![Photo](https://www.gmh-torana.com.au/forums/uploads/profile/photo-thumb-110.jpg?_r=0)
Block Clearancing for Stroker Crank
TempesT
, Sep 01 2009 09:35 PM
6 replies to this topic
Posted 01 September 2009 - 09:35 PM
For those seeking info on Block Clearancing for Stroker Crank's be it for a 355 or 383 here is a little vid I came across.
Having done this myself its a pretty good indication of what needs to be done despite being a ls7 not a 304/308.
jim
jim
_beergut_
Posted 02 September 2009 - 11:16 PM
got a pic of a 355?
mine looks modded the same way but got 308 stamped on the crank?
also got 5.7" rods but might b out as hard to measure
Posted 03 September 2009 - 09:41 AM
Here is the work done on Herne's block by Struggler:
![Posted Image](https://cache.gmh-torana.com.au/i304.photobucket.com/albums/nn170/jimmy_mannas/alan016.jpg)
Here is the first cylinder done on mine prior to cleaning it up:
![Posted Image](https://cache.gmh-torana.com.au/i304.photobucket.com/albums/nn170/jimmy_mannas/03092009728.jpg)
This is why it is done:
![Posted Image](https://cache.gmh-torana.com.au/i304.photobucket.com/albums/nn170/jimmy_mannas/29042009461.jpg)
![Posted Image](https://cache.gmh-torana.com.au/i304.photobucket.com/albums/nn170/jimmy_mannas/29042009464.jpg)
note it is the opposing rod’s bolt that fowls the outer cylinder wall.
The opposite bank:
![Posted Image](https://cache.gmh-torana.com.au/i304.photobucket.com/albums/nn170/jimmy_mannas/29042009471.jpg)
![Posted Image](https://cache.gmh-torana.com.au/i304.photobucket.com/albums/nn170/jimmy_mannas/29042009469.jpg)
The crank and c/r will determine how much metal needs to be removed, some require more than others. I run a scat crank and A9l rods.
Beer gut you may have a Vs block that has factory clearancing for a stroker crank as posted above?
jim
The opposite bank:
jim
Edited by TempesT, 03 September 2009 - 09:47 AM.
Posted 03 September 2009 - 04:55 PM
got a pic of a 355?
My VN 304 had 308 on the crank...show us a pic of the block, as said.you may already have it..check the VS block above.
Posted 03 September 2009 - 05:34 PM
Close up of VS V8 bore (clearance for 5.7L).
_beergut_
Posted 03 September 2009 - 10:34 PM
not vs as is red block suspect it,s vb as engine no starts wit vClose up of VS V8 bore (clearance for 5.7L).
anyway photo is attached
