VH V8 DISTRIBUTOR IN LX
_vtss_
Posted 03 April 2006 - 08:55 AM
_MYLJ_
Posted 03 April 2006 - 09:23 AM
Posted 03 April 2006 - 09:26 AM
_vtss_
Posted 03 April 2006 - 09:28 AM
_Yella SLuR_
Posted 03 April 2006 - 09:33 AM
The large VK cap will fit, I'm running the large cap. You can see it up the back of this pic.
The only hassle comes in actually dropping the base in past the drip sill. This can be achieved by removing the plastic base (really easy to do). Once it is in, all fits readily under the drip sill.
Hope that helps. Only other thing, is remember to buy Blue Motor spark plug leads. Upgrading to 12v at the coil is optional, and plugs to VK plugs (larger pre-gap, otherwise same as Torana). EDIT: And a hi-energy type coil. The VK ones are oil filled, but tend to leak over time, best going for a solid state type coil (my experience anyways).
Edited by Yella SLuR, 03 April 2006 - 09:36 AM.
_vtss_
Posted 03 April 2006 - 09:46 AM
_devilsadvocate_
Posted 03 April 2006 - 09:49 AM
Edited by devilsadvocate, 03 April 2006 - 09:52 AM.
_Yella SLuR_
Posted 03 April 2006 - 10:23 AM
Tell me more, I didn't realise that. Which models, and what where the systems? I thought the VK was the only straight transfer for our old beasts. Happy to learn otherwise.v8 electronic distributor started from vc to vl commodore and wb serries. cap is very tight fit
From my experience it's not the cap that is the tight fit, it's the base as you drop it into the hole hitting on the drip sill. If your the plastic on the base is still pliable, you can distort the base to get it past the drip sill. I prefer not to risk it, and remove the base.
Posted 03 April 2006 - 12:15 PM
_vtss_
Posted 03 April 2006 - 01:27 PM
standard holden v8 cap and ford 80 to 83 v8 rotor from bursons . fits good and runs good its easyer with small cap to do timing just got back from drive perfect on road testI think the small cap and rotor button you are after is found on XD V8 falcons (the run the same type of dissy) Repco or someone similar will be able to hep you.
thank you to all
_Yella SLuR_
Posted 03 April 2006 - 02:16 PM
Edited by Yella SLuR, 03 April 2006 - 02:17 PM.
_vtss_
Posted 03 April 2006 - 02:48 PM
yes kept the red motor lead's and changed red motor standard ignition coil to an electronic high energy ignition coil that fits red motor leadThere ya go. It's a nice upgrade isn't it, so smooth. I take it going that option you get to keep your red motor leads.
Posted 03 April 2006 - 03:10 PM
Posted 04 April 2006 - 05:51 AM
_Yella SLuR_
Posted 04 April 2006 - 03:40 PM
