how to remove windows
16 replies to this topic
#1 _gen3torrie_
_gen3torrie_
Posted 13 November 2009 - 01:45 PM
how do i remove my windows out of the doors
gotta do doors now but the glass is still in
cheers josh
#2 Statler
  • 6,326 posts
Posted 13 November 2009 - 01:51 PM
front or rear?
Are you going to replace the bailey channel rubber?
Edited by coolngroovy, 13 November 2009 - 01:53 PM.
#3 MRLXSS
  • 12,415 posts
Posted 13 November 2009 - 01:52 PM
My passenger window use to just fall out on its own when you slammed the door! But i fixed that.
Best way, just thinking off the top of my head.. Remove the door trim (To gain access) and undo the bolts to the window winder regulator thing (Just undo all the bolts if you need to completely strip for paint)
You'll be then able to wriggle the window out, once its off its runners. You'll see what i mean when you get to this stage... Just put it on an angle, and pull it out from the top!
Also, start with the window full DOWN.
#4 _gen3torrie_
_gen3torrie_
Posted 13 November 2009 - 01:59 PM
col- front and rear
Matt- Thanks i'll do that now
i'll get back to yahs
#5 Statler
  • 6,326 posts
Posted 13 November 2009 - 02:11 PM
Front dooors.
Remove door trims....wind window fully up.....remove 4 bolts holding reg on..remove 2 bolts holding the slide on....remove slide....reach inside door & slide the window winder stalk in...slide the reg forward until the roller slips out of the guide...slide reg backwards until roller is out of the other guide....remove the reg. Lower the window by hand...tilt the glass[rear] upwards....remove to outside of window frame. Note: Having someone hold the glass inplace while you remove the reg is good idea.
Rears are a little more complicated.
#6 MRLXSS
  • 12,415 posts
Posted 13 November 2009 - 02:16 PM
LOL, My rears don't go down... They just unscrew haha
#7 Statler
  • 6,326 posts
Posted 13 November 2009 - 02:19 PM
Rear doors.
Remove trim.....wind window fully up...remove the nut holding the 'upright guide' adjuster....remove the screw at the top of the guide....wind the adjuster in until you can get it inside the door. Tilt the upright slightly sideways...Unscrew the adjuster & remove it...undo the 3 bolts holding the reg in...slide the window winder stalk inside....slide the reg forwards until the roller comes off the guide...remove reg. Fully lower the window... remove the bailey channel rubber from upright....tilt the upright forward...slide/pull the rest of the bailey channel rubber out....remove the upright....remove the glass. 1/4 glass simply pulls out with the rubber attatched. [Leave the 1/4 glass rubber on the glass. that way it wont shrink]
#8 _gen3torrie_
_gen3torrie_
Posted 13 November 2009 - 02:21 PM
well i just undone 3 bolts with the window down
undone it from the slider
and pulled and the front windows come out
then rebolted the slides in place again
rears dont work that way what can i do to get them out? i unbolted the winder and the Sliders and nothing happened
then i discovered a bolt near the lock i undone that and doh i lost me lock need midget hands to fix it...
please help me asap
#9 _89'King_
_89'King_
Posted 13 November 2009 - 02:22 PM
Rears are much the same as Coolngroovy described but to gain more leaverage, the bar between the window and the quater window has to come out (screws top and bottom) then remove the quater window (should theoretically slide out to the front of the car). once that is out the rear glass can be tilted in the same mannor as the front to remove it from the runners.
i have to do mine over the weekend (if not tonight) as well so if ya get stuck ill take some photos and post them up.
Josh.
#10 _gen3torrie_
_gen3torrie_
oh it seems you posted about the rears already ...
#11 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Name:Jesus Bloody Christ
  • Car:Goon
Posted 13 November 2009 - 02:32 PM
Please tell me you bought a workshop manual before you pulled it to bits.
Please.
They have drorins and strukshuns an stuff.
#12 _89'King_
_89'King_
Posted 13 November 2009 - 02:44 PM
Please.
drorins and strukshuns are for the weak! lol
#13 _gen3torrie_
_gen3torrie_
Posted 13 November 2009 - 03:39 PM
yes wot179 i do have a workshop manual i read it when things are broken lol
luckily this isnt the first torana ive pulled to pieces
... i was unlucky with the rear windscreen... one little crack in the corner caused the whole thing to shatter when we pushed it through
lucky i have a spare front and rear screen...
the rest of the glass is out
anyway back out to the shed to fix this mess i made
#14 Rockoz
Rockoz
  • 4,055 posts
  • Name:Rob
Posted 13 November 2009 - 04:36 PM
MMmmmmm.
Toughened glass with a crack.
Never seen that before.
#15 mitchg
mitchg
    The guy with the Torailer
  • 3,111 posts
  • Name:Mitch
Posted 13 November 2009 - 06:33 PM
Maybe you should read it BEFORE you break things :P
#16 robdog
robdog
  • 11 posts
  • Name:Robert Guppy
  • Car:LC SL 1971
Posted 15 July 2019 - 10:48 PM
Hi All,
I know I'm reading this almost 10 years after It started but this thread has been a great help.
Took me a few goes at reading to understand everything but has worked a treat on my LC.
Thanks,
Rob.
#17 LJ-1972
LJ-1972
  • 14 posts
  • Name:Nick
  • Car:LJ Torana
Posted 12 August 2024 - 08:38 PM
Hi all,
Trying to get the glass out of the Rear Doors; I took the regulator out, removed the top screw and bottom adjuster screw on that bar between the main window and rear quarter window. What do I do now? Everything is still rock-solid in place. The metal divider bar doesn’t move at all with the window up or down. Are there any tricks to this without breaking anything?
Cheers,
Nick
