Anyone got any pics of how they are mounted?
cheers Dan
Edited by sloshy, 07 September 2009 - 12:43 AM.
Posted 07 September 2009 - 12:41 AM
Posted 07 September 2009 - 08:28 AM
Posted 07 September 2009 - 11:02 AM
Posted 07 September 2009 - 12:06 PM
Posted 08 September 2009 - 09:39 PM
Posted 08 September 2009 - 10:02 PM
I think that using the piping would be the proper way to do it. That way it, as Matt said, flows with the look of the rest of the car. That is, of course, the car in question is flared.
Mount it using the allen key bolts, the same size as the ones used for flares, a flat washer on top and a flat washer underneath the bonnet, and of course, use nylon nuts.
The one mounted on my car has some of the bolts right above the bracing in the bonnet. They just drilled a larger hole in the bracing so that the smaller washer and nut can sit right against the bonnet.
I can get you a pic of that if you want, but it depends on where you mount it. Some people have them all over the place!
I think Ruts fixed up one in his flare fitting thread, might be worth the look.
Posted 08 September 2009 - 11:33 PM
Posted 09 September 2009 - 07:34 AM
Posted 09 September 2009 - 07:53 AM
Posted 09 September 2009 - 08:10 AM
Posted 13 June 2011 - 12:14 PM
I don't agree with using allen key bolts. For one, it looks rough, and for 2, you have to hack holes in the ribs in 2 places to fit nuts to the back. Use the correct screws which are the same as the grill screws and for the two on the front corners, use self tappers with the same head design, you can find them holding the dash in place.
Posted 13 June 2011 - 03:11 PM
Edited by Quagmire, 13 June 2011 - 03:16 PM.
Posted 13 June 2011 - 03:22 PM
