im looking at removing my engine and painting it in the next couple of months. ive already dragged a mate into it. whats the best product to clean the engine with first and whats the best product to paint with? are some better than others?
next is what colour to paint the engine, currently its rust coloured! can people post up pics of different coloured 6's? im thinking either black or grey, dont think i want to paint it red.
Painting Engine
_dickiep_
, Sep 15 2009 11:40 PM
6 replies to this topic
_dickiep_
Posted 15 September 2009 - 11:40 PM
Posted 16 September 2009 - 05:54 PM
Yellow
Protec 609 2k, i've painted quiet a few engines in that and have yet to see it burn off or be affected by heat at all
_dickiep_
Posted 16 September 2009 - 05:57 PM
that look nice as! ive got a yellow car so dont know how well it will look with yellow engine. ive got the same rocker cover in black too. i think i might leave that black, paint my extractors black and have the engine a colour. yellow could look cool though. mmmmmmmm decisions
Edited by dickiep, 16 September 2009 - 05:57 PM.
Posted 16 September 2009 - 06:50 PM
One tip with yellow, you dont want any oil leaks, show up like mafakas.
Old engine.
Running "yella" 202's has become a bit of a trade mark for me according to some mates lol.
Old engine.
Posted 16 September 2009 - 09:15 PM
I did mine back to orange.
It was a full rebuild so it was a blank canvas
After building the engine i washed it with an acetone to get rid of all traces of oil.
I just bought pressure packs of engine paint from supercheap.
Posted 16 September 2009 - 10:00 PM
I have only ever used engine enamel, VHT seems best, other brands seem a bit thin.
Next motor I do will be body colour so will be using 2k.
Motor prep is same as body prep.
If you want a good finish that will last and not peel or flake then it must be clean and rust free.
Give it a good scrub with caustic based oven cleaner (remember cloves and googles) and use a water pressure washer if you have one to wash it down afterwards.
Don't forget to seal the motor up.
Rust can be treated with acid (hydrochloric or any rust converter) and wire brushes.
If you are painting over old paint too then hit it all over with either a wire brush, scotchbrite or even sand paper on the bigger areas to remove the loose stuff and to help the fresh paint stick.
_Brad1979UC_
Posted 16 September 2009 - 10:33 PM
I know you dont want to paint it red, but i used the same paint that Paul used, the Septone engine enamel from supercheap, seems to have worked well, this is how its held up on mine after 2 years, i just degreased the block before i painted it, didnt strip it back like pauls either
Edited by Brad1979UC, 16 September 2009 - 10:34 PM.
