HM Headers HM9C
129 replies to this topic
#51 orangeLJ
Posted 24 November 2009 - 09:14 AM
hahaha, thought about going to a toyota box?
Yeah Im running the same flywheel (lightweight, billet steel, explosion proof)
Pity you arent a couple weeks ahead, you could have brought it out for a run on the christmas cruise!
Will definitely be keen to see how your setup performs! How long till you will have it all back together?
#52 _CraigA_
_CraigA_
Posted 24 November 2009 - 09:45 AM
Engine is about two weeks away so car should be on the road before Christmas. Then use January to sort out the niggles and run it in.
As for the Toyota box - to be honest I'm not keen on the non-Holden bits. I have to show at least a little respect for the fact its a genuine XU-1 Posted Image
#53 _CraigA_
_CraigA_
Posted 26 November 2009 - 07:29 PM
Picked these up today. Decided on the bright finish as apparently the black tends to scratch very easily.
Photos don't do them justice. In real life they are just incredible to look at. :D :D :D :D
Work done by Hi Octane in Rydalmere Sydney. About 500 metres from work
Bottom end of the engine is now built. All done by end of next week. :spoton:
Edited by CraigA, 26 November 2009 - 07:34 PM.
#54 LJ RB30
LJ RB30
  • 1,038 posts
  • Name:Trevor
Posted 26 November 2009 - 11:23 PM
Good stuff mate.
just a tip, if your putting them on a motor you haven't run before make sure your timing is not too redarded when you first fire it up. Reason i say this is a good mate had his 383 stroker rebuilt, was fitted to the car ( VS commodore) then he decided to fit some coated extractors, he was ever so careful to fit them with out scratching them (it took hours). Only to have the engine builder fire it up to run the cam in ( i was there ) and with too much retarded timing in the beginning to burn the tops of all of the first bends of the pipes. Needless to say he was not happy.
#55 _CraigA_
_CraigA_
Posted 27 November 2009 - 06:11 AM
Thanks for the tip!! I'll be extra careful on initial startup.
#56 _CHOPPER_
_CHOPPER_
Posted 27 November 2009 - 08:30 AM
If the timing is out or the engine runs lean, they will dis-colour.
#57 orangeLJ
Posted 29 November 2009 - 10:58 AM
If I was you craig, Id run it in with a different set of pipes.
They dont tell you until after you ring to ask why they are faded/discoloured, but there are a two things that I found that will stuff them.
Fuel or oil will stain them if it hits while hot
Excess heat will dull them (so dyno tuning, running in a cam etc)
Just something to be wary of when using them, I found the coating pretty hardy other then that, Ive bashed mine around a bit over the years and it hasnt really scratched or chipped anywhere.
#58 _CHOPPER_
_CHOPPER_
Posted 29 November 2009 - 01:43 PM
Apparently doing burnouts will also cause them to overheat and dis-colour.
#59 _CraigA_
_CraigA_
Posted 29 November 2009 - 07:24 PM
^^ Looks like they are getting dis-coloured then......................... :lol:
I'm fitting a heat shield so the headers will be covered. I just want it to go good anyway so not concerned so long as the ceramic coating does its job and minimises engine bay temps.!!!
#60 ls2lxhatch
  • 5,332 posts
Posted 29 November 2009 - 07:30 PM
The appears to be a couple of different silver coatings available from a few different suppliers.
One company I spoke to (CIC) recommended against using the silver as petrol will stain and the finish will discolour if overheated.
An agent for Jet Hot coating in Perth claimed that the silver coated headers on his drag car still look like new after a couple of seasons. This included oil spills from the rocker covers during inspection between runs. Jet Hot claim the sterling silver coating can not be penetrated by Petrol, Brake fluid, Oils or Antifreeze.
Jet Hoat Coatings
It would be interesting to hear if anyone has had problems with Jet Hot coated sterling silver headers.
#61 orangeLJ
Posted 30 November 2009 - 07:35 AM
Mine were done by HPC in melbourne.
#62 _CraigA_
_CraigA_
Posted 01 December 2009 - 12:24 PM
Engine is now nearly complete. Just waiting on push rods to arrive and then roller rockers to be fitted.
#63 orangeLJ
Posted 01 December 2009 - 01:09 PM
Same balancer as mine by the looks of it :)Have you decided what you are going to do radiator and fan wise?
#64 _CraigA_
_CraigA_
Posted 01 December 2009 - 01:41 PM
Radiator is on its way from Norm at Aussie Desert Cooler.
Triple flow with two front mounted thermo's with no mechanical fan.
Edited by CraigA, 01 December 2009 - 01:48 PM.
#65 _threeblindmice_
_threeblindmice_
Posted 01 December 2009 - 02:01 PM
It's looking good Craig ,It will be good to see it back on the road , did it always have those inlet ports ? if so what was the power band ? Is you diff still the same ratio ?
#66 _CraigA_
_CraigA_
Posted 01 December 2009 - 02:08 PM
Cheers Bruce. Externally the ports are unchanged, just some minor adjustments where the port turns down towards the valve. Engine guy reckons it was all very good except the turn was little sharp in this area.
Before it came on around 3000rpm. Now I think it would be a little higher.
Diff will be 3.55 LSD.
I can't wait to get it going again either. Should be a fun 2010 Posted Image
#67 ls2lxhatch
  • 5,332 posts
Posted 01 December 2009 - 05:04 PM
It would appear that JetHot, CIC and HPC all use different coatings or at least different trade marks. It would be good to know what the difference between the products if any is.
#68 _CraigA_
_CraigA_
Posted 08 December 2009 - 07:51 AM
Car left for my brothers work yesterday. Engine is complete and I will install in the week before Christmas.
#69 blake
blake
  • 267 posts
  • Name:Blake
Posted 09 December 2009 - 08:37 PM
geez craig your car looks really sweet in that pic. im 15 years old and doing up and lc xu1 replica, recently purchased a worked 186 with triple webers, hopefully mine would look as good as your one day, except im gonna do mine in linamint, cheers craig, good luck with the new hot engine
Blake
#70 _CraigA_
_CraigA_
Posted 09 December 2009 - 10:16 PM
Thanks a lot Blake, I appreciate your comments mate.
It makes me really happy that a younger bloke like yourself would have such a strong passion for these cars. I look forward to seeing your car progress so keep us up to date.
Linamint is a perfect colour on an LC. Did you see Alan's LC XU-1 in the recent Unique Cars shootout? That's a cracker of a car and John Bowe raved about it when he jumped out of his test drive.
I'll post a video as soon as I get mine running.
Edited by CraigA, 09 December 2009 - 10:19 PM.
#71 orangeLJ
Posted 15 December 2009 - 07:23 AM
Just wondering if you got your webers back yet?
Im really keen to see how they turn out.
#72 _CraigA_
_CraigA_
Posted 15 December 2009 - 07:55 AM
Hi Chris, I didn't get time to send them as I have been travelling with work.
Am fitting the engine next week so will get them re-done in the New Year.
#73 orangeLJ
Posted 15 December 2009 - 08:03 AM
No worries mate :)
just thought Id ask.
If yours turn out good then I will definitely be looking into it in the new year.
cheers mate.
Chris
#74 _CraigA_
_CraigA_
Posted 15 December 2009 - 09:33 AM
^^^ Photos can be deceiving Posted Image
Have bolted everything up out of the car and it fits OK with the sump. Not sure about clearance to the body or subframe but will find out next week when I put it in.
As you may have seen in the thread I was using the factory exhaust headers but engine builders advice was to go for the HM Headers. Not sure about flow figures for the muffler but the factory style pea shooter would surely flow less than a low restriction 2.5" to 2 x 2" outlet muffler.
Not sure I care anyway - its just sounds real good.Posted Image
Has your sump got an external oil pick up? If so I'd be interested to see where you run the hose from the sump to the oil pump. We have some clearance concerns around that area and a picture of yours may give me a better idea.
#75 _CraigA_
_CraigA_
Posted 15 December 2009 - 11:08 AM
I'm not certain of the muffler type but will check next week when I'm near the car.
Thanks for checking the sump. It'll all work out next week when we make it fit Posted Image
