Interior trim codes
259 replies to this topic
#26 _[2_FLY]_
_[2_FLY]_
Posted 16 December 2010 - 03:51 PM
Not sure if this helps anyone, my plate says interior is 1930-18X, i`m not sure if i have the right interior for this code but i was told its the original
#27 _sloper35_
_sloper35_
Posted 29 January 2011 - 02:04 PM
Just some clarification
62V Is Doeskin Sadlon Vinyl. The car above has darker inserts indicating it has been retrimmed. The carpet colour (Chestnut) appears correct. Rear compartment shelf, Inst Panel pad and rear compartment shelf were also Chestnut. Doeskin could be had with either Chestnut (62V) or Black (63V) on 8UH, 8VC & 8VD00. Black meant Black carpet, Inst Panel pad Compartment shelf etc. If code is 62X then the insert iseither Chestnut Royal Cord Bodycloth (SL) or Black & White Ranier bodycloth (SLR) in but again with Chestnut carpet etc. 63X is the same but with Black carpet etc. Also remember id XY9 Neutral headling was optioned then the colour of Sunvisors, coat hooks and hand grips may change. In the case of Doeskin they did not change but if for example you have Black trim with XY9 then the Visors were Ash colour.
When one looks at the number of different combinations across LH and LX it can be somewhat confusing. The only good thing was that you could have any trim colour with any paint. BUT if L31 engine was ordered then some coloured interior parts changed to Black.
Also XY9 Neutral headlining changed to XU3 during the life of LH.
Hope this helps
Norm
#28 _darrenmark1_
_darrenmark1_
Posted 28 March 2011 - 08:42 PM
Orchid Metallic 15335
19X
Black with Herringbone Cloth Inserts with black carpet
All good as far as i can tell
There ya go Col, dragged it from the garage to take pictures for the interior thread.
Daz
Edited by darrenmark1, 28 March 2011 - 08:44 PM.
#29 Statler
  • 6,318 posts
Posted 28 March 2011 - 09:06 PM
Thanks Daz. That's 1 more off the list.
#30 dattoman
  • 16,487 posts
Posted 28 March 2011 - 09:12 PM
60A
Chamois golfball for LX
http://i713.photobuc...ld/P7190045.jpg
http://i713.photobuc...ld/PA170058.jpg
http://i713.photobuc...ld/PA170059.jpg
http://i713.photobuc...ld/PA310075.jpg
http://i713.photobuc...ld/PA310077.jpg
http://i713.photobuc...11/IMGP1062.jpg
#31 Swarbs
Swarbs
  • 1,671 posts
  • Car:LX 5000
Posted 03 April 2011 - 12:06 PM
Anyone know whether this is the correct interior for LX - 18X
Will be sorting an LX SLR 18X sedan soon so any info would be appreciated
There seems to be a hoard of different door trims and every LX SLR i seem to see is different
#32 _sloper35_
_sloper35_
Posted 03 April 2011 - 04:41 PM
Yes 18X is the optional cloth trim insert called Herringbone. Often mistakenly called Houndstooth, which is very different. I have recently been told that the initial Herringbone was Australian sources but did not wear well and was replaced with an American source. Has anyone noticed differnces, particularly in the sharpness of the Herringbone point? Just to confuse the issue are the Y and B trims, also cloth option but using chevron material (can also be found in Premiers)
Norm
#33 dattoman
  • 16,487 posts
Posted 03 April 2011 - 07:03 PM
So.... is this right
A is golfball vinyl
V is plain vinyl
Y is Chevron cloth
X is Herringbone cloth
B is ? .... maybe Houndstooth ?
#34 _sloper35_
_sloper35_
Posted 03 April 2011 - 08:30 PM
Neil not that easy
With LX SLR
18X, 60X, 64X and 65X are all Rainer Herringbone cloth inserts (XS9 option)
60B and 65B are Chevron cloth but the carpet is in contrast to the seat material ie Chamois 60B has Black Carpet and 65B Sienna has Dark Sienna carpet. Wherer as the Y trims have same or similar shade carpet.
60Y, 64Y, 65Y and 67Y are Chevron cloth. 60Y is Chamois with Chamois carpet. and 64Y is Gazelle with tan carpet
The Vs are Vinyl except for 60A and 65A which are Chamois vinyl (60A) with Black carpet and Sienna vinyl (65A) with Dk Sienna carpet The vinyl trims all have Vinyl Golfball inserts door trim inserts match. Door trim inserts on XS( option cars are all Golfball but mostly a different shade to the sadlon vinyl used on the facings. Ie 18X Slate Black with Herringbone cloth insert has Dark Grey Golfball insert material in the door trim. And so it goes.
Norm
#35 Swarbs
Swarbs
  • 1,671 posts
  • Car:LX 5000
Posted 03 April 2011 - 11:02 PM
Cheers for the reply norm
Have been told that herringbone was the standard but houndstooth was a dealer fitted or ordered option -- ?? -- not sure on this i have a houndstooth style trim on ther seats ATM but have run this through the forum before and it's not right
More interested in the door trims as there seems to be a million different doortrim styles - see a photo of an LX SLR interior and the bloody things are always different
Darrenmark to me shows herringbone -- 2-FLY's not sure but not herringbone and doesn't look like houndstooth -- ??
#36 _sloper35_
_sloper35_
Posted 04 April 2011 - 11:18 AM
Houndstooth was not released by GMH for LH or LX. I do not believe Dealers would have ripped out Herringbone and replaced it with Houndstooth. I have seen guys claim they have Houndstooth but its actually Herrinbone. Also have seen Houndstooth in a retrimmed LH SLR but with 18X trim on the plate.
This pic is I believe correct for 18X, Door card has Black sadlon vinyl with a Dark Grey Vinyl "Golfball" insert. On LH SLR the insert for 19V was Dark Ash LH SLR 18X was the same as LX SLR 18X I suspect you would have to have Dark Ash next to Dark Grey to see the difference.
#37 Statler
  • 6,318 posts
Posted 04 April 2011 - 11:39 AM
Now we have LX 18X
Thanks.
#38 hanra
  • 10,975 posts
Posted 04 April 2011 - 01:01 PM
Can anyone assist in what a -60Y SL/R 5000 door trim should look like?
Thanks.
#39 Swarbs
Swarbs
  • 1,671 posts
  • Car:LX 5000
Posted 04 April 2011 - 03:52 PM
Again thanks Norm and PM sent
#40 _sloper35_
_sloper35_
Posted 04 April 2011 - 04:30 PM
60Y is Chamois Vinyl with Chamois Chevrol cloth inserts - door trim insert is Covert Golfball vinyl. The same combination seems to have been used withn 60B the only difference being that 60B has Black carpet and 60Y has chamois. Other parts alo change like windlace and lower facia.
The attached pics are 60B but show what 60Y is like. There is also 60X which has Herringbone cloth inserts with Chamois and Covert "Golfball" door trim inserts.
#41 hanra
  • 10,975 posts
Posted 04 April 2011 - 04:38 PM
Ok Thanks, Im a little confused here as I found some info on -60Y which relates to a HJ Monaro. Now I just assumed that trim codes across holdens of that era would relate to the same materials????
It lists -60Y as Chamois/Covert with Herringbone Cloth Insert.
Scroll to the bottom:
http://www.44gpw.inf...monarocodes.htm
And from reading through the Interior Code Charts, it appears that a LH SL/R 5000 with 60Y has Covert floor carpets?
Edited by hanra, 04 April 2011 - 04:40 PM.
#42 _darrenmark1_
_darrenmark1_
Posted 04 April 2011 - 05:56 PM
When i got my car it had houndstooth cloth on the seats, i still have the rear seat with the cloth on it in the shed, they tell me it had been re trimmed.
Daz
#43 _sloper35_
_sloper35_
Posted 04 April 2011 - 08:22 PM
You are correct Hanra, I was too hasty with my reply and have yet to learn how to correct a post. Carpet is Covert but the point is 60Y has Chamois with mostly Chamois or Covert coloured interior parts like carpet, arm rests, crash pad, wind lace etc whereas 60 B is Chamois with Black parts except for the door trims which had Covert inserts.
Yes Holden and Torana shared the same trim material but be careful with the trim descriptions, they generally describe the overal interior rather than the seat material. HJ 60Y is listed as Chamois/Covert & Cloth which means Chamois Vinyl, Covert Chevron Cloth inserts.
#44 hanra
  • 10,975 posts
Posted 04 April 2011 - 08:53 PM
Thanks for your assistance! I have found in the trim code charts that on SL/R 5000 they change the covert dash pad to black along with the dash fascia. Ive tried Knox Carpets for Covert and they have advised they cant do it... I wonder if Covert Carpet is available anymore?
#45 TerrA LX
Posted 25 April 2011 - 06:43 PM
Can someone stick this thread to the top please?
#46 hanra
  • 10,975 posts
Posted 27 April 2011 - 09:40 PM
All of the Auto Upholstery stores I have contacted have advised Covert Carpet is NLA. Buckskin is the closest possible colour. So Cheveron cloth and Covert Carpet are both NLA and both play a big role in the -60Y Interior.. Great... How will I ever get my interior back to original....???????
#47 _bradxu1_
_bradxu1_
Posted 02 May 2011 - 07:03 PM
hi, havent been on here 4 couple years but just brought another slr and hav been trying 2 work out trim code ,i have looked at the charts but still having trouble, can some put up a pic off seats trim code 1914 60A ,cheers brad
#48 _sloper35_
_sloper35_
Posted 02 May 2011 - 07:43 PM
Hi Brad
60A is Chamois Vinyl with Chamois Golfball vinyl inserts and Black carpet. 60V is the same but uses Covert carpet.
60A image attached from a previous post.
#49 _sloper35_
_sloper35_
Posted 02 May 2011 - 07:49 PM
Stop Press
Now that I look at the image I just posted you can see the windlacing is darker. 60V has Doeskin windlacing and if a Sedan a Covert Inst Pad and lower instrument panel facia (except L31 then its Black). I now don't wonder if this is not an image of a 60V trim but fitted with Black carpet. The windlace on a 60B should also be Chamois.
#50 _l34inhatch_
_l34inhatch_
Posted 03 May 2011 - 04:31 PM
May be i just don't look in the right places, but what colour are these? I was told they are SS, but if they are 67V, I need a colour check. They look too redish to be tan!
