IDENTIFY THIS QUADRAJET CARB PLEASE
_HUNTER SODABLAST_
, Sep 11 2009 11:41 AM
9 replies to this topic
#1 _HUNTER SODABLAST_
Posted 11 September 2009 - 11:41 AM
Hello
I am after a little help identifying a quadrajet carb Part# 7041202zf
BUILT 193rd day 1972
I am under the impression it was off a A9X torana hence why i am asking the question here
I will add that the body also has a X cast into the moulding can someone please supply me some info on this carb and also what the X in the casting means
i have had a look over my other carbs and none have this casting mark
DSC00402.JPG 287.75K 38 downloads
Regards Craig
HUNTER SODABLAST
0437411830
Regards Craig
HUNTER SODABLAST
0437411830
#2 _ozbox_
Posted 11 September 2009 - 01:52 PM
the number should be 7041282....its off a hq 308....i have a 6/73 hq statesman here which has that carb on it and also has the x casting...no idea what the x casting meens...
Posted 11 September 2009 - 02:25 PM
And since A9X was made late 77 a 72 built carb certainly aint going to be on one
#4 _HQ SS_
Posted 11 September 2009 - 08:18 PM
As ozbox said it is a HQ 308 carby but just a little bit more information for you is that it is a Automatic model carby.
Even numbers are Auto, Odd are Manual.
The full brake down is this
7041282 ZF
704 1970-74
1 = 1971. (this is because it is a 1971 spec carby)
2 = Quadrajet 4BBL US federal standards.
8 = Holden.
2 = Auto transmission.
Cheers Paul.
7041282 ZF
704 1970-74
8 = Holden.
Cheers Paul.
Edited by HQ SS, 11 September 2009 - 08:25 PM.
#5 _Yella SLuR_
Posted 03 April 2010 - 10:05 PM
There are over 30 different model of quadrajet. Just try find a carby kit for one, to find out how many different varieties there are!!!
Posted 04 April 2010 - 07:11 AM
So what is the difference between the auto & manual carb?
Posted 04 April 2010 - 05:49 PM
Vacuum advance port is connected to full vacuum for auto, ported vacuum for manual.
Posted 05 April 2010 - 06:57 AM
Have just bolted a 7041281 Q-jet to a HJ 2 door that has the X on the carb.
Posted 05 April 2010 - 11:50 AM
Hey all
Maybe my eyes but it looks to me more like a symbol rather than an X. One leg of the X appears to be thinner than the other and looks like a needle (pointy end up) inserted through the other piece.
Dave
Dave
Posted 05 April 2010 - 01:44 PM
Any X on a carb casting would have very little to do with anything GMH were doing. These carbs were cast in the USA, and they would never have heard of an L34. The only thing on most GMH Quadrajets that distinguishes them from others is the 8 in the carby number.
