measurements for lx/lh rotisarary
#26
_Yella SLuR_
Posted 28 August 2011 - 10:03 PM
#27
_Liam_
Posted 20 January 2012 - 04:41 PM
#28
_Yella SLuR_
Posted 21 January 2012 - 08:38 AM
#29
_Liam_
Posted 21 January 2012 - 10:32 AM
Cheers Yella.
#30
Posted 21 January 2012 - 12:49 PM
The rotisserie had the link bar underneath and and castor wheels.
Id be loathe to load/unload it from a trailer or tilt tray without one as you use the lower brace of the rotisserie to attach the winch.
The car went really well on it - rotisserie chained to the deck and ratchet straps through the door openings to the deck.
To be sure I also chocked the underside with some axle stands the first few times but learned it didn't need them.
Like anything, go carefully and slowly and all wil be well.
Cheers, TB
#31
_Liam_
Posted 21 January 2012 - 01:53 PM
#32
_Yella SLuR_
Posted 22 January 2012 - 12:22 PM
#33
_Liam_
Posted 22 January 2012 - 02:15 PM
#34
_Yella SLuR_
Posted 23 January 2012 - 07:31 AM
#35
_Liam_
Posted 23 January 2012 - 10:18 AM
#36
_Liam_
Posted 23 January 2012 - 10:21 AM
#37
_Yella SLuR_
Posted 23 January 2012 - 12:38 PM
#38
_Liam_
Posted 23 January 2012 - 04:01 PM
#39
_Keiron_
Posted 02 June 2015 - 09:32 PM
I had a go with the design listed with a few more detailed photos I hope this helps other people with there projects.
One question tho the front arm that goes out under the car should it also have a 45 degree stay on it for stability also?
One last thing I would advise you make a plate to goto your flywheel as it is cast and hard to weld too even the engineering place I went to said they would not trust welding to the flywheel so I made a plate and welded the pipe to the plate then bolted it to the flywheel with hi tensile steel bolts.
Hope this helps.
_Jas76hatch_
Posted 20 September 2020 - 07:33 AM
#41
Posted 24 June 2021 - 09:50 PM
Hi folks! Awesome plans here and got me thinking about having a go at one. I have sone 50x50x2mm handy do you think this would be strong enough? Or am I better to try and find something 3-4mm?
Get 3 and 4mm. Not worth the risk of dropping it.
