Posted 11 August 2009 - 08:47 PM
front brake are Hoppers twin piston and rears are VK discs...
Posted 11 August 2009 - 09:55 PM
#8 _SS Hatchback_
Anyway i bled the master first on its own, then installed it . Then did each line starting from the furthest caliper first (ie rear left) . Using the normal push pedal and crack nipple and then close nipple before pedal hitting the floor. repeat repeat repeat . My misses reckons her leg was sore but i didnt feel a thing
Posted 11 August 2009 - 10:03 PM
vacuum bleeder
Where Can I buy one of these....
Posted 11 August 2009 - 10:17 PM
Posted 11 August 2009 - 10:29 PM
car not running yet, and no datto it has a VN Brake Booster.......
All new stuff?
You might have to bleed the master cyl.
Posted 12 August 2009 - 12:12 AM
Under floor or in engine bay ?
You'll never get a perfect pedal first up anyway cause the pads have a certain amount of compression and need to bed in
But I think theres more to the story
Pics of everything ?
Posted 12 August 2009 - 06:11 AM
Posted 12 August 2009 - 10:48 AM
http://static.summit...9-1-2-3-4-5.pdf
http://static.summit...ng_addendum.pdf
Posted 12 August 2009 - 07:28 PM
The master if second hand could be rooted
You could try reverse bleeding
Shame its got those aweful braided hoses on it
You could be clamping lines and finding the actual problem area
Posted 12 August 2009 - 08:53 PM
Neil, threw them away, Matt at Race Brakes got me some new plain black ones made.. I have put all new lines and hoses alround, booster was rebuilt some time ago though, maybe its stuffed.. Wayne
Posted 12 August 2009 - 11:06 PM
Posted 12 August 2009 - 11:08 PM
Posted 13 August 2009 - 06:47 AM
You have one built into the master cylinder already
thanks that is what i thought....
Posted 16 August 2009 - 05:36 PM
rgds
wayne
#21
Posted 16 August 2009 - 05:42 PM
