Twin Turbo 253
76 replies to this topic
#1 _splosh123_
_splosh123_
Posted 09 November 2009 - 07:43 PM
Hey guys, me again.
Going to get rid of the 202 out my UC and going to go the 253 or 308, and hoping to get some info on Twin turbo or single turbo set up on it. Lay the info on the table. What i'm looking at, what will i have to do to the stock engine to get it able to support turbos. Etc etc.
Pretty much at the moment, I rushed my current project, and I've gone the wrong way about it. I started working on the engine, before working on anything else.
Also, I have 4 years to complete this project (Until i'm on my opens), so i have plenty of time to collect these things, rebuild things etc etc.
Josh
#2 _rocket_
_rocket_
Posted 09 November 2009 - 07:49 PM
Dont rush the next step, go chev !
#3 _splosh123_
_splosh123_
Posted 09 November 2009 - 08:06 PM
I want to keep it Holden, I think a 253 with RX7 Turbo Chargers, or RB20 Turbos could work aswell?
Obviously I'm not able to talk from experience as of yet, but i'm sure someone here can inform me.
#4 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 09 November 2009 - 08:59 PM
I think to keep it simple just use the stock exhaust manifolds but swap sides, left maifold go to right and right go to left side of the engine/heads. This should make the outlet of the manifolds face forward where you attach piping and turbos.
Or fabricate extractor style turbo manifolds.
You can get Jap turbos fairly cheap with internal waste gates.
Make sure you can squeeze the exhast pipe from turbos between the block and cross member you donr want to under cross member, they hang like dogs balls.
Did you want injection or carby?
What gearbox you want?
Wgat diff?
You need to upgrade brakes at least the front
I think youll have to change pistons and rods
Whats your budget?
Edited by Bart, 09 November 2009 - 09:01 PM.
#5 mr5000
mr5000
    chief break-everything
  • 3,455 posts
  • Car:77 lx 4door
Posted 10 November 2009 - 07:10 AM
copper head gaskets wouldnt hurt either something with that much grunt id be going 9 inch and depending on whether you want auto or manual as to what box
#6 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 10 November 2009 - 07:20 AM
Here are some pics of a turbo 308 I did about 8 years ago. Sorry, no pics of it all together running but this will give you a few clues.
Also the Series 5 RX7 turbo with a TO4 comp wheel inside the standard cover would be perfect for a 253 IMO.
Attached File  turboout1.jpg   270.39K   213 downloads
Attached File  turboout2.jpg   263.18K   249 downloads
Attached File  turboin1.JPG   353.93K   250 downloads
Attached File  turboin2.JPG   306.84K   218 downloads
#7 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 10 November 2009 - 11:12 AM
This looks like a nice simple seup
I remember this, what happened?
It would be good if you can use VN heads on the 253 to get it breathing better.
#8 _splosh123_
_splosh123_
Posted 10 November 2009 - 05:21 PM
Wgat diff?
Whats your budget?
Everything is up in the air at the moment, probably make it manual, 5 speed celica gearbox; if it can handle it.
Not sure about injection or carby yet, tossing it up, I suppose injection wouldn't be a bad idea, although do turbos run off an ECU? If it does i could get a ECU for the injection/turbos/sensors etc. Undecided on that one.
Diff unsure yet... waiting on some advice from you's to help me out.
I plan to do a full overhaul on the brakes, probably put HQ rotars all round.
Piston and rods; plan to do an engine overhaul so that will come with it.
Budget: 4 years of money that comes my way; so pretty much take it as it comes.
Josh
#9 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 10 November 2009 - 06:25 PM
Wgat diff?
Whats your budget?
Josh
The turbo boost is normally pressure controlled which activates the waste gate. I think I got that right :sofa:
You can have the boost controlled by ecu and solenoid, but the internal waste gate you get with the RX7 turbos can be left as is, i.e. pressure/pneumatic control waste gate
You can use HQ discs out front, this would be required by an engineer as you need ventilated.
The rear you can use a VN diff with VN discs
I think an ECU controlled engine would be less temperamental than carby/turbo setup. And nicer to drive. I think.
Piston and rods, probably you have to know what hp you want.
#10 _Viper_
_Viper_
Posted 10 November 2009 - 11:39 PM
Id like to do a twin-turbo setup in my Torry too, will be easy to make manifolds and get the turbo's to fit but is nowhere to run the exhaust past the motor... Under the crossmember would suck and I never liked exhausts going through wheel well..
so guess its underbonnet supercharger for me...
#11 _89'King_
_89'King_
Posted 11 November 2009 - 12:04 AM
it could be possible to run the exhaust abit lower than where it sits standard. just make the turbos high mount or infront of the engine between the block and radiator (depending on the size of the snail) and custom fab some pipes, it would be a dick-a-round but would look fantastic and you'd be able to run the exhaust pipes in roughly the same position as they already are.
Attached File  0245.jpg   171.73K   91 downloads
in that sorta position
Attached File  DSC_0006_preview.jpg   116.93K   88 downloads
lookin like that i spose...
i could be well wrong here thoPosted Image ...
#12 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 11 November 2009 - 09:12 AM
I was never happy with the lag (the turbo was a second hand truck unit and a bit big on the exhaust side) so bypassed the intercooler one day and rattled a piston to bits, split a bore and basically messed it up. I pulled it all apart and someone purchased the lot as it was. Never saw it again.
#13 _splosh123_
_splosh123_
Posted 11 November 2009 - 05:06 PM
How would i go about setting up a smaller turbo for the low end range, and bigger turbo for the high end range?
#14 dattoman
  • 16,487 posts
Posted 11 November 2009 - 05:12 PM
I would guess that would be a plumbing nightmare
If you size the turbos and get your comp ratios right and run sensible boost then lag isn't an issue
#15 _splosh123_
_splosh123_
Posted 11 November 2009 - 05:21 PM
Alright thats cool.
So running straight gas on the 308, with the turbos would be okay?
#16 Heath
  • 18,376 posts
Posted 11 November 2009 - 06:04 PM
Sequential turbos on a V8 would be a plumbing nightmare. You can get away with it on an inline four or six more easily, or a rotary, but yeah not a V8 in a Torana engine bay
#17 _splosh123_
_splosh123_
Posted 11 November 2009 - 06:10 PM
Now we're talking, I need to know these things. I don't want anything protruding the bonnet, so we need to keep this as a sleeper. And i don't want it to be too tight in there. So surely there is a way around this? Some sort of better custom turbo manifold to let it fit slightly better?
I've got my eyes set on this, but i also need to know how much work is going to be involved in this, and what i should expect to hold me up.
Also would a big single turbo work just aswell as say 2x RX7 or RB30 Turbos?
Edited by splosh123, 11 November 2009 - 06:11 PM.
#18 dattoman
  • 16,487 posts
Posted 11 November 2009 - 06:38 PM
A big single will give you boost... but lag more than 2 smaller ones
As suggested... extractors turned over to put them facing forward... 2 tubos strapped to the front.Plenty of room for pipes then
#19 _splosh123_
_splosh123_
Posted 11 November 2009 - 08:01 PM
Can you show me how the 2nd picture is relevant... excuse my ignorance but I can't see what it is in relation to what we're talking about lol.
#20 dattoman
  • 16,487 posts
Posted 11 November 2009 - 08:08 PM
Holden V8
2 turbos
whats not relevant ?
#21 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 11 November 2009 - 08:34 PM
the first one is injected turbo
the 2nd one is blow through carby turbo. Looks like a 4 barrel.
The previous post on using extractors and mounting them opposite sides i thought was a good idea, but the wall thickness on extractor i dont think are thick enough, the extractors/manifolds will get red hot with turbos. You should use 3mm wall steam pipe.
#22 Heath
  • 18,376 posts
Posted 11 November 2009 - 08:42 PM
Honestly what's wrong with log manifolds? I wouldn't go for extractors in that setup personally.
Would go straight LPG with the standard pipes, low boost and no intercooler probably, and yeah just some random OEM Jap turbos
#23 _splosh123_
_splosh123_
Posted 11 November 2009 - 08:45 PM
Sorry I was looking at the picture completely the wrong way... My head ins't screwed on properly tonight. I don't mind fabricating some custom turbo manifolds, or getting some fabricated... Whats stopping me from cutting out the wheel arch and slotting the two turbos in there? And running the exhaust down through there? Is there a engineering certificate or something needed for that?
#24 Heath
  • 18,376 posts
Posted 11 November 2009 - 08:55 PM
Registering a car with modified wheel arches is a pain I believe. Normally people try and avoid it because it looks tacky and isn't very good for power amongst other things on EHs etc when they put Chevs in them, but that's on N/A - with a turbo, neither of those rules really apply. I still don't think it's something you really wanna do
#25 dattoman
  • 16,487 posts
Posted 11 November 2009 - 08:57 PM
Have another look at your wheel and ask that again
usually you have to mod the footwells to fit any decent rubber in there so no idea where you would run pipes
Logs , extractors , stock cast manifolds.... its just ideas thrown around atm
