windscreen and roof lining
4 replies to this topic
#1 _355lxss_
_355lxss_
Posted 24 November 2005 - 08:15 AM
do i need to install the roof lining before the front windscreen goes in on the hatch? I presume the hatch window can go in at any stage?
#2 _Yella SLuR_
_Yella SLuR_
Posted 24 November 2005 - 09:03 AM
Yes. I have heard of a retrofit method where you can make the hood lining non-dependent on the windscreen, but I've never seen it. Might be worth some inquiries.
#3 _jimjet61_
_jimjet61_
Posted 24 November 2005 - 10:05 AM
It is probably best to fit the headlining first, especially if it is a new one, as they normally require a bit of trimming after you get it all nicely into place. I glued mine around the edges with contact adhesive. Makes it easier, and to get a nice tight looking fit, but, the lining could probably be installed after by poking it into the window seal. Good Luck Jim.
#4 GML-31
Posted 24 November 2005 - 10:35 AM
agree with Jim...best before fitting window
#5 _Yella SLuR_
_Yella SLuR_
Posted 24 November 2005 - 01:02 PM
The other way is some mix of how new cars are done (solid stiffener fixed along the windscreen head). Like I said, have heard of it, but haven't seen it done, but worth looking into.
