scuttle panel
12 replies to this topic
#1 lcgtr1970
lcgtr1970
  • 1,702 posts
  • Name:Jordan
Posted 04 September 2009 - 12:37 PM
hi all.
well i want to check and see if the pipes that drain water from the plenum? chamber are blocked up coz water leaks in on the passenger floor when it rains hard.
just want to know...do i have to take off the scuttle panel to do this?
if so how do i do it?
if not how do i clear out the pipe?
#2 _lx5008_
_lx5008_
Posted 04 September 2009 - 01:04 PM
Rust is the big problem under there. you can remove them from inside the car to clean them out. but its not easy to do.
#3 Statler
  • 6,318 posts
Posted 04 September 2009 - 01:22 PM
You can unplug the drain pipe from the plenum, but it is a mongrel of a job. Theoretically, they should pull off, but seldom they do!
Once you get them off, you can feel up the hole with your finger for any debris.
If you find some, then i suggest you remove the wiper panel for a clean out.
To remove it, first remove the wiper arms, then undo all the screws in the engine bay. Usually these are sealed, so you need to break the seal. Lifting it gently from the enginebay side will do the trick.
Be carefull not to lift it too high, as it wont clear the wiper motor.
Once the seal is broken, lift the outside corners [in engine bay], then slide a finger up toward the windscreen. All you are trying to do at this stage is lift the tabs out. [tabs go along just forward of the screen, or along the top edge of the scuttle panel.
Usually, once the outside 2 tabs 'pop', you can slide the finger along & the rest will follow.
If you put a bucket under the drain pipes, you can flush the plenum chamber out.
Dont forget to poke the hose in the drain pipes also.
Hope that helps.
#4 _torana_umunga74_
_torana_umunga74_
Posted 04 September 2009 - 07:45 PM
think about blocking off the holes with flyscreen or something. i have shadecloth stuck in there just under the scuttle with a gap fpr the wiper and it works a treat to stop leaves gettinin. im so used to removing the scuttle panel i can do it like 10 seconds now lol
#5 lcgtr1970
lcgtr1970
  • 1,702 posts
  • Name:Jordan
Posted 04 September 2009 - 11:55 PM
thats a good idea....dont want to drive to wagga and do mine for me do ya?
#6 _torana_umunga74_
_torana_umunga74_
Posted 05 September 2009 - 12:37 AM
is it an lh/lx? i didnt see ur name readin the thread. i dunno what a baby torry looks like there lol. id come to wagga i worked there on the hume upgrade for a while.. free everything for us, ive never drank so much in my life.
#7 lcgtr1970
lcgtr1970
  • 1,702 posts
  • Name:Jordan
Posted 05 September 2009 - 09:57 PM
its an lx...youre not irish are you???lol...we had a few irish fellows live next door to us that worked on the hume...tried picking my sister up one night..lol...
how long were you here for?
#8 _torana_umunga74_
_torana_umunga74_
Posted 05 September 2009 - 10:01 PM
i hung with em they were great lol. it was a while back now.. jan an feb 2008 i was there for 2 months had a ball. heaps of irish i dunno y..
#9 _double ss trouble_
_double ss trouble_
Posted 05 September 2009 - 10:11 PM
Attached File  torana 29.6.2009 032.jpg   243.07K   18 downloadsthis is why mine was leaking ,needed to drill spot welds ,saw cut down both sides to remove top of plenum ,all fixed now though .it was all bare metal under there and had been since it left the factory ,it has now been painted with zinc rich gal paint after the welded rust repairs and should last for another 33 years at least
#10 _Squarepants_
_Squarepants_
Posted 10 September 2009 - 04:16 PM
I have stainless mesh glued up under the cowel panel vent slots. Keeps leaves and crap out and looks a treat too.
I would post a pic but the missus just cleaned up and I can't find the camera.
#11 _nial8r_
_nial8r_
Posted 10 September 2009 - 06:42 PM
i would almost bet my balls on it if you have a good look under the dash around that heater box part there is rust mate almost all of them go there you should see mine Posted Image
#12 _Squarepants_
_Squarepants_
Posted 10 September 2009 - 07:14 PM
Are you talking to me or LC?
Yeah, I repaired a bit of rust in mine under there when I was building it, that's why I put the mesh in.
I was lucky as it was only minor, so I could do it from under the dash inside with a die grinder, a little bit of sheet steel and a mig.
#13 _nial8r_
_nial8r_
Posted 10 September 2009 - 07:27 PM
was telling LC or who ever wanted to listen Posted Image mate you should see mine, the last owner glued it in with some heavy duty shit i couldnt even get the screws out so i gave it a little jiggle and the whole bloody lot came out now i have 1 massive hole to repair as well as refit the heat box thingo, im gonna do a custom job on that part of the plenuim as the little piece that sticks up in to the it is only about 25mm high so if you hook it around a corner the water is going to still get up over it and inside the car, i will be raising mine up to about 60mm and the mesh under the vets you talk about is a perfect idea ( IDEA HAS NOW BEEN STOLEN Posted Image )
