Posted 26 October 2009 - 08:07 PM
Posted 26 October 2009 - 09:12 PM
Posted 26 October 2009 - 09:22 PM
Posted 27 October 2009 - 06:24 AM
Posted 27 October 2009 - 05:51 PM
Better make sure I have good welds then
Heres another question, I cut and welded in some GTS guard flutes to my Gemini Guard today using the leap frog tack cool method and was just wondering is there any way to stop/reduce the shrinkage around the welds?
Like i get both the panels perfectly level but sometimes when you weld it then grind it back flush, around the weld is a little lower like its sunken away?
Posted 27 October 2009 - 07:34 PM
Posted 29 October 2009 - 04:58 PM
Posted 11 November 2009 - 07:11 AM
Posted 15 November 2009 - 09:58 AM
Posted 15 November 2009 - 10:51 AM
Posted 15 November 2009 - 03:02 PM
Posted 16 November 2009 - 10:51 AM
Posted 22 November 2009 - 05:52 PM
Posted 22 November 2009 - 09:34 PM
But doesnt overlapping the panels provide air gaps between the 2 and areas for water etc to get trapped and cause rust?
Yes, OEM.
or do you use seam sealer on every weld?
Ditto.
They last 30yrs+ if you did don't submerged them.
Posted 02 January 2010 - 07:08 PM
Posted 02 January 2010 - 07:22 PM
Posted 02 January 2010 - 09:03 PM
Posted 02 January 2010 - 09:05 PM
Posted 03 January 2010 - 01:22 AM
I also tried pressing the trigger abit without actually creating an ark to sorta get the gas "primed" but was still the same... Im leaning towards a wire feed problem? how do you know if you got the correct tension on the feeder?
Posted 04 January 2010 - 08:54 PM
Posted 05 January 2010 - 06:37 AM
Posted 05 January 2010 - 01:47 PM
Hey all... Ok well been doing abit of welding of late and am getting better... just 1 problem... When Im doing the tack tack tack... cool.... tack tack tack... cool... method (buttwelded sheetmetal together) the first tack I goto do is always crap, when I pull the trigger it goes, bang bang bang (splat splat splat) then ZZzzzzzzz and does a weld... but then if I do the next tacks pretty quickly (withing say 10seconds) they just go Zzzzzzzz... Zzzzzz... Zzzzz perfectly.... but then if I wait too long, 15seconds Plus... once again the first tack goes pop pop pop zzzzz...
Any ideas?
Here's my latest effort
Posted 05 January 2010 - 08:55 PM
Posted 05 January 2010 - 09:47 PM
Posted 05 January 2010 - 10:25 PM
