Did VN heads have a PCV valve?
7 replies to this topic
#1 Evan
Evan
  • 1,287 posts
Posted 20 August 2009 - 08:24 PM
Heya Guys and Girls!
I purchased some VN rocker covers and it has a nozzle missing on the drivers side cover as pictured.
What was ment to go there?
Is the one that is on the passengers side a PCV or is it just an outlet?
I was going to run one to a catch can and another a PCV to the carby.
I tried putting my old PCV valve in the hole with the missing nozzle and it does not fit well. The open hole has a key way in it so i cant see how it would make a good seal on the PCV.
Any help would be appreciated.
Regards
Evan.
#2 makka
makka
    A m��se once bit my sister
  • 3,559 posts
  • Name:Cohen
Posted 20 August 2009 - 09:09 PM
I would do exactly as you have mentioned, 1 to the pcv the other to a breather/catch can
#3 76lxhatch
  • 7,207 posts
Posted 21 August 2009 - 07:24 AM
Yes the one on the passenger side had a PCV into the throttle body and the drive side had a breather hose across into the air intake also (before the throttle butterfly I think). There should be another elbow like the passenger side one to fit into the driver side cover width keyway, they both had hoses running off these.
Definitely put a standard PCV setup of some sort on it, what you've suggested should work fine.
#4 Evan
Evan
  • 1,287 posts
Posted 22 August 2009 - 05:09 PM
Cheers for the heads up guys!
So the one i currently have in there on the passenger side is a PCV?
Is there an easy way to tell? , ive tried to take it out , but it is really stuck in there heys.
Evan.
#5 _1uzbt1_
_1uzbt1_
Posted 22 August 2009 - 06:04 PM
there is normally a short piece of hose coming of the passenger side fitting and then the pcv valve gets pushed into that.
#6 _mumbo_
_mumbo_
Posted 22 August 2009 - 08:48 PM
They do pull out , i pulled mine out and turned to a dif position and nocked back in .
A lot of people take them out and weld in fitting , i run both of mine to catch cans.
Edited by mumbo, 22 August 2009 - 08:49 PM.
#7 76lxhatch
  • 7,207 posts
Posted 23 August 2009 - 08:26 AM
No, its just an elbow. You need another elbow for the driver side and a PCV which you will attach via a short piece of hose.
The elbows do fit rather tight and they have a keyway so you can't twist them at all, they must pull straight out.
Edited by 76lxhatch, 23 August 2009 - 08:27 AM.
#8 Evan
Evan
  • 1,287 posts
Posted 23 August 2009 - 08:27 AM
Excellent info!
Cheers for that,so i need a in line PCV from coventry's, if they can get one, and another elbow. Thats going to be interesting.
I think im gonna put my catch can on the passengers side so that one can stay where it is.
Ill run a pcv and a catch can, and see how that goes.
Thanks again.
Evan.
