HM Headers HM9C
#101
Posted 07 February 2010 - 04:54 PM
#102
_pacey1977_
Posted 15 February 2010 - 10:16 PM
looks a million bucks. video time...
hi craig what numbers has your new engine run or what do you think its going to run am building a new engine with bit bigger cam then you and also running 45mm weber carbys aslo can you give me the place where you got your sump made cheers looks mad buddy
#103
_CraigA_
Posted 15 February 2010 - 10:25 PM
Sump came from:
Australian Specialty Racecraft
2/43 Dingley Ave
Dandenong
VIC 3175
JOHN POTTER
(03) 8774 0343 Ph
(03) 8772 2457 Fax
Haven't really given it a big rev yet but my expectation is a mid-13 on street tyres which will make me happy.
Ran 14.2 @ 96mph with the old engine which wasn't as well sorted as this version.
#104
_oldjohnno_
Posted 16 February 2010 - 06:18 AM
#105
_pacey1977_
Posted 16 February 2010 - 06:28 AM
Thanks for the kind comments.
Sump came from:
2/43 Dingley Ave
Dandenong
VIC 3175
JOHN POTTER
(03) 8774 0343 Ph
(03) 8772 2457 Fax
thanks heaps buddy I hope to run the same time's am using a comp cam Cam: gross valve life .556
duration @50 is 261 soild cam so if i make the same power as you it will be mad do you have any hp reading from a dyno.
very nice car buddy thanks for the info
have a good day.
regards
pacey
#106
Posted 16 February 2010 - 08:20 PM
Would you have any photos of the mods to the floor, etc to fit the extractors? I'm thinking of fitting the same and am curious as to how much the floor needs to be modded. Would prefer to do it whilst doing rust repairs if possible....
Cheers,
Jeff
#107
_CraigA_
Posted 16 February 2010 - 09:41 PM
You could use the method we did; that was to fit the engine and then the headers, marking where they foul. We then used a small cut off wheel to removed the area we'd marked. This was done from inside the car. Once happy it was welded, seam sealed, and body shutzed.
I also needed to slightly mod the trailing edge of the engine mount.
There's some other threads regards Weber's so I thought I'd stick up some closer pictures of the throttle set up. Linkage kit from Pentastar, throttle cable from Jegs.
Edited by CraigA, 16 February 2010 - 09:42 PM.
#108
_mello92_
Posted 17 February 2010 - 12:02 AM
Not exactly impressed with them, if I knew about this beforehand I would have got something decent from the local Rural supplies shop.
And the adjustable links are Redline units too...? Fairly sloppy little buggers.
Someone correct me if Im wrong, please.
BTW Craig, Im sure that there are many fellas (myself included), and ladies, who would love to have a car of that standard.
A very big 'well done' to you!!
#109
_beergut_
Posted 17 February 2010 - 02:28 AM
Sump came from:
2/43 Dingley Ave
Dandenong
VIC 3175
JOHN POTTER
(03) 8774 0343 Ph
(03) 8772 2457 Fax
jesus that's charger and fraud phase 3 terrority lol
#110
_EFI-GTR_
Posted 17 February 2010 - 04:07 PM
#111
_CraigA_
Posted 17 February 2010 - 07:26 PM
#112
_CraigA_
Posted 17 February 2010 - 09:04 PM
Discovered a perfect product on eBay the other day and fitted it tonight. Its the Ecliptech Shift-i a programmable shift light with an upper and lower setting so I can preset a staging rpm range and a shift reminder.
Anyone used or seen these before?
#113
Posted 18 February 2010 - 08:19 AM
Got a link? The purple car could probably use one.
#114
_CraigA_
Posted 18 February 2010 - 09:19 AM
#115
Posted 18 February 2010 - 11:37 AM
#116
Posted 18 February 2010 - 02:44 PM
Thanks for the pics and the information Craig. Looks like I'll need to wait until I get the engine back in to cut the right spot...Hi Jeff, we removed most of the corner of the passenger floor that protrudes near the subframe mounting point. There is a picture below and while it looks like too much clearance I was trying to avoid any issues of the floor getting hot. I've been in plenty of cars that have had extractors fitted and the carpet has melted from radiant heat.
Cheers,
Jeff
#117
_CraigA_
Posted 18 February 2010 - 03:40 PM
And yes Peter, I'll be at Toranafest this year. Didn't get there last year because the old engine was dead at that time.
Thanks for your (and others) comments but the car is no show stopper, its a 10 metre car that gets used hard. I'm pretty certain that's what Harry Firth designed them for, rather than being considered too precious or 'worth too much'.
#118
Posted 18 February 2010 - 06:40 PM
#119
Posted 18 February 2010 - 08:17 PM
Blakey
#120
_CraigA_
Posted 21 February 2010 - 08:34 PM
Bloody hot in Sydney (especially today) but car didn't get over 185 deg F and ran fine EXCEPT yesterday when it popped and farted and stopped. Turned out that three spark plug leads came out at the dizzy cap side. Pushed them back in and off it went.
Here's a quick video of it on the freeway. MCH11N you can hear the sound of the air filters - to me its only a little less than what it was with open ram tubes.
Edited by CraigA, 21 February 2010 - 08:36 PM.
#121
_CraigA_
Posted 21 February 2010 - 08:54 PM
A guy posted a request on the forum for a photo and this is where it ended up
Edited by CraigA, 21 February 2010 - 08:55 PM.
#122
Posted 22 February 2010 - 07:53 AM
#123
_Macka_
Posted 13 February 2011 - 02:06 PM
<br /><br /><br /><br />If those things don't turn out to be massively restrictive I'll eat them..<br />
John, Did you ever end up trying these filters? I mean on a car and not eating them!!
#124
_CraigA_
Posted 05 May 2012 - 09:14 PM
We did over 20 runs most with full slicks and best of 13.8 seconds and 101.7 mph but got bored in the afternoon and put the stockies back on. My brother drove and first run out spun the wheels through the first two gears and into third. Car was everywhere. And then this - a 13.548 @ 100.05mph.
Best time the car has ever run and with 175/70/13 stockies with 32psi!!
Edited by CraigA, 05 May 2012 - 09:15 PM.
#125
Posted 05 May 2012 - 09:56 PM
Kevin, you are right , the Falcon uses this heat shielding HOWEVER it is a "thermoset " material, when you buy a NEW piece in a box it is cuttable with scissors and you can bend it with your fingers anywhere you want, once used and "cooked" sets nice and hard to the shape you created when first fitted. Impossible to rework as easily as a new piece. Chances of a Falcon piece fitting a Holden 6 cylinder with carbs and pipes on same side of head ( Falcon is X flow and injected) nil.if your after some heat shield go to the wreckers and look for a newer model falcon, a six cylinder one, they have then and wreckers will probs only want $10 for them, thats what i got on mine. that stuff works a treat aye
cheers kevin
